Local Time 06:16 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Southern Cross mystery bung?
Greenbelt
Posted: 05:26am 07 Jan 2010
OZTULES SAYS;
"Here is the inner of the hub. 80% of it is hollowed out. You can see the ribs there. These keep the oil from the shaft rotating around the inside for reasons unknown. I suppose it does keep oil around which is good."
Apparently The plug is a drain plug.
Perhaps this will clear up some of the mystery.
an Interesting read.Oiling system
MacGyver
Posted: 05:49am 07 Jan 2010
I think what we're talking about is that little stand-alone plug on the piece to the left. Are we all on the same page?
Copeville, Texas
GWatPE
Posted: 06:24am 07 Jan 2010
I think oztules has summed it up.
From a mechanical aspect, the bung is most likely there to drain water from the self oiling mechanism without taking the machine apart.
The main rotor is connected to the pumping mechanism with a thin shaft. Oil that weeps out of the pumping crank case along the drive shaft provides lubrication to the main journal. There would be a lot of force from the fan that would be translated to the large journal during furling. The combination of 2 bearing systems provides low wind startup and high wind survivability.
The clearance between the fan rotor casting and the crank case casting should confirm this purpose.
Still good to see so much documentation is still around.
Gordon.
become more energy aware
oztules
Posted: 06:35am 07 Jan 2010
Yes.
That is a slightly different pump motor, but is essentially the same. It is interesting that they have the bung as well.
In the last photo, there is the oil outlet/inlet (mine is outlet only) with weep indent. There is a second indent just in front of that. That one is used to hold the bearing in place. If it is original, the bearing (white steel) is cast in situ, and line bored, so the white steel runs into the hole and that pins it. If you rebuild the bearing, then you use a grub screw into your bearing block to hold it.
...........oztulesEdited by oztules 2010-01-08
Posted: 06:37am 07 Jan 2010
Here's a couple of pics I took yesterday. The tower, which is now in 3 parts beside the house I'm renting, and the "motor" as they like to call it, cover removed. The hammer is there for scale, I didn't hit anything I swear.
Yes, its as heavy as it looks.
