Local Time 22:59 24 Oct 2026 Privacy Policy
Forum Index : Windmills : New V.A.W.T. design
Energy Creator
Posted: 03:34am 22 Nov 2012
Hello, its bin a long time.
Finely the wind direction scoops are mounted on the V.A.W.T.
Now we have to make the rotor and a cool generator what fits perfectly by the V.A.W.T.
I was building on a new generator design whit the same winding principle.
Only it will become a big ring.
A ring generator?
I don’t know when this project will be finished?
In 2 weeks I am going to Brazil for 6 months to create some energy systems in the middle of no ware on top of a mountain for generating energy for a few homes.
So, my next movies or updates will com from Brazil.
Brazil??.... Yeehaaa Party Time!!
electrondady1
Posted: 04:33am 22 Nov 2012
great work !
are you going to spin the coils or the magnets?
govertical
Posted: 04:36am 22 Nov 2012
Hi, congratulations and safe journey. What is the stator resistance?
Energy Creator
Posted: 08:48pm 27 Nov 2012
Hi, the coil ring stays stationary and the magnates are going to spin.
The rotor will come on the inside.
I don’t know the resistance, its already in the container for shipment….. forgot to measure??
But I have made a smaller one for testing!
It’s a Ring generator, diameter 45 cm , 6 phases 2,2 ohms a phase But connected to 3 phases with 4,4 ohms a phase.
Wire used 0,7mm
The coil is embedded in polyether.
I also embedded a temperature sensor for further testing.
I have made a quick test movie of the ring generator, its on YouTube.
Ring generator
I will try to make a descent test bench for descent testing before I’m of to Brazil.
Cheers to you all!
Brian
Energy Creator
govertical
Posted: 02:33am 28 Nov 2012
Edited by govertical 2012-11-29
electrondady1
Posted: 03:27am 28 Nov 2012
your ring stator is beautiful work Brian.
that's a very nice casting.
i have been planing one for this winter .
but it will be two phase with overlapping coils.
and a mag rotor on both the outside and inside.
consider winding a layer of silicone steel wire around the outside of your stator to give a flux return path
it should pull the flux through the copper.
Edited by electrondady1 2012-11-29
