Forum Index : Microcontroller and PC projects : Next project: Micropython on the Pico Computer 3 - progress reports
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12053 |
v0.7 firmwarev0.7.zip Manual Turtle graphics — a Turtle class (MMBasic TURTLE): movement/pen/heading, arcs, Béziers, circles, filled polygons, a state stack. Bitmap fonts — the full set of nine MMBasic fonts (8×12 up to 32×50). hdmi.text(s, x, y, fg, bg, scale, font), hdmi.fonts(), and Display.text(..., font=, scale=). GUI toolkit (pcgui) — the complete MMBasic GUI control set as Python objects: caption, frame, button, switch, checkbox, radio, LED, gauge, bar gauge, slider, text/number box, display box, spinner, list box, format box, and area. Driven by a USB mouse or touch panel, with an on-screen keyboard/keypad for touch text entry and global touch hooks (the GUI INTERRUPT TouchDown/TouchUp equivalent). Flicker-free incremental gauges/sliders. Tile maps (TileMap) — scrolling tile-map backgrounds with a fast C render loop (hdmi.tilemap), tile attributes and collision, and single-tile drawing (blit_tile). Ships with a Breakout game demo (tests/breakout.py) ported from MMBasic. File manager — fm() — a dual-panel file manager (MMBasic FM). Two panes side by side: Tab / ←→ switch panes, arrows navigate, Enter opens by type (.py runs, audio plays, images show, text views), and C copy / M move between the panes. Plus edit (pye), delete, rename, mkdir, and audio controls. Incremental redraw keeps it snappy; it restores the video mode after a program changes it. Plotting — plot() — one-call plotting on the screen for maths/science: a list, several series, or a function over a range; line / scatter / bar, autoscaled with axes and range labels. Game-loop timing — pcgame.Clock — a drift-free fixed-cadence frame clock (MMBasic SYNC): tick() holds an absolute deadline so animation runs at a steady rate with no drift, returns dt for frame-rate-independent motion, and tracks .fps (or vsync=True to lock to the display refresh). Maths helpers — pcmath — the MMBasic MATH verbs that ulab doesn't already cover: quaternions, 3-D vectors, DSP (window / sinc / crossings / power spectrum), correlation, chi-square, and a PID controller. (Statistics, linear algebra, FFT and complex are in ulab + cmath.) autosave("file") — capture what you paste or type at the console straight into a file (MMBasic AUTOSAVE) — the frictionless way to get a program onto the board with no XMODEM or SD-card shuffling. Ctrl-Z saves. Edited 2026-07-15 21:22 by matherp |
v0.8 firmwarev0.8.zip Manual New in v0.8 cls() — clear the console screen (MMBasic CLS). fm multi-select — Space selects several files (shown yellow, counted in the status line); C/M/D copy, move or delete the whole selection. Plus a guard: copying when both panes show the same directory is refused (it would have truncated the source). Readable tracebacks from run() — errors now report File "prog.py", line N instead of <string>. console("none") — no console output anywhere and no blinking cursor over full-screen graphics; input still works, console() restores. DS3231 daily alarm — ds3231.set_alarm(h, m), alarm_fired(), clear_alarm(), alarm_off(), alarm_pin() (INT wired to GP32). Survives resets — it lives in the battery-backed chip. pccursor — a visible mouse pointer (MMBasic GUI CURSOR): save-under sprite, ARROW/CROSS shapes; pcgui shows and refreshes it automatically when a mouse is present. Manual and development-notes updates throughout (auto-run, import paths, hardware alarm, cursor, plus a fix to the GUI skeleton example). |
