Local Time 21:37 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM runs 65k VGA 800x480 resolution
TC 72
Posted: 08:18pm 26 Feb 2014
hello zonker
thank you for this idea, but I already tried the code to manage the display is in C, I got to do my interface but not managed the touchscreen.
did you read the basic program geoff?
Can you explain the operation of sub keys on playback?
I just deleted the " ' "(REM) before the establishment and management functions of the touchscreen.
Be careful if you want to see the keys and have no error on the part of the display of coordinates must be set according to the key type of display.
thank you in advance for your help.
has soon
thierryEdited by TC 72 2014-02-28
plasma
Posted: 08:53am 27 Feb 2014
for this price you can also put a raspberry pi or beaglebone to the tv.
even you get HD , much moore color und a faster rs232
now write you own software to read micromite commands from serial and create a full hd gui with.
overpowered, overpriced but possible if u will
Zonker
Posted: 07:06pm 27 Feb 2014
@TC 72.. Well, I too have to admit that it's a bit overpriced..!! But at the time, there was no "TFT Maximite"... I wanted to create a GUI of some type that the pilot could quickly get to the data needed... And, BTW, I didn't write a single line of code for the display. I used the "Visi-genie" part of the IDE and just created the screen layouts containing the displayed objects and compiled it into a working piece of code inside the GPU. Then, just sent properly formatted serial strings to the unit to update the objects. Kinda easy... Still, I wasn't happy about the cost... After the TFT MM came out, Jman helped me to get a prototype TFT unit rumming using a UBW32 board.. I am (so far) quite happy with it, and would like to create a new PCB and repackage this neat design... But, then got involved with the uMite Bata testing so have been delayed a bit... Will get back on track soon... I like the uMite for doing all the SPI based data collection work for the project, as this will help in creating cheap "potted module" based building blocks for the system all connected through the Rs-485 comm line...
Anyway, nuff babble... Thanks again Gents..!!
TC 72
Posted: 08:09pm 27 Feb 2014
thank you to you for your comments
the choice of μlcd 4dsystem was made ​​two years ago because I thought I could do what I wanted with the only intelligence processor display.
out I do not know C programming. more poster has an 8-bit processor
that which requires to do a lot of manipulation for calculation.
when the rasberry I do not know of all the world of linux and or android.
if there is an interpreter in basic mmbasic as simple as this could interresser me.
if you have a source I'm interested.
by cons for my loop problem asks me have you looked?
see you soon and thank you again
thierry
TC 72
Posted: 09:28pm 08 Mar 2014
hello all
I solved my little problem operating touchscreen.
in fact it is the reading loop keys must be dimensioned.
that is why I asked the question to the author, the demo works in this state does it.
no answer so I looked ....
thank you to everyone who took the time to read and wonder.
thierry
psergiu
Posted: 09:34pm 08 Mar 2014
That's very good, congratulations !
Can you please post some updated BASC code in here so next time somebody else has the same issue can find-it easily ?
Thanks.
TC 72
Posted: 11:48pm 13 Mar 2014
hello
here is what I am running I still have a big problem is the speed.
must hold the button for 1 second at 1.5 it is detected.
I am looking ......
