Local Time 21:02 24 Oct 2026 Privacy Policy
Forum Index : Other Stuff : NiFe, Nickel Iron Batteries, Ni-Fe
     Page 2 of 3
ChargedUp
Posted: 08:12am 28 Dec 2012
Here are some more project photos:
700 Ah 24 Volt battery near Moab, UT
400 Ah 24 Volt battery in New Mexico
800 Ah 48 Volt battery near Cadillac, MI
Wind turbine to power up the 800Ah battery bank
Solar Array to charge up a new 1000 Ah 48 Volt bank in Colorado
Posted: 10:29am 28 Dec 2012
Wow!
Thank you ChargedUp, that is an absolute goldmine of information.
ChargedUp
Posted: 10:47am 28 Dec 2012
Thanks for the positive feedback. I love this stuff!!! Here are some more historical documents you may enjoy.
This 1914 Manual was purchased from Ebay, is a one-of-a-kind, and is the most expensive book that I own... just don't tell my wife how much it cost!
2012-12-28_204353_Edison_Manual_--_Battery_Charging_1914.pdf
This document is from 1911 Scientific American magazine
2012-12-28_204453_1911_Edison.pdf
A pertinent Edison quote...
And Edison's original EV that was Ni-Fe powered (but only went about 10-15 mph)
One more fun photo...
Edited by ChargedUp 2012-12-29
Posted: 12:22pm 28 Dec 2012
Truly fascinating stuff ChargedUp.
How are modern NiFe cells constructed ?
Do they still use the perforated tubes and stacked oxide/nickel flake method that Edison used, or some other method.
Georgen
Posted: 11:04pm 29 Dec 2012
  Georgen said
Any price that I can get for finished NiFe Battery seems to have 'tree hugging' component built into the price irrespectively if supplier is in China or US.
E-Bay 130Ah Deep cycle AGM battery with free delivery $299 need 4 of them to make bit over 500Ah 12V storage. Just $1,200 for all 4
Making it 4 lots for the price of one.
“Inexpensive” Edison 500Ah 12 V system $4,500 plus delivery
http://ironedison.com/nickel-iron-ni-fe-battery
Break even mentioned on Edison page after 8 years, which suggests that AGM batteries system will break down in about 2 years, as you can get 4 lots AGM for the price of one Edison.
George
yahoo2
Posted: 01:31am 30 Dec 2012
Hi George,
you are not really getting this are you!
I have looked at the web site for the best part of 2 minutes and a number of things things are immediately obvious.
1. Nickle iron batteries are discharged to 95% NOT 35%, you are not taking this into account.
2. The middle sized batteries in their range in a 12volt bank loaded with electrolyte are going to be a total weight close to half a tonne. This is a whole different league to cheap-arse AGM's on ebay. Electrolyte volume is king when it comes to battery capacity and longevity.
3. The site is in American dollars.
An equivalent mid range battery bank to compare it with would be a 1500Ah trojan or Raylite.
Rolls/surrette $3500-$4500 (they don't last)
raylite or trojan $4,500 +
BAE / trojan industrial $6,000+ (the next level up again)
Georgen
Posted: 01:24pm 30 Dec 2012
Looks better now
George
MasterCATZ
Posted: 10:57am 19 Jan 2013
I am also thinking about building my own nife batteries
I was wondering what fish tanks would be like for containers
I know a guy that just makes heaps of them for something to do ...
just unsure how silicone reacts with the chemicals needed
I have fish tanks that have lasted over 20 yrs in the sunlight
and these seem more like HH0 generators reversed
maybe looking for nickel / ion foils might work out cheaper / surface areaEdited by MasterCATZ 2013-01-20
Posted: 11:22am 19 Jan 2013
Don't know about the silicone rubber sealer, but should be o/k ??
Edison built his original NiFe batteries in a hard rubber case.
Silicone rubber is impervious to just about anything except petrochemical solvents.
Do they make small plastic framed glass fish tanks ?
I have no idea.
Edited by Warpspeed 2013-01-20
jack fork stik
Posted: 04:22pm 19 Jan 2013
are nife's like nicad's as in for every ah taken out you need to put 1 1/2 ah back in compered to lead acids that you only need 10% more?
MasterCATZ
Posted: 04:57pm 19 Jan 2013
From my workings I should be able to DIY for around the same price as buying manufactured lead batteries / AH
for now I will just do a 12v system and if it works go for a 48v system and hook it up to a solar inverter
I should be able to store 6kw worth of power easily even if I get poor ah per cell
pretty confident I can make 200 ah cells cheaply enougth
the guy practically gives away his small fish tanks for like $5 for 30x15x15 tank
and the large 180x90x90 one I got from him was only $80
pretty sure he has something along the size I need
looks like I will have to get the foils from china could not find any supplies in AU guessing .5 mm thick will do and just use plastic washers and rods like we use in HH0 generators
just unsure if I should get expanded foil or not ( mesh / matt design )
I am pretty sure I would loose the surface area
http://www.simon.richardson.net/homepower/edison.html
What are the characteristics of the cell?
iFe cells are a fully-charged voltage of 1.25v per cell, a fully discharged voltage of 1.0v per cell, and a charge endpoint of 1.8v per cell.
They have a rather high rate of self-discharge: 0.33% per hour. That equates to about 8% per day, about 43% per week. about 67% in a fortnight, about 90% in a month.