v0.9 firmwarev0.9.zip Manual Coming tomorrow, fully functional PC emulator for Micropython on the Pico Computer 3 New in v0.9 3D engine — draw3d — MMBasic's DRAW3D ported as a module: quaternion-rotated polyhedra with backface culling, painter depth-sorting, per-face colours/fills/flags/lighting, and hidden-line rendering (depthmode=2, the z-buffer wireframe mode — the Elite look). Demos: tests/football.py (bouncing truncated icosahedron), tests/elite.py and tests/cobra.py (hidden-line wireframe ships). hdmi.RGB640_4 — 640×480 in 16 colours, the fast game mode: the 150 KB framebuffer is half the video SRAM, so hdmi.create()'s off-screen F buffer takes the other half. Double-buffered 3D now runs faster than MMBasic on the same hardware. RGB320 fast double-buffering — hdmi.create() called before hdmi.layer() claims the second half of video SRAM for the F buffer (first come, first served; layer() then errors until close("F"); call layer() first and both coexist as before). Turtle pattern fills — t.fillpattern(0..31) (fp), MMBasic's 32 8×8 fill patterns, plus a fix for the speckled border artefact on filled shapes; hdmi.polyfill() exposes the scanline pattern fill to everything else. pcmath.AHRS — Mahony and Madgwick sensor fusion (MMBasic MATH verbatim) for IMU work: feed gyro/accel (/mag), get quaternion or Euler angles. Overclock flash fix — screen(..., 315) / screen(..., 378) no longer hard-hangs: the post-write XIP re-entry now respects the flash's limits at every supported CPU clock (PICO_FLASH_SPI_CLKDIV=4, MMBasic's setting). 4-bpp modes corrected — all C drawing paths now share framebuf's GS4_HMSB nibble order; RGB1024 text and graphics render with columns the right way round. Console robustness — Ctrl-C during a dupterm write no longer kills the screen console; run() always restores drawing (and the console) to the visible display when a program ends, however it ends — no more "dead REPL" after interrupting a double-buffered program. Performance — the 3D engine and drawing core use single-precision hardware FPU arithmetic and horizontal-span fills throughout (MMBasic parity). pye editor sizing — the editor takes its screen size from the active console, fixing the bottom line in RGB320. Manual and development notes updated throughout. Edited 2026-07-18 07:07 by matherp |
| okwatts Regular Member Joined: 27/09/2022 Location: CanadaPosts: 88 |
Deleted operator error! Edited 2026-07-18 09:00 by okwatts |
V0.10 is now available Manual New in v0.10 On-device SQLite — import usqlite — a full SQLite 3.47 database engine is now built into the firmware. usqlite.connect("/data.db") gives you real SQL — tables, indexes, transactions, parameterised queries and cursors — with the database an ordinary file on the flash disk (/) or SD card (/sd) that survives a power-cycle. SQLite runs in the board's 8 MB PSRAM heap, so non-trivial queries are practical. Hardware-tested (create/insert/select, REAL round-trip, persistence across reconnect). The PC emulator has it too, so import usqlite behaves identically there. See User Manual §17. Simple test program for sql import usqlite, os DB = "/sqltest.db" try: os.remove(DB) except OSError: pass print("VER", usqlite.sqlite_version) con = usqlite.connect(DB) # executemany() usqlite-style: one multi-statement string, no params con.executemany( "BEGIN TRANSACTION;" "CREATE TABLE readings(id INTEGER PRIMARY KEY, name TEXT, temp REAL);" "COMMIT;") # parameterized execute() -> exercises the patched float bind path (REAL param) for name, temp in (("alice", 3.14), ("bob", 2.71), ("carol", 42.0)): con.execute("INSERT INTO readings(name, temp) VALUES (?, ?)", (name, temp)) with con.execute("SELECT id, name, temp FROM readings ORDER BY id") as cur: for row in cur: print("ROW", row[0], row[1], row[2]) with con.execute("SELECT COUNT(*), SUM(temp) FROM readings") as cur: r = list(cur)[0] n, total = r[0], r[1] print("AGG", n, total) con.close() # reopen -> proves on-disk persistence + a float parameter in WHERE con2 = usqlite.connect(DB) names = [] with con2.execute("SELECT name FROM readings WHERE temp > ? ORDER BY name", (3.0,)) as cur: for row in cur: names.append(row[0]) con2.close() print("FILTER", names) ok = (usqlite.sqlite_version == "3.47.0" and n == 3 and abs(total - 47.85) < 1e-6 and names == ["alice", "carol"]) print("PEAK", usqlite.mem_peak()) print("RESULT", "PASS" if ok else "FAIL") USB gamepad — gamepad() — plug a USB game controller into the host port and read it like MMBasic's DEVICE(GAMEPAD): gamepad("LX"/"LY"/"RX"/"RY") analog sticks, gamepad("B") button