Local Time 21:22 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bubble universe on steroids
Bleep
Posted: 06:00pm 20 Jun 2026
  Quote  The next step is to improve the whole csub architecture to make writing them a bit easier. There will be a python script to generate a csub direct from the c source.
Hi Peter,
this sounds very interesting to me, I've often thought, a CSub here, would speed this up dramatically, but when I've looked at how it's all done, eventually gave up. :-( So being able to write a CSub in C, and get it all correctly formatted etc. to use as a CSub would be great. :-)
I'll look forward to trying it out.
Regards Kevin.
PS. I have tested it and sure enought it runa at over 42Hz screen refreshes! or nearly 44Hz with Trace Cache, which now makes very little difference compaired to the massive gain of using assembled C in the tight loop.
Edited 2026-06-21 04:37 by Bleep
Posted: 06:49pm 20 Jun 2026
Try this version in mode 2 (or mode 5) with OPTION RESOLUTION 378 on rc22 just posted
' bubble.bas - "bubble universe" demo driven by the bubblerow CSUB (bubble.c).
' The CSUB does the sin/cos recurrence + scale + offset for one row (66 points),
' returning integer screen coordinates in c() and d().
' Regenerate the CSUB block below with:
'   python armcfgen.py bubble.c --compile -n bubblerow -e bubblerow -O s -I <firmware dir>
Option tracecache on
Font 7
FRAMEBUFFER create
FRAMEBUFFER write f
Dim Float t,pf(15)              ' pf: 0=i 1=b 2=v 3=x 4=pi/2 5=xs 6=ys 7=xc 8=yc
Dim Integer c(65),d(65),n(65),m(32,195),nn   ' m: 196 palette rows (one per i step)
Dim Integer a,g,i,j,xc,yc,xs,ys
Const r=(2*Pi)/235,k=255,s=50
CLS RGB(black)
t=Rnd*10
nn=Peek(varaddr n())
' centre and scale factor
xc=MM.HRES\2:yc=MM.VRES\2
xs=MM.HRES/4.2:ys=MM.VRES/4.0  ' Oval
pf(2)=0:pf(3)=0:pf(4)=Pi/2     ' v=0, x=0, half-pi
pf(5)=xs:pf(6)=ys:pf(7)=xc:pf(8)=yc
' build the colour palette, packed 32-bit into m()
For a=0 To 195
For g=0 To 65
 If a<18 And g<18 Then
  n(g)=RGB(0,255,0)
 Else
  n(g)=RGB(a*1.3,g*3.93,128*(a+g<65))
Next 'g
Memory pack nn,Peek(varaddr m(0,a)),66,32
Next 'a
CLS
Inc t,0.035:g=0:Print Timer:Timer =0
For i=60 To 255 Step 1                       ' Step 1 = densest; raise to 2/3 for fewer points
 pf(0)=i:pf(1)=r*i+t
 bubblerow c(),d(),pf()                     ' recurrence + scale + offset (in C)
 Memory unpack Peek(varaddr m(0,g)),nn,66,32
 Pixel c(),d(),n()
 Inc g
Next 'i
FRAMEBUFFER copy f,n
CSub bubblerow INTEGER, INTEGER, FLOAT
 00000000
 0014B5F0 68126853 920CB09B 68A2930D 920E68E3 6922930F 92026963 69A29303
 920469E3 6A229305 92066A63 6AA29307 92106AE3 6B229311 92126B63 6BA29313
 92146BE3 6C229315 92166C63 23009317 91199018 4D519301 990D980C 69DB682B
 681E33A4 9B039A02 682B47B0 69DB0006 3390000F 4798681B 9008682B 69DB9109
 001A0030 681B33A4 469C3290 46666812 92020039 9B079A06 9B0247B0 682B4798
 91039002 99059804 339069DB 4798681B 900A682B 9804910B 69DB9905 33A4001A
 68163290 9A06681F 47B89B07 682B47B0 91059004 99099808 33A469DB 9A0A681E
 47B09B0B 9008682B 98029109 69DB9903 681E33A4 9B059A04 682B47B0 91039002
 99099808 33A469DB 9A0E681E 47B09B0F 9004682B 98089105 69DB9909 3288001A
 920A6812 33A0001A 681632A4 9A10681F 47B89B11 9B159A14 9B0A47B0 9A014798
 189B9B18 60596018 99039802 69DB682B 33A0001A 68153288 681F69D6 9B139A12
 9A1647B8 47B09B17 9A0147A8 189B9B19 60596018 22840013 93013308 42930092
 E768D000 9A022000 21009B03 61636122 9B059A04 61E361A2 BDF0B01B E000ED08
End CSub
/* bubble.c - "bubble universe" inner loop as a PicoMite CSUB.