A trawl online also uncovered a manual for the original Edison product.
nickel hydroxide surface area of 17 to 19 m2/g.
typical Ni(OH)2 particle sizes are around the 20μm diameter. Since conductivity is through particle contact, a covering layer of 20μm should be good. The material has a density of 1600kgm-3
An ampere-hour of charge is approximately 37.3mMol of electrons. Here are the weights of various active reagents in this cell:-
Reagent Molar Mass Mass for 1Ah Notes
Hydroxyl Ion 17.0g 630mg
Nickel 58.7g 2190mg 8900kgm-3
Nickel Hydroxide 92.7g 3460mg 1600kgm-3
Nickel Oxyhydroxide 91.7g 3420mg
Iron 55.8g 1040mg 7850kgm-3
Iron Hydroxide 89.8g 1675mg
Surface area and dimensions
To obtain the required surface area, each gram of Ni(OH)2 will need to occupy about 20m2 of electrode. That means about 70m2 per Ah. Anything much less than this is going to give excessively high internal resistance. If we use nickel wire where 75% of the wire reacts, then we need 2.92g of wire, which has a volume of 3.28 x 10-7 m3. Modelling wire as a cylinder of area 2πrl and volume πr2l gives a ratio of volume to area of r/2. Substituting our area and volume gives a radius of 9.4nm, or a diameter of 19.8nm. That's silly.
However, the particle sizes of 19μm clearly don't match this area/volume ratio, so the material itself must be porous. By substituting in the densities and molar masses, we can see that to produce 20μm of nickel hydroxide requires 2.3μm of nickel. Given that using 75% of the wire means using 50% of the diameter, a diameter of 10μm would seem about right.
In volume terms, for each Ah of capacity, 0.25cc of nickel combines with 1.26cc of water to form 2.16cc of nickel hydroxide. So the initial charging process that creates the nickel must increase the volume of the cell by 0.65cc. A similar expansion is likely to occur at the iron electrode.
Edited by MasterCATZ 2013-01-21
powerednut
Posted: 12:59pm 24 Jan 2013
I can't provide any info as to the accuracy of the information in this link, but the article "How to Make Economical, Green, High Energy Batteries" may be of use:
MakingBatteries
Posted: 01:33pm 24 Jan 2013
Catz,
It will be a long time before I am free of all my existing projects and can look into all this myself.
The main advantages of NiFe batteries seems to be the very long life of these batteries and freedom from all the slow deterioration and failure modes common to many other battery chemistries.
While initial cost is always a big factor, a battery that lasts 30 years or 60 years has to be better than a 3 or 6 year life battery.
The big disadvantage appears to be that of high internal resistance, unless extraordinary measures are taken to keep this low.
As I see it, if the battery is sized to have a very high total amp hour capacity, relatively fast discharge rates are not going to be required anyway.
If very high intermittent discharge rates are a prime requirement, as it could well be with a huge oversized inverter, and motor starting.
How about combining some Ultracaps to a NiFe battery ?
These could also soak up large infrequent peaks in charging current without wasteful load dumping.
Tassie Mike
Posted: 03:44am 07 May 2013
I found some really old DEAC batteries at the scrappies ! orig Edison config, covered in black tar paint and metal cases.
Pix when I get them charging
Am going to replace the electrolyte in a month or so when I get back to Tassie from the mainland -- leaving tomorrow.
Here is a guy who mixes Potassium Hydroxide with a small amount of Lithium Hydroxide to make a better electrolyte ! :-)
BY THE TONNE !
Really, by the tonne
Brad Parker ph 0410146356
Cheers all
Tassie Mike
Georgen
Posted: 09:17pm 12 Aug 2013
Found this supplier :
http://ironcorebatteries.com.au/page2.php
10 pieces 500 Ah about $4,000 US plus delivery
10 pieces 200 Ah about $1,700 US plus delivery
Also payment for currency exchange, plus few more.
On top of that GST 10% and probably duty too.
George
Posted: 12:02am 13 Aug 2013
One would think lithum might be more cost effective in the longer view.
Also if you were to import a quanty for self use, you would want to order them in at least 1 week intervals, and stay under $1000.00 per order, as in this great country there is no duty on import orders under $1000.00
Althought if all orders arrive on the same day you will be charged duties on the total combined orders.
Its a simple use of the system, but overseas sellers dont care and dont understand the importants of dispaching goods over a time period, and tend to send all orders together.
This is why you need to watch the limit and stretch the order out, even with added freight charges it still often works out far cheaper and no import hassels to stay under the $1000.00 limit.
Pete.
Bryan1
Posted: 10:45pm 13 Aug 2013
G'Day Guy's,
Finally got around to reading this thread and I do have a bank of old cells that a mate gave me. They came from an airforce base and have been powering my shed radio for the last 10 years via an 80 watt pv panel. I have set the dump charge to 16 volts and for years they worked 24/7 but now they are getting a bit tired mainly due to me adding distilled water over the years.
I do think a fresh wash of distilled water and new batch of electrolyte may bring these babies back to life again. It is good to see that soap company is in Adelaide so I'll have to go grab a 5kg bag and do a good readup on the whole process.
Cheers Bryan
Georgen
Posted: 07:51pm 14 Aug 2013
From what I read 10 years is long run on one batch of electrolyte.
(You are very lucky to get set.
Pity that it is so hard to buy old stock locally)
George
Georgen
Posted: 03:56pm 20 Aug 2013
Relevant link to this thread:
http://ps-survival.com/PS/Batteries/NiMH/Iron-Nickel_Battery _2008.pdf
From page 15 of this thread:
http://www.thebackshed.com/forum/forum_posts.asp?TID=2979&PN =1&TPN=15
Suppose best to come back here with Ni-Fe batteries or we might start another thread on:
‘Home made Ni-Fe batteries’
George
Tassie Mike
Posted: 11:45pm 26 Aug 2013
Just saw this link, http://www.noonco.com/edison/improvements.htm
Mike
     Page 2 of 3
