Local Time 17:48 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Silicon Chip USB Datalogger Kit
     Page 2 of 3
norcold
Posted: 09:27pm 16 Apr 2012
Had believed USB cables could be no longer than 5m, until I came across an article that showed how to extend that limit. The cable can be much more than 15m too, they are built with a "booster"(little black box) in the middle of the cable. Also have my inverter plugged into the hub and computer has no trouble accessing both logger and inverter simultaneously.
The Western World cannot knock China, just tell them something cannot be done and they`ll do it, cheaper, easier and drama free. They are the world leaders whilst we are the Nero`s.
Vic
garthwimbush
Posted: 03:35am 24 Apr 2012
I manage to fix the post sleep problems, but I had to modify the firmware to do it. It seems that after the sleep, the oscillator was clocking at a slower rate, which matched what I was seeing. There may be a higher current draw now (I haven't checked), but at least it works. I have had it logging continuously for 24 hours without a hitch on battery alone. Does anyone here know of a kit forum where I could post the modified firmware? I note that Silicon Chip haven't got one, which is poor - their excuse is they can't afford the staff to moderate the forum, but it leaves kit builders in the dark after the build.
BobD
Posted: 06:10am 24 Apr 2012
Make it available here as a file for download and refer Sil Chip to this thread and send them a copy of the code. Put it out here first.
norcold
Posted: 07:29am 24 Apr 2012
I think this forum is probably as good as any, to leave the firmware update, from my googling there does not seem to be much interest in the datalogger. That is a shame as it seems to be quite capable, maybe those that have been built have been put aside because the kit builder has believed he has done something wrong as I believed initially. The firmware update will be most welcome by me, and as BobD suggests refer Sil Chip to this thread.
Many Thanks
Vic
Posted: 08:33am 24 Apr 2012
Post it here with some useful keywords so that google will (in time) find it and allow people who don't think of here still to find it :)
You could put it on github or sourceforge etc, of course.
Over time I suspect more and more will find it useful so take heart.
JohnEdited by JohnS 2012-04-25
garthwimbush
Posted: 09:09am 24 Apr 2012
OK, here is the updated firmware. No guarantees etc. I suggest you save your current image before uploading this one, in case it doesn't work for you.
I'm new to PIC's, so I will see if any of you have problems before I point SilChip here. The fix was specifically for oneWire for me, but it will probably fix any other time-critical functions as well. I have updated the version to 9.93. As noted previously, you may find that the idle current has gone up. I measured 780uA, which should get you up to a month and a half on 900mAh batteries, depending on your duty cycle. Incidentally, this seems to be about half of the 1.5mA stated in the documentation!
2012-04-24_185516_Data_Logger.zip
Posted: 02:07pm 24 Apr 2012
Oh. I didn't realise it would be only a HEX file.
garthwimbush
Posted: 10:03pm 24 Apr 2012
JohnS, the hex file was generated from the source - I'll put the source up on GitHub once I have done some more beta testing. Not sure of the code licensing though - I need to look into it before I put the code up.
Garth
laurief
Posted: 06:05pm 31 Jul 2012
I liked the look of the datalogger and got the last kit from Altronics - couldn't believe that more people didn't want one of these. Having the same problems with it going to sleep under battery, but I'm going to do some testing to see if an external supply can hold it up. I have downloaded, but haven't tried Garth's new firmware as yet. I did find an error in one of the sample scripts, so if you're trying them, don't assume they are 100% . Good to see a couple of others are using it too.
- Laurie
paradigm
Posted: 08:55am 12 Mar 2013
The USB Data Logger seems to be a most attractive design and I am very tempted to build one (it has subsequently been featured as a constructional project in the UK's Everyday Practical Electronics (EPE) Magazine, Dec 2012 to Feb 2013 issues).
However, judging from this thread, there seem to be a variety of issues with the design. May I ask if ANYONE here has succeeded in getting the unit to operate in accordance with its published features? The author of the articles has obviously devoted a great deal of time and effort into developing the design (which looks as if it might have been heading for production as a commercial unit).
I am a little puzzled why the author has not come back with updates/solutions to the evident issues. I wonder if we can expect any further updates e.g. to the software? I expect the author is 'uncontactable' and Silicon Chip/EPE are unlikely to be able to assist with technical queries, e.g. on the firmware. I suppose there can be no guarantee that a unit like this will be free from problems - which is a great pity.
In a situation like this it may unfortunately not be wise to construct the unit?
What do people have to say?
paradigm
CircuitGizmos
Posted: 09:08am 12 Mar 2013
I don't get the magazine that had the article in it, so I don't know the details of the data logger. A Maximite like the CGMMSTICK is small, has 20 I/O lines, and a micro SD. I would think it could be pressed into service as a datalogger quite easily. There is a lot more life to the maximites here at TBS.
norcold
Posted: 10:52am 12 Mar 2013
Mine runs OK whilst conx by usb to PC, seems to have a problem when run by internal battery. Did not try the updated firmware above as use it powered by usb. Like you I also wonder why the author didn`t follow up, with development believe it would have been a hot seller.