* One frame row (66 points): the sin/cos recurrence + scale + offset, producing
* integer screen coordinates in c() and d(). Moving this out of the BASIC
* interpreter took the demo from 233 ms/frame to ~23 ms.
* Build (compute-heavy -> ask for -Os; -I points at PicoCFunctions.h):
*     python armcfgen.py bubble.c --compile -n bubblerow -e bubblerow -O s -I <firmware dir>
* Call from BASIC:
*     CSUB bubblerow INTEGER, INTEGER, FLOAT      ' c(), d(), pf()
*     pf(0)=i : pf(1)=r*i+t
*     bubblerow c(), d(), pf()
* pf(): 0=iang(i)  1=b(r*i+t)  2=v(state)  3=x(state)  4=pi/2
*       5=xs  6=ys  7=xc  8=yc      (v,x persist in pf(2)/pf(3) across calls)
* Uses PicoCFunctions.h: all double maths goes through the firmware CallTable
* (Sine/FAdd/FMul/FloatToInt), which the header locates at runtime via VTOR - so
* no CallTable argument and no chip-/build-specific address, one blob for every
* variant and both chips. (The per-call base re-read the wrappers do is lost in
* the noise here - the software Sine calls dominate.)
#include "PicoCFunctions.h"
long long bubblerow(long long *c, long long *d, double *pf)
   double iang = pf[0], b = pf[1], v = pf[2], x = pf[3], hp = pf[4];
   double xs = pf[5], ys = pf[6], xc = pf[7], yc = pf[8];
   int j;
   for (j = 0; j < 66; j++) {
       double A   = FAdd(iang, v);
       double siv = Sine(A);
       double civ = Sine(FAdd(A, hp));     /* cos(i+v) = sin(i+v + pi/2) */
       double sx  = Sine(x);
       double cx  = Sine(FAdd(x, hp));     /* cos(x) */
       double uu  = FAdd(siv, sx);
       v = FAdd(civ, cx);
       x = FAdd(uu, b);
       c[j] = FloatToInt(FAdd(FMul(uu, xs), xc));
       d[j] = FloatToInt(FAdd(FMul(v,  ys), yc));
   pf[2] = v;
   pf[3] = x;
   return 0;
Bleep
Posted: 08:28pm 20 Jun 2026
That's a huge number of Pixies in 70mS nearly 13000, or 186400 per second!!!
Thats not just plotting them, but doing 4 Sin calculations, & a few other 'simple' adds. Not bad for a £3 micro controler.
toml_12953
Posted: 08:48pm 20 Jun 2026
Here's a video of Bubble Universe running on PicoCalc. I, too, had to comment out the memory pack statements.
PicoCalc Bubble Universe
Edited 2026-06-21 06:49 by toml_12953
Posted: 07:14am 21 Jun 2026
  Quote  I, too, had to comment out the memory pack statements.
What firmware, what release, your build or mine? This is really bad as it suggests the linker is ignoring the alignment instruction
Posted: 08:17am 21 Jun 2026
The first version runs well on a RP2040.
> run  "bubble universe 06-2026 v1.bas"
529175.835
179.787
179.632
179.611
Another data point for v2.