ps: desolated my comments are in french
has soon
thierry
' demo of the graphics library for the 4D-Systems PICASSO range of touch LCDs
' this has been tested on the 4.3 inch and 3.2 inch serial displays
' models: uLCD43(SGC) and uLCD-32PT(SGC)
' the demo displays the time and some other graphics (see the photo)
' buttons are not used but can easily be added
' Geoff Graham, March 2012
'ajout d'un pavé numerique de 0 a 9 avec touche correction et touche validation
'affichage sur le lcd de la valeur de la touche du nombre de frappe
' de la valeur du nombre tapé
'la touche validation est non active
' chevallier thierry mars 2014
' open the display
LCDOpen 4
'definition du hard
SetPin 1,1
SetPin 2,1
'couleurs et positions
TCol = RGB(0,1,1) ' time display colour and position
TVPos = 0
WnCol = RGB(0,0,0)
WCol = RGB(0,.8,0) ' water display colour and position
WVpos = 120
bncol = RGB(0,0,0)
BCol = RGB(1,0,0) ' battery display colour and position
BVpos = 156
ICol = RGB(0.9,0.9,0) ' inside temperatures display colour and position
IVpos = 198 : IHpos = 45
OCol = RGB(0.9,0.9,0) ' outside temperatures display colour and position
OVpos = 198 : OHpos = 196
'***variables
T = 0
'nettoyage des ecrans
LCDCLS ' clear the screen and any buttons
Cls
MainScreen:
'temp1 = Pin(1)*100
'temp1 = (temp1-50)*1.2
'T1 = Int(temp1)
'T1S = Int(T1/7.15)
'If T1<0 Then T1= 0
'If T1>215 Then T1= 215
'T1 = Abs(T1)
'temp2 = Pin(2)*100
'temp2 = (temp2-50)*1.3
'T2 = Int(temp2)
'T2S = Int(T2/7.15)
'If T2<0 Then T2= 0
'If T2>215 Then T2= 215
'T2 = Abs(T2)
Print " prog en cour"
'Print@(10,10) temp1; print@(150,10) temp2
'Print "T1 :",T1; print "T2 :",T2
'Print "T1S :",T1S; print "T2S :",T2S
Print@(150,130)T
Print@(150,150)val
'************boutons********************
' this demo does not have any butons but this is how you would set them up
'****positionnement et labelisation des boutons
'exemple de bouton sans label ici la totalite de l'ecran
'LCDBSetup 0,0, "", 240, 100 ' button not labeled (area of the screen)n'est pas utilise
LCDBSetup 0, 0, "1" ' button labeled t1
LCDBSetup 45, 0, "2" ' button labeled t2
LCDBSetup 90, 0, "3" ' button labeled t3
LCDBSetup 0,50, "4" ' button labeled t4
LCDBSetup 45,50, "5" ' button labeled t5
LCDBSetup 90,50, "6" ' button labeled t6
LCDBSetup 0,100, "7" ' button labeled t7
LCDBSetup 45,100, "8" ' button labeled t8
LCDBSetup 90,100, "9" ' button labeled t9
LCDBSetup 0,150, "C" ' button labeled t10
LCDBSetup 45,150, "0" ' button labeled t11
LCDBSetup 90,150, "V" ' button labeled t12
'*******************fin boutons***********************
'LCDPrint 0, WVpos+2, "Temperature", WCol, 15
'LCDLine 96, WVpos, 319, WVpos+20, WCol, 1
'LCDLine 100+T2, WVpos + 4, 318, WVpos+16, WnCol, 2
'LCDLine 100, WVpos + 4, 100+T2, WVpos+16, WCol, 2
'LCDPrint 0, BVpos+2, "Temperature", BCol, 15
'LCDLine 96, BVpos, 319, BVpos+20, BCol, 1
'LCDLine 100+T1, BVpos + 4, 318, BVpos+16, BnCol, 2
'LCDLine 100, BVpos + 4, 100+T1, BVpos+16, BCol, 2
'LCDPrint IHPos, IVpos,Str$(T1S), ICol, 30
'LCDPrint IHPos-30, IVPos + 8, "T", ICol, 12
'LCDPrint IHPos-30, IVPos + 24, "1", ICol, 12
'LCDPrint IHPos+80, IVPos, "C", ICol, 13
'LCDPrint OHPos, OVpos,Str$(T2S), OCol, 30
'LCDPrint OHPos+110, OVPos + 2, " ", OCol, 12
'LCDPrint OHPos+110, OVPos + 16, "T", OCol, 12
'LCDPrint OHPos+110, OVPos + 30, "2", OCol, 12
'LCDPrint OHPos+80, OVPos, "C", OCol, 13
'Do ' this loop never ends
' If tlast$ <> Left$(Time$, 5) Then
' tlast$ = Left$(Time$, 5)
' hrs = Val(Left$(Time$, 2)) : min = Val(Mid$(Time$, 4, 2))
' If hrs > 12 Then hrs = hrs - 12
' If hrs >= 10 Then oset = 0 Else oset = 6 * 5
' LCDPrint 10 + oset, TVPos, Format$(hrs, "%g") + ":" + Format$(min, "%02g"), TCol, 45
' LCDPrint 26, TVPos+80, "Quantite silot", TCol, 10
'LCDPrint 26, TVPos, Str$(Pin(1)), TCol, 30
'LCDBsetup 25,30,"test1"
'LCDBsetup 176,30,"test2"
'LCDBsetup 25,198,"test3"
' LCDPrint 8, TVPos+80, Time$+" "+Date$, TCol, 21
