Local Time 01:24 25 Oct 2026 Privacy Policy
Forum Index : Windmills : homemade wind turbine 2 KW
SpitsFire
Posted: 10:46am 24 Jul 2011
  Khalid said   One of the best thread in this forum. Especially thanks for the AutoCad drawings. You have mentioned in another forum that you are using the magnet( neodimio 20x50 di grado 40 e 12 bobine).
energyalternative
whereas in this thread you wrote that you are using 30x50Grade 42 and.
As i am following your plans, i seek your help for clarification if possible. You also mentioned that you are using 48Volt system. May i consider your batteries are arranged in the manner storing 48 volts??.. Also please tell why you chose 48Volt system.
Hello Khalid, the thread that you mentioned refers to a previous implementation. While the current implementation is in this thread Energiaalternativa. . I chose a 48-volt system because I had the gift of a 48V battery pack and I economized on the size of electrical cables.
SpitsFire
IPSA SCIENTIA POTESTAS EST (bacone)
vawtwindy
Posted: 05:54am 25 Jul 2011
complimenti cara spitsfire
can you tell me how the furling works in it as attached in your .dwg extracted image?
usually i keep a small piece to tab for low end stop as attached.
Edited by vawtwindy 2011-07-26
SpitsFire
Posted: 07:13am 25 Jul 2011
  vawtwindy said   complimenti cara spitsfire
can you tell me how the furling works in it as attached in your .dwg extracted image? ......
Hi vawtwind, here are the pictures of the stationary jib furling.
SpitsFire
vawtwindy
Posted: 10:24am 25 Jul 2011
saluti , grazie per la condivisione delle informazioni
can you please share if you have more pictures.?
Rastus
Posted: 03:15pm 25 Jul 2011
Hi Spitsfire,
Very creative.You have introduced yourself with great Fanfare,and well deserved!The attention to detail you have included in making your mill certainly will pay dividends in the end result (how it makes power)Wether a small or large amount,it will be the best it can do.CONGRATULATIONS Cheers Rastus
SpitsFire
Posted: 05:48pm 26 Jul 2011
  vawtwindy said   saluti , grazie per la condivisione delle informazioni
I hope these pictures will have clarified the furling.
Good job.
SpitsFire
SpitsFire
Posted: 05:51pm 26 Jul 2011
  Rastus said   Hi Spitsfire,
Hi Rastus, thank you for the compliments. I'm very flattered.
SpitsFire
vawtwindy
Posted: 03:20am 27 Jul 2011
its pretty clear spitsfire, i was worrying about that tab, coz, many of the documents doesnt show much importance on that part