bitmap (test with & gamepad.A, gamepad.START, …), gamepad("H") d-pad/hat, the analog triggers, and the PS4 gyroscope/accelerometer. Xbox, PlayStation 3/4 and a table of common generic HID pads decode out of the box; gamepad.configure() teaches it an unrecognised controller (gamepad.monitor() helps discover one). Hardware-tested with a generic pad and a DualShock 3. USB serial (CDC host) — USBSerial — a USB-serial adapter (FTDI, CP2102, CH340, or a native-USB device such as an Arduino) plugged into the host port becomes a UART-like object: exactly the read/readline/readinto/write/flush/any of machine.UART, plus connected() and on_change() for hot-plug. Up to four at once. Hardware-tested round-trip against a second RP2 running MMBasic. hdmi.RGB320_8 — 320×240 in 256 colours, pixel-doubled to 640×480. One buffer is only a quarter of the video SRAM, so the display, the overlay layer and the off-screen create() buffer all fit in fast SRAM at once — the only mode offering an overlay and a fast double buffer together. Wi-Fi password security — the saved Wi-Fi password is now scrambled and tied to this specific board (not readable at a glance in settings.json, and useless if copied to another board), and wifi("SSID", "pw", save=False) connects without saving it. Fixes — a composite keyboard's extra HID interface (e.g. the Raspberry Pi keyboard's media keys) no longer shows up as a phantom gamepad; RGB640_4 vsync timing; the cosmetic hardware/powman.h build error on RP2350; and the emulator now builds cleanly from a fresh clone. Built against pico-sdk 2.3.0 with an upstream MicroPython sync. Manual and development notes updated throughout. Edited 2026-07-22 20:15 by matherp |
Terrific. Does this wipe the flash drive? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Hi Peter Do you accept the following python syntax on the pico 3? from aw.engine import Engine where aw is a directory, engine is a engine.py file and Engine is a class I could not find anything regarding that in the book. I'm using the pc emulator on linux Edited 2026-07-22 23:40 by LeoNicolas |
AFAIK You can't specify a directory in the import command. To use a non-standard directory you need to include it in the path import sys sys.path.append('/path/to/your/dir') |
Thank you Peter I'm learning the differences between Python and MicroPython. We always should reference the MicroPython documentation. From the MicroPython documentation: MicroPython doesn’t support namespace packages split across filesystem. Cause: MicroPython’s import system is highly optimized for simplicity, minimal memory usage, and minimal filesystem search overhead. Workaround: Don’t install modules belonging to the same namespace package in different directories. For MicroPython, it’s recommended to have at most 3-component module search paths: for your current application, per-user (writable), system-wide (non-writable). |
To answer my question: flashing this new firmware doesn't wipe the flash drive. (As the manual says, but I hadn't gotten that far.) ~ Edited 2026-07-23 01:10 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| scruss Senior Member Joined: 20/09/2021 Location: CanadaPosts: 116 |
It doesn't, but I'd still recommend a backup of your board's filesystem first. Talking of that, (and this is in Peter's manual now): the /flash filesystem is case sensitive. The SD card filesystem is not (it's plain old FAT) Edited 2026-07-23 07:13 by scruss |
Per Claude: flash_backup.zip PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I can smell a SQLite |
Might be |
Quick question on MATH.PID: I see it is implemented but in the notes, I don't see the LPF parameter(?) And is it still limited to 1ms? |
Ah-ha found it: |
v0.11 is now available at https://github.com/UKTailwind/micropython/releases/tag/v0.11 lizby: this has been tested with your test program and works perfectly both with the emulator and the real firmware (both flash and sd) |
Peter Are these changes being pushed to the pico 3 pc emulator? If yes, I will pull the last changes from the repo and compile it |
