Local Time 11:01 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bitwise reversal of a hexidemal number?
drkl
Posted: 09:21pm 16 Feb 2016
Helo,
TassyJim's solution is the best (by my opinion...). It operates every lenght:
main:
INPUT "BIN NUM, LENGHT(2...): ",s$, h
s$="&b"+s$
PRINT bin$(val(s$,h),h)," rev: ", bin$(bitreverse(val(s$),h),h)
GOTO main
FUNCTION bitreverse(num, k)
' reverse bit order
' num = integer to reverse
' k = number of bits (8 or 16)
LOCAL n
FOR n = 1 TO k
IF (num AND 2^(n-1)) > 0 THEN
bitreverse =bitreverse+ 2^(k-n)
ENDIF
NEXT n
END FUNCTION
twofingers
Posted: 04:20am 17 Feb 2016
  drkl said  It operates every lenght:
Hi Kónya,
this is not what TassyJim says!
I really appreciate Jim and his contributions here! Always good stuff!
He limitated the lenght for 8 or 16 (and it worrks well!).
But his code is not working for big negative 64bit integers (eg -1) and a lenght of 64 for example!
Note: the CFunction can be up to >100 times faster!
num (dec):-1 lenght: 64bit
1111111111111111111111111111111111111111111111111111111111111111
rnum (dec):-1
100 µs for one borev function call
1111111111111111111111111111111111111111111111111111111111111110
rnum (dec):-2
18242 µs for one bitreverse function call
Sometimes it depends on speed!
Thanks for your comment!
Michael
Posted: 12:05pm 17 Feb 2016
The bitreverse function was written well before we had integers (and CFunctions) to play with.
Assuming that we wanted to work in bytes, 16 bits is the max that we can use with 32bit floating point numbers. That is where the '8 or 16' number of bits came from.
twofingers
Posted: 04:37pm 17 Feb 2016
  TassyJim said   The bitreverse function was written well before we had integers (and CFunctions) to play with.
Yes, that's true!
I do not hope that you feel any kind of criticism!?
The C-code is very similar to your Basic code. As anybody can see.
Michael
ajkw
Posted: 11:49pm 17 Feb 2016
I thought I would do a bit of speed testing and it seems using a IF statement is marginally quicker. However it also seems it is even quicker if you drop the >0 test
IF (num AND 2^(n-1)) > 0 THEN ==> IF (num AND 2^(n-1)) THEN
The >0 test is not needed as (num AND 2^(n-1)) returns 1 or 0 / true or false which is all the IF statement needs.
Cheers,
Anthony.Edited by ajkw 2016-02-19
twofingers
Posted: 04:42am 18 Feb 2016
  ajkw said   I thought I would do a bit of speed testing and it seems using a IF statement is marginally quicker. However it also seems it is even quicker if you drop the >0 test
Cheers,
Anthony.
Hi Anthony,
you are right!
This solution is not only faster it eliminates also the bug for negative numbers.
Input:
num (dec):-5 lenght: 64bit
1111111111111111111111111111111111111111111111111111111111111011
Output:
1101111111111111111111111111111111111111111111111111111111111111
rnum (dec):-2305843009213693953
99 µs for one borev CFunction call
17199 µs for the NEW bitreverse function call
Michael
EDIT
This seems a fast (12862/17199 µs) modification of Jims code to be:
' reverse bit order
' x = integer to reverse
Function brv(x,k) As integer
Local n
For n = 1 To k
If x And (1<<(n-1)) Then
brv=brv+(1<<(k-n))
Next
End Function
Edited by twofingers 2016-02-19