Vic
garthwimbush
Posted: 11:24am 12 Mar 2013
Mine appears to run almost perfectly, however, it needed the firmware update I posted earlier, and it seems to be really sensitive to the flash storage you use - most cards I tried ended up with corrupted files. I finally settled on a Verbatim 4Gb card, which has no problems. I have run it for 3 days continuously on batteries, taking 9 separate temperature readings every minute, and am very happy with the result. The only problem I have is that it stops logging of its own accord after 4 or 5 days, goes into sleep mode and has to be restarted.
paradigm
Posted: 02:10am 17 Mar 2013
Thanks to everybody for the replies which have inspired confidence to have a go at building this unit!
Looking at the PCB images (.pdf file) the maximum copper side appears to be the copper bottom. This must be the case in order for the surface mount regulator and card holder to position on their lands on the top side which has most of the tracks. However, this means that parts like the IC holder will have their solder joints on the bottom side and there will be no connection to the top-side tracks unless the holes are plated-through. I believe the boards available via the EPE magazine do not feature plated-through holes - in fact I read that the holes are all drilled to a uniform minimum diameter and will require to be opened up as necessary.
I do not immediately see how an IC holder can be used with this design and there will be problems with many of the other parts where leads will require to be soldered on both top and bottom layers. The photographs in the original articles show the IC in a holder. Maybe the earlier kit boards featured plated-through holes or employed inserted VIAs? Is anyone able to shed light on this?
Best regards, Alan
BobD
Posted: 06:51am 17 Mar 2013
Alan
Have a look at the attachment. I think it will answer the questions in the last line and provide a source for the PCB. Good luck.
Bob
2013-03-17_164344_Universal_USB_Data_Logger_PCB.pdf
edit
Just had a look at Jaycar and Altronics and the latter is still showing the kits. http://www.altronics.com.au/index.asp?area=item&id=K2572 As the link implies, the catalogue number is K2572.
ALTRONICS INTERNATIONAL ORDERS
174 Roe Street, Perth, Western Australia 6000
PO Box 8350, Perth Business Centre, Western Australia 6849
RETAIL
Telephone: +61 8 9428 2188
Fascimile: +61 8 9428 2187
Edited by BobD 2013-03-18
isochronic
Posted: 02:06pm 17 Mar 2013
An IC socket can be used with non-plated-through
boards: a socket is placed and left slightly clear
of the board so as to leave room for soldering
connections on the socket side.
Machined-pin sockets are best. It is easiest to
heat the pin and feed the solder wire through
underneath the socket.
Not exactly perfect I agree but it works ok.
paradigm
Posted: 10:40am 19 Mar 2013
Thanks for the useful information and suggestions. It is confirmed that the original board has plated-through holes but there seems to be a issue with the non-availability of the card socket which matches the board.
I am an experienced user of the Cadsoft Eagle PCB layout package and I have made a start to doing my own layout. I can incorporate a few alterations to suit my application, e.g. placing the USB socket horizontally and providing a facility to (re)program the PIC 18F27J53 in-circuit (ICSP). The board may be slightly larger but will not need plated-through holes. I originally wanted to save time and buy a board but I have changed my mind on this! Thanks to all.
Alan
Posted: 12:12pm 19 Mar 2013
Gday Alan,
Do you have any specs on the card socket you need?
paradigm
Posted: 12:36pm 20 Mar 2013
Hi Mick,
Thanks for your message. The articles in EPE Magazine only quote "Altronics P5722". However, the photos show a socket similar to the Multicomp part 412D02F-09PC0035V (Farnell 2226409) but I suspect the PCB may now require a different socket? I would have to make an Eagle part for the Multicomp part as I can't see an existing one anywhere. The alternative I was planning to use is the Wurth Elektronik part 693 063 020 911 (Farnell 2081361) and I have the Eagle part file for this (available from the Wurth website), although I do see an issue with it which I am raising with Wurth. The Farnell site has links to the specs for these sockets.
Thanks for your interest,
Alan
Posted: 01:31pm 20 Mar 2013
Hi Alan,
The Multicomp part looks a fair bit different size wise but the Wurth part is that close I don't think you would have to change anything to fit... the differences are fractions of a mm and I feel would fit perfectly on the existing foot print
Here is an overlay of the Wurth part and Altronics parts one in red the other blue and aligned on the location holes they are near perfect...
2013-03-20_233147_SD.pdf
Edited by bigmik 2013-03-21
     Page 2 of 3
