Local Time 19:43 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error accessing SD card
brucepython
Posted: 09:16pm 29 Jun 2011
Sandisk Ultra II, 2 Gb, SD works fine.
I also have a mystery one called "LX series" 16 Gb, SDHC, Class 10. It's fine too, though it could be a while before the Maxi collects that much data.
donmck
Posted: 09:43pm 29 Jun 2011
  brucepython said   Sandisk Ultra II, 2 Gb, SD works fine.
Thanks Bruce, have also added:
http://www.themaximitecomputer.com/maximite-control/
Cheers Don...
https://www.dontronics.com
VK6MRG
Posted: 03:00am 30 Jun 2011
Maybe the problem with the SD cards is not the cards themselves but an issue with the Maximite. When I built the WIB, i had the same problems that some of you guys are having with the Maximite. It came down to the 3.3v regulator output voltage being slightly low. I changed the resister bias and to give me a voltage as close to 3.3v as possible. Some SD cards have a very fine voltage tolerance (window).
I just thought I'd share this experience with you in case it may help.
donmck
Posted: 04:10am 30 Jun 2011
  VK6MRG said   Maybe the problem with the SD cards is not the cards themselves but an issue with the Maximite. When I built the WIB, i had the same problems that some of you guys are having with the Maximite. It came down to the 3.3v regulator output voltage being slightly low. I changed the resister bias and to give me a voltage as close to 3.3v as possible. Some SD cards have a very fine voltage tolerance (window).
Good Lead, have added.
Cheers Don...
