Local Time 13:01 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Meter Clock
palcal
Posted: 11:12am 14 May 2015
  Quote  How about a meter that sweeps back and forth for the seconds? With the meter mounted upside down it would look sort of like a pendulum. It would give the clock some animation.
@ Justplayin
Yes I was thinking the same thing, now that you mention it maybe it would look good with all the meters upside down. I might have a closer look at the code and see if my humble programming skills would be up to adding the seconds and then the PCB would also need an upgrade.
Paul.
viscomjim
Posted: 01:48pm 14 May 2015
palcal... or you can use some rc servos and mount some monster size needles to them....
Benzol
Posted: 03:23am 17 May 2015
Hi Jman. I recieved the boards the other day, thanks. Yu mentioned in your post above a track needs to be cut and a wire link added. Where would these be located?
