Local Time 00:17 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Ir is working but not on sony tv
plasma
Posted: 08:53am 21 Apr 2014
Hi ,
first off all Geoff ir code works fine with my sony tv.
and now the secret : where is no really secret , the only thing is the timing for sending the ir codes.
u need to repeat the signal 3 or 4 times with a delay with 26 ms between .
a simple :
for r = 1 to 3
ir send 14,1,21 ( pin 14, device 1 (tv),command 21 on/off
pause 26
next
will turn the device on or off .
all commands i testet are working .
have fun .
ir codes sony ir codes
Posted: 08:26pm 21 Apr 2014
Ah, very good to know. Thanks!
I would have not guessed that you had to repeat the codes.
This will save some time.
