Local Time 23:32 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM - can’t get USB working
Posted: 05:54am 15 Dec 2011
  BobD said   I just checked one of my laptops and it shows ports in use just like your machine. You're right. I think my machine is screwed.
Bob
Hmm, I think you mentioned you have previous backups of your system so make a current backup and try a clean install using the latest driver and nothing else... no virus scanners etc and see what happens..
BobD
Posted: 06:00am 15 Dec 2011
I think that will be the solution. I can't even think about it until I get back home next week and even then I'll have to get my head around the idea of doing a Windows install. If I do a minimal install and it works then I eventually have to do a full install. That is a non trivial task which is why I have good backups.
The final solution, if there is one, may be weeks away.
Bob
Posted: 06:04am 15 Dec 2011
  BobD said   Mick
Bob
I know, I posed it as a solution to see see if it is a hardware or a software fault...
If it works then it is software if it doesnt I would suggest something is screwy in your MB hardware,
regards,
BobD
Posted: 04:25pm 15 Dec 2011
my bet is a software problem as the machine has both usb2 and usb3 which are implemented on different hardware and both fail.Edited by BobD 2011-12-17
