Forum Index : Microcontroller and PC projects : PWM command hates me...
Maximite has 4 but I use 2 of them for I2C We still have the problem with counters overflowing the floating point counter. I haven't investigated too far yet. Jim VK7JH MMedit |
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
Both the Maxi and Mini chips are listed as having 5 16 bit timers. Does that mean 5 possible completely independent (16 bit) pwm channels ? |
Manual says 5 PWM or SERVO channels, so I would say yes. From the uM manual, page 44 under PWM: Smoke makes things work. When the smoke gets out, it stops! |
But it says "both" implying 2 ..... AND ! I mean the chip itself ... I know MMBasic's not setup for that. I guess 5 'controllers' is what I'm dreaming of :) |