' this demo does not have any butons but this is how you would detect a
' button press and run the appropiate subrouting to handle the press
On LCDTouch() GoSub t1,t2,t3,t4,t5,t6,t7,t8,t9,t10,t11,t12
lcdprint 130,10, Str$(T)
'lcdprint 130,30," "
lcdprint 130,30, Str$(val)
' this demo does not have any butons but this is an example of how you would
' handle a button press. Note that these are the target of GOSUB's
t1: If T = 0 Then
val = 1
Else
val = (val*10) + 1
T = T +1
Return
t2: If T = 0 Then
val = 2
Else
val = (val*10) + 2
T = T +1
Return
t3: If T = 0 Then
val = 3
Else
val = (val*10) + 3
T = T +1
Return
t4: If T = 0 Then
val = 4
Else
val = (val*10) + 4
T = T +1
Return
t5: If T = 0 Then
val = 5
Else
val = (val*10) + 5
T = T +1
Return
t6: If T = 0 Then
val = 6
Else
val = (val*10) + 6
T = T +1
Return
t7: If T = 0 Then
val = 7
Else
val = (val*10) + 7
T = T +1
Return
t8: If T = 0 Then
val = 8
Else
val = (val*10) + 8
T = T +1
Return
t9: If T = 0 Then
val = 9
Else
val = (val*10) + 9
T = T +1
Return
t10: lcdprint 130,30," "
val = 0
t = 0
Return
t11: If T = 0 Then
val = 0
Else
val = (val*10) + 0
T = T +1
Return
t12: Print "V" ' fonction non utilse pour le moment
Pause 250
Return
' graphics library for the 4D-Systems PICASSO range of touch LCDs
' open the LCD display for access
' this resets the display and opens comms at 9600 baud
' com is the communication channel. ie, 3 for COM3:
' pin 17 is used to reset the display and should be connected to the RES
' pin on the LCD. This must be called once at the start of the program
Sub LCDOpen com
Dim LCDBut(15, 5) : Dim LCDBMsg$(15) ' these are used to record the buttons tableau agrandi a 15
Open "COM" + Chr$(com + 48) + ":9600" As #10
' Open "COM4:115200" As #10
SetPin 17, 9
Pin(17) = 1
Pause 2000
Print #10, "U";
LCDGetAck
' Print #10, "Q" Chr$(13);
' LCDGetAck
' Close #10
'Open"com4:19200" As #10
Print #10, "Y" Chr$(5) Chr$(0); ' enable the touchscreen
LCDGetAck
' he following is only needed if the display is in portrait mode
Print #10, "Y" Chr$(4) Chr$(1); ' rotate a portrait screen to landscape
LCDGetAck
' clear the LCD screen and any buttons that have been setup on it
Sub LCDCLS
Local i
For i = 1 To 10
LCDBut(i, 0) = 0
Next i
Print #10, "E";
LCDGetAck
' print a string on the LCD
' z and y are the coordinates, msg$ is the text
' c is the colour and f is the font (both are optional)
' f is two digits, the first is the scale and the second is the PICASO font
Sub LCDPrint x, y, msg$, c, f
Local scale, opaque
If f = 0 Then f = 13
scale = (f\10) Mod 10
opaque = ((f\100) = 0)
If scale = 0 Then scale = 1
f = f Mod 10
If c = -1 Or c = 0 Then c = RGB(1,1,1)
Print #10, "O" Chr$(opaque);
LCDGetAck
If f > 3 Then f = f - 3
Print #10, "S" LCDWords$(2, x, y);
Print #10, Chr$(f) LCDWords$(1, c);
Print #10, Chr$(scale) Chr$(scale) msg$ Chr$(0);
LCDGetAck
' draw a line or a box
' x1, y1, x2, y2 are the start and end coordinates, c is the colour
' b = 0 will draw a line, b = 1 will draw a box and b = 2 a filled box
' c and b are optional and will default to a white line
Sub LCDLine x1, y1, x2, y2, c, b
Local cmd$, pen
If c = -1 Or (c = 0 And b = 0) Then c = RGB(1,1,1)
If b = 0 Then
cmd$ = "L"
Else
cmd$ = "r"
Print #10, "p" Chr$(b = 1);
LCDGetAck
Print #10, cmd$ LCDWords$(5, x1, y1, x2, y2, c);
LCDGetAck
' generate a colour index for the LCD
' r = red, g = green and b = blue
' the values can range from zero (full off) to 1 (fully on)
Function RGB(r, g, b)
RGB = Int(r * 31) * 2048 + Int(g * 63) * 32 + Int(b * 31)
End Function
' draw a button on the screen and initialise it
' x and y are the top left coordinates of the button
' msg$ is the caption for the button. This can be a zero length string
' (ie, "") and in that case the button is not drawn and x1 and y1 are
' used to define an area on the screen which, if touched will return a
' button press. A maximum of 10 buttons can be defined.