Saved 2591 bytes
> RUN
[14] Dim Integer c(65),d(65),n(65),m(32,195),nn   ' m: 196 palette rows (one per i step)
Error : Not enough Heap memory
> option list
PicoMite MMBasic RP2040 V6.03.00RC22
Edited 2026-06-21 18:20 by phil99
Posted: 08:52am 21 Jun 2026
The V2 result is just a simple lack of ram on the rp2040. Not related to the alignment issue
toml_12953
Posted: 10:45am 21 Jun 2026
I used WebMite RP2350B V6.03.00RC22 (tried on both your build and mine) on a PicoCalc with a Pimoroni Pico2W Plus.
Posted: 10:50am 21 Jun 2026
Please list the exact full option list you are using and the exact version of the bubble program and try this
WebMiteRP2350V6.03.00RC23.zip
Edited 2026-06-21 21:12 by matherp
toml_12953
Posted: 01:23pm 21 Jun 2026
  matherp said  Please list the exact full option list you are using and the exact version of the bubble program and try this
Option List:
WebMite MMBasic RP2350B Edition V6.03.00RC22
OPTION SERIAL CONSOLE COM1,GP0,GP1,BOTH
OPTION SYSTEM I2C GP6,GP7, SLOW
OPTION BAUDRATE 19200
OPTION FLASH SIZE 16777216
OPTION LIBRARY_FLASH_SIZE  40000
OPTION COLOURCODE ON
OPTION CASE UPPER
OPTION TAB 8
OPTION DEFAULT COLOURS GREEN, BLACK
OPTION KEYBOARD PICOCALC
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION CPUSPEED (KHz) 384000
OPTION LCDPANEL CONSOLE ,, FF00
OPTION DISPLAY 26, 40
OPTION LCDPANEL ST7365P, PORTRAIT,GP14,GP15,GP13
OPTION BACKLIGHT LCD 96
OPTION WIFI MySpectrumWiFie0-2G, **************, PicoCalc-1
OPTION TELNET CONSOLE ON
OPTION GUI CONTROLS 50
OPTION SDCARD GP17, GP18, GP19, GP16
OPTION AUDIO GP26,GP27', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM PicoCalc
OPTION PSRAM PIN GP47
Libraries:
OPTION console none
ON ERROR SKIP 2
CONST TRUE = -1
CONST FALSE = 0
SETPIN GP4,GP5,COM2
OPTION console screen
SUB MM.STARTUP
OPTION console none
DRIVE "B:"
END SUB
SUB MM.END
PRINT
PRINT
PRINT "END PROGRAM"
PRINT
END SUB
SUB mm.prompt
SETPIN GP4,GP5,COM2
PRINT ">";
END SUB
SUB LLIST(fname$)
FONT 8
OPTION console serial
IF fname$="" THEN
LIST all
ELSE
LIST all fname$
END IF
PRINT :PRINT :PRINT :PRINT :PRINT
PRINT :PRINT
FONT 1
END SUB
SUB BEEP()
PLAY tone 1000,1000:PAUSE 175
PLAY stop
END SUB
FUNCTION DET(n())
DET=MATH(m_determinant n())
END FUNCTION
Edited 2026-06-21 23:24 by toml_12953
Posted: 01:34pm 21 Jun 2026
Please delete the library and OPTION RESET PICOCALC. Does the problem then go away? If it does slowly add changes back to identify what causes the problem.
toml_12953
Posted: 07:30pm 21 Jun 2026
It works! It also has more colors than before. Thank you!
Sorry it took so long to get back to you. Father's Day, ya know.
I did find that OPTION GUI CONTROLS 50 caused the problem. Once I set that to 0, the program ran fine.
Edited 2026-06-22 06:03 by toml_12953
Posted: 09:31pm 21 Jun 2026
I've found the problem with the alignment issue. Caused by picking the wrong number of OPTION GUI CONTROLS. Will post a fix tomorrow
