Forum Index : Microcontroller and PC projects : PicoMite Firmware Release Version 6.01.00
I'm still not getting it. Still getting parameter errors. I've tried both with and without quotes around the star name. Could someone provide a single line example? |
' DIM FLOAT lat = -41.12545, long = 145.90739 DIM FLOAT alt1,az1, ra_out1, dec_out1 DIM FLOAT alt2,az2, ra_out2, dec_out2 DIM mystar$ = "Acrux" DIM testTime$ = DATETIME$(NOW()) PRINT testtime$ location testtime$,lat,lon astro Rigel alt1,az1 , ra_out1, dec_out1 PRINT alt1,az1, ra_out1, dec_out1 astro Betelgeuse alt2,az2 , ra_out2, dec_out2 PRINT alt2,az2, ra_out2, dec_out2 I couldn't get a result for object names that contain spaces. It looks like the object has to be hard coded. Perhaps "EXECUTE" to the rescue? Jim Footnote added 2025-12-20 14:52 by TassyJim Yes EXECUTE does allow you to have the star ina variable but still no joy with multi-word stars. DIM mystar$ = "Acrux" mystarcmd$ = "astro "+mystar$+" alt2,az2 , ra_out2, dec_out2" EXECUTE mystarcmd$ PRINT alt2,az2, ra_out2, dec_out2 VK7JH MMedit |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12057 |
The multi-word issue is a bug. I'll do a fix and maybe update the firmware if anything else crops up |
I'm still getting an error: 20-12-2025 03:52:54 [10] Astro Rigel alt1,az1 , ra_out1, dec_out1 Error : Argument count It must be something unique to my setup. |
I suspect you are still running the old software. Download fresh from Geoff, make sure you clear any caches |
could someone please post what the latest date/timestamp of the most recently changed file in the zip file is. Just to make shure, I've managed to clean the cashes and got the most recent version. And I would suggest to have some kind of marking of the different bugfixes of an official release. Maybe V6.01.00RC0.x. Not neccessarily in the firmware itself, but to distinquish between the bugfixes when handling them on the local computer. If it would be also in the zip filename, things would be clear and everybody would have a handle in the discussions to name exactly what he/she is writing about. Thanks, Gerald 73 de OE1HGA, Gerald |
The current .uf2 timestamps are 19/12/2025 00:49 to 00:59 |
thanks, so I'm up to date ![]() 73 de OE1HGA, Gerald |
I suspect you are still running the old software. Download fresh from Geoff, make sure you clear any caches There is some disconnect between the uf2 files on Geoff's site and UKTailwind's source. Yes, I have cleared the cache before downloading the source. When I run the precompiled uf2, it runs fine. When I compile the source I get this: PicoMite MMBasic RP2350B V6.01.00 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather Total of 6 Mbytes PSRAM available > run 01-01-2024 00:00:08 0 263.5669684 0 0 0 263.5669684 0 0 Edited 2025-12-21 14:40 by toml_12953 |
In this post it appears the array version of KEYPAD is missing from the current firmware. Footnote added 2026-01-13 09:20 by phil99 To use large keypads on the RP2040 see this thread |
Has help.txt ever been updated for 6.01.00? If so, where can I find it now? |
RP2350 only, manual should say this. In order to keep the image size small and give disk space on a 2Mb flash Pico I have to leave out some things on the RP2350. |
A lot of confusion here. You say "RP2350 only" then "I have to leave out some things on the RP2350". So, is the command for the RP2350 or RP2040 or both? Is the command syntax: KEYPAD keymapmap!(),var!,int, startcolpin, nocols, startrowpin, norows or KEYPAD keyret, myint, gp1, gp2, gp3, gp4, gp5, etc and in the latter, how do you specify the keymap and rows/columns? Some guidance is needed. Geoff Graham - http://geoffg.net |
RP2350 only, manual should say this. In order to keep the image size small and give disk space on a 2Mb flash Pico I have to leave out some things on the RP2350. Which ones are they? Regards Michael BTW, `DrawPixel(a,b,c)` is in `PicoCFunctions.h` (v2.0.2 Makros) but not in the `CallTable` (`picomite.c`). It would also be nice to have `GetPixel()` and a positioning method for the graphical cursor (`CurrentX`, `CurrentY`) for outputting printable characters (MMPrintString) ... and ClearScreen(gui_bcolour)? |
The RP2350 firmware supports both KEYPAD syntax variants. The RP2040 only the original. The only thing wrong with the manual is the the new variant should have had "RP2350 only" specified at the top of the manual entry. For the RP2350, the firmware distinguishes between the two variants based on the number of parameters to the command. AFAIK any other commands that are RP2350 only are already identified in the manual. |
Thanks to all who got the fixed GPS.c over to UKTailwind. Now astro works perfectly. |
If you didn't chase every minor update in github until I release changes on this site you wouldn't waste so much time. Github is just a filedump. Unless I update the readme then the code should be considered not to have changed |
The firmware on my website has been updated with Peter's latest. Changes include: - Fixed the star catalog in the Astronomical Commands - Updated the Astronomical Commands documentation - Updated PicoMite User Manual (now revision 4) - Added "RP2350 ONLY" to the new KEYPAD command Download from https://geoffg.net/picomite.html (scroll to the bottom of the page). WARNING: Loading this will erase the flash memory. Geoff Geoff Graham - http://geoffg.net |
6.01.00 has a undocumented feature that someone may be interested in. MMBasic has long had the ability to decode GPS input using OPEN "COMn:baudrate" as GPS. This sets up a background interrupt listener and decodes the GPS signal which can then be interrogated using the GPS function. This all works great but has the disadvantage that any error, ctrl-C, etc. terminates the GPS input and you then need to go through the setup of the pins again and re-open the channel. In V6.01.00 you can use OPTION GPS comnTXpin,comnRXpin e.g. OPTION GPS GP0,GP1 This sets up the pins on reboot to always background monitor the GPS on the specified pins so you can then use the GPS function with no other set up needed and the GPS decoder and parser continues to run regardless of errors etc. Perfect for a bike/boat computer or car speed warning device (also for the STAR command to drive a telescope which is why I included it ) |
There are problems with PicoMite MMBasic USB RP2040 Edition V6.01.00 regarding the option serial console GP8 and GP9. The connection is disrupted with the output to the Tera-Term terminal. I also tested with OPTION SERIAL CONSOLE GP0 and GP1, and the same issue occurs. Test with PicoMite MMBasic USB RP2040 Edition V6.01.00RC25, and both serial connections work fine. However, I noticed that the list of pins for OPTION SERIAL CONSOLE COM1, GP0, and GP1 shows strange information. By "disrupted," I mean that the output to the terminal displays strange characters, which strongly resembles an incorrect baud rate. Have a wonderful holiday. > List pins GP0 1 Boot Reserved: SSD RESET GP1 2 Boot Reserved: CONSOLE RX GP2 4 OFF GP3 5 OFF GP4 6 OFF GP5 7 OFF GP6 9 OFF GP7 10 OFF GP8 11 OFF GP9 12 OFF GP10 14 OFF ..... Kind regards, Jan. Edited 2025-12-26 09:00 by JanVolk |
