Local Time 23:19 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (MM-DM-UBW32) The 3D Mite !
VK6MRG
Posted: 11:17pm 26 Nov 2011
I've just loaded the cube and ball files onto my Maximite. WOW, I love the cube! Top job.
Keith @
Posted: 03:46am 27 Nov 2011
Hi Guys
tried to run cube & ball programs and got the same error ...
DO without matching LOOP ... at line 20420
did a LIST and found the P in LOOP was missing on the last line 21080
Put a nil remark line after the LOOP ie 21090 '
All ok now .... good show ... ball is a bit slow ... cube has a couple of lines missing from time to time ... I'm impressed
Keith
The more we know, the more we know we don't know !
darthmite
Posted: 10:43am 27 Nov 2011
Hi [BKeith] ,
All lines are defined it's just that my back face algorithm remove
them because one part of the face is behind the cube or the ball.
Actually i just test what i can do with the MM.
I'm sure that some in the Shed have better solution for this issue.
Cheer.
trippyben
Posted: 07:02am 04 Dec 2011
I can't get either to work. Running V2.7B on an original Maxi with VGA.
The 3d cube stops with "Error line 20090: Invalid array dimension"
and the 3d Ball stops with "Error line 20290: No more DATA to read"
A quick look over the pasted in code and i can't see any errors in/around the line numbers identified.
Any ideas?
Ta.
Ben
Keith @
Posted: 08:37am 04 Dec 2011
Hey Ben
a simple query ... are you using the zipped files in the post from 27 Nov ?
Keith
trippyben
Posted: 09:48am 04 Dec 2011
I copied the code from the earlier posts - the 'condensed' versions.
Just downloaded the zip file, but the ball.bas and cube.bas files appear incomplete - they seem only to contain the object data?
Keith @
Posted: 10:18am 04 Dec 2011
Ben
sorry it's the code from the 26 Nov which has been posted into the message ...
I didn't open the files on the zip (I only had a look at the contents of the zip and saw the ball and cube .bas files in there. I have opened them now and you're right they're not the real mccoy.
the ball.bas makes up 7kb and the cube.bas makes up 4kb on my MM
As you can see there's not much in them .. a few double digit line numbers at the start with mostly data and then the program starting at 20000 thru to 21080.
Give em a whirl .. may need to add a blank remark at the end with 21090 ' or use these files.
2011-12-04_205817_ball-cube.zip
KeithEdited by Keith @ 2011-12-05
trippyben
Posted: 06:15am 05 Dec 2011
That's more better. Thanks Keith. Something must be corrupted in the copy/paste transfer from the listing in thos posts. Your zipped ones work straight up.
They do look good. Well done Darthmite.
Ben
darthmite
Posted: 03:31pm 05 Dec 2011
hi ,
I just think that Rhino made too much faces when i export the meshes.
A ''normal'' 3D Cube is 8 points and 12 faces when i make it with hand.
But if you use another 3D editor who export STL or PLY you can get better
result for sure.
Long time ago i have use the 3D Studio ASC files who give better result but
it was limited to 65535 Points/Faces due to the "old" 16bits systems
So now you have the 3D viewer for the MM , we just need the 1st 3D game
Cheer.