' x1 and y1 are optional
' dessin des boutons ecritude des "labels"
Sub LCDBSetup x, y, msg$, x1, y1
Local i
For i = 1 To 12
If(LCDBut(i, 0) = 0) Then Exit For
Next i
If i > 15 Then Error
LCDBut(i, 0) = 2: LCDBut(i, 1) = x: LCDBut(i, 2) = y
LCDBMsg$(i) = msg$
If msg$ <> "" Then
LCDBut(i, 3) = x + Len(msg$) * 24 + 12: LCDBut(i, 4) = y + 44
LCDButton 1, x, y, msg$
Else
LCDBut(i, 3) = x1 : LCDBut(i, 4) = y1
' returns the button number that has been pressed or zero if no buton pressed
' normally this is used like this: On LCDTouch() GoSub msg1, msg2, msg3
' the button number is the order in which they were set up
' boucle de controle des boutons
Function LCDTouch
Local i, j, k, x, y
Print #10, "o" Chr$(4);
For k = 1 To 8000
If Loc(10) = 4 Then
If Input$(4, #10) = Chr$(0)+Chr$(3)+Chr$(0)+Chr$(0) Then
Print #10, "o" Chr$(5);
For j = 1 To 8000
If Loc(10) = 4 Then
x = Asc(Input$(1, #10)) * 256 + Asc(Input$(1, #10))
y = Asc(Input$(1, #10)) * 256 + Asc(Input$(1, #10))
For i = 1 To 15
If x > LCDBut(i,1) And x < LCDBut(i,3) And y > LCDBut(i,2) And y < LCDBut(i,4) Then
If LCDBut(i, 0) = 2 Then
LCDBut(i, 0) = 1
If LCDBMsg$(i) <> "" Then LCDButton 0, LCDBut(i, 1), LCDBut(i, 2), LCDBMsg$(i)
LCDTouch = i
Exit Function
Next i
LCDTouch = 0
Exit Function
Next j
Error
Else
For i = 1 To 15
If LCDBut(i, 0) = 1 Then
LCDBut(i, 0) = 2
If LCDBMsg$(i) <> "" Then LCDButton 1, LCDBut(i, 1), LCDBut(i, 2), LCDBMsg$(i)
Next i
LCDTouch = 0
Exit Function
Next k
Error "LCD is not responding***"
End Function
' internal routines - user code should not call these routines
' used internally to draw a button
' user code should not call this sub
Sub LCDButton state, x, y, msg$, f, ct, cb
Local scale
If f = 0 Then f = 23
scale = f\10
f = f Mod 10
If ct = 0 Then ct = RGB(1,1,1)
If cb = 0 Then cb = RGB(0,0.5,0.5)
Print #10, "O" Chr$(0); : LCDGetAck
Print #10, "b" Chr$(state) LCDWords$(3, x, y, cb);
Print #10, Chr$(f) LCDWords$(1, ct) Chr$(scale) Chr$(scale);
Print #10, msg$ Chr$(0);
LCDGetAck
' used to get an acknowledgement from the LCD
Sub LCDGetAck
Local i
For i = 1 To 8000
x$ = Input$(1, #10)
If x$ = Chr$(6) Then Exit Sub
If x$ = Chr$(15) Then Error "LCD reported an error"
Next i
Error "LCD is not responding ack "
' send a series of bytes to the screen
Function LCDWords$(nbr, w1, w2, w3, w4, w5)
LCDWords$ = Chr$(w1\256) + Chr$(w1 And 255)
If nbr > 1 Then LCDWords$ = LCDWords$ + Chr$(w2\256) + Chr$(w2 And 255)
If nbr > 2 Then LCDWords$ = LCDWords$ + Chr$(w3\256) + Chr$(w3 And 255)
If nbr > 3 Then LCDWords$ = LCDWords$ + Chr$(w4\256) + Chr$(w4 And 255)
If nbr > 4 Then LCDWords$ = LCDWords$ + Chr$(w5\256) + Chr$(w5 And 255)
End Function
a bientot thierry
TC 72
Posted: 12:27am 14 Mar 2014
hello
as I said above I have problem of acquisition speed button.
