Local Time 22:59 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Wind Turbine Solar Inverter
norcold
Posted: 01:00pm 04 Jan 2013
I`ll add my collection of antique spirit level bubbles that Yahoo2`s on the money. If that 10mm is 10mm diameter I`ll relieve you of them for all my bubbles
Vic
MOBI
Posted: 01:16pm 04 Jan 2013
  norcold said  Your current wiring may be enough, would depend on the number of panels wired in seies. My system has 3 banks (arrays) of 6 X 12v panels. Which equates to up to 120 volts per array max(6X20v) Cells are poly also. Wiring is only 4mm which is ample as time has proved.
The sun was shining brightly this morning at 0800 and the system was charging at 26+ amps.
My array is 2 banks of BP Solar 85watt poly silicon panels. Each bank is 4 x 12v in parallel. The two banks are then in series to give me a 24v system.
My solar voltage usually sits around 40v on a sunny day such as today. I probably don't need heavier wire than I have, but the set up isn't the neatest in the panel wiring department so when I tidy it up (counduit etc) I'll put in the 10mm cable.
I might see if I can set up a logger to record things such as solar volts over a period of time to cover days from sunny to overcast.
I reckon we need a topic just called "My System" or something similar to showcase what we each have - a bit like a blog.
  yahoo2 said  I would be doing the boring stuff first.
Get the multimeter out and probe the back of the panels and see what potential you have to work with.
That's on my list of things to do. I want to get the new array mounted on the shed roof and then I'll do the tidy up and overhaul thing.
Edited by MOBI 2013-01-05
David M.