I tried to change the speed of transfers between the display and the card but I did not arrive no result.
I first contact at 9600 baud ("u" command)
then I wrote
Print # 10, "Q" Chr $ (13) (cahangement speed at 115200
LCDGetAck
Close # 10
Open "com4: 115200" As # 10
so if Mr. GEOFF GRAHAM reads this line can be can he provided some solutions.
may be I am wrong in trying to change the exchange rate between screen and map, loss of time can be elsewhere.
thank you and see you soon
thierry
Posted: 01:40am 14 Mar 2014
No idea what you're asking or what your problem is as I cannot understand you.
But I think you need delimitters e.g. not
Print # 10, "Q" Chr$(13)
but
Print # 10, "Q";Chr$(13)
What it does without a ";" I don't know. A syntax error would be my choice!
TC 72
Posted: 02:49am 14 Mar 2014
hello john
thank you for a few moments to read price my request.
if you read the source code listed on another post you will notice that mr Geoff Graham wrote the comande to the display without delimiter.
Print # 10, "Y" Chr $ (5) Chr $ (0) 'enable the touchscreen
LCDGetAck
'Following he is only needed if the display is in portrait mode
Print # 10, "Y" Chr $ (4) $ Chr (1) 'rotate screen to landscape to portrait
LCDGetAck
I are therefore merely copying what have already been doing by changing only the commands.
for more information you must know the order of the display 4dsystem kind μlcd 32 PT.
thank you to you john.
has soon
thierry
Posted: 11:29am 14 Mar 2014
  TC 72 said  so if Mr. GEOFF GRAHAM reads this line can be can he provided some solutions.
Thierry, I cannot help you write your programs, especially if I cannot understand what you want. That code is a demo and it worked fine as it was, if you want to adapt it to do something else then you are welcome - but you need to do it yourself.
TC 72
Posted: 09:03am 15 Mar 2014
good evening
thank you for your note
I do not demand that you do the program my place, the specifications will be too long.
I appeal to your service because I know you know the display, and these control codes.
I turn around for a few days because I did not manage to change the speed of the serial line on the display.
why change the speed? because Touchscreen put 1- 1.5 second to play keys!!.
and over the last touches draw works in "autorepet" and I do not understand why.
I learn every day by reading on forums or basic old book.
but there are things I do not understand.
if you want to help me ... thank you in advance.
but thank you for this kind of demo program that helps a lot.
has soon
thierry
Posted: 01:32pm 15 Mar 2014
The Picasso chip is very slow anyway and that might be part of your problem with speed.
I don't have the display set up so I cannot test anything but, from memory, you change the speed of the serial interface using the Set new Baud Rate (51hex) command. For example:
Print #10, "Q" Chr$(13); ' change the Picasso interface to 115200
LCDGetAck ' wait for the acknowledgement
Close #10
Pause 500
Open "COM4:115200" As #10 ' re open the serial interface at the new speed
This assumes that you are using the Duinomite which has a hardware UART on COM4:.
I am not in a position to help you much because I do not have a test setup and it was a long time ago when I wrote that demo code.
TC 72
Posted: 10:55pm 15 Mar 2014
hello
geoff thank you for that information, I think what I wrote was ok except the break that I did not bet. I'll try this.
other questions:
there t there a way to empty the buffer reception without close command?
how t on the "loadlibrary" command uses? Have you an example INCORPORATING order?
see you soon and thank you for all
thierry
Posted: 11:29pm 15 Mar 2014
Yes, use this:
DO WHILE INPUT$(250, #10) <> "" : LOOP
I don't know of any examples. The LIBRARY command is easy to use... does anyone else have an example for Thierry ?
