Local Time 18:25 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 V6.00.00 beta9 Onwards
PhenixRising
Posted: 11:42am 24 Feb 2026
  PeteCotton said  Wow! I've just been looking over the changes. You've done an incredible amount of work. Thank you - it is very much appreciated.
X 1000
Many, many thanks, Gerry. Rushing over to test this right now.
PhenixRising
Posted: 02:43pm 24 Feb 2026
VAR SAVE/RESTORE working perfectly
In b11, booting to a prompt, the SD-busy LED would remain ON until I addressed the SD. Now it is off in b12
Loving the CMM2
Thanks again
Edit: Correction, I had somehow pushed the LED away from the window. It still remains ON until I do something like "FILES"
Not a problem, just FYI.
Edited 2026-02-25 00:47 by PhenixRising
Posted: 03:31pm 24 Feb 2026
  Quote  The red LED will also illuminate when a USB
keyboard is plugged in and successfully communicates with MMBasic – it then reverts to normal activity on
the first read/write to the SD card.
PhenixRising
Posted: 01:58pm 05 Mar 2026
Moved from separate thread (my bad)
Is it supposed to work with SPRITE SHOW?
MODE 11,16,0,frameint
'left setup code out for clarity
fi%=0
do:loop while fi%=0
SPRITE SHOW 1,50,50,0
Sub frameint
fi%=1
End sub
I get screen flicker for both SHOW and HIDE.
Update: No flicker in MODE 9,16
PhenixRising
Posted: 08:49pm 05 Mar 2026
In the editor:
SPRITE NEXT is fully colour coded
SPRITE HIDE/SHOW: HIDE/SHOW remain white
disco4now
Posted: 10:02pm 05 Mar 2026
  PhenixRising said  In the editor:
You have been spoiled by MMEdit!
The CMM2 editor knows the keywords/commands.
SPRITE NEXT is white because NEXT is a keyword in its own right.
If SHOW and HIDE are added they would be white where ever they appear.
I will have to see how many others fall into same category and think about it.
Short answer I don't know never played with it.
Can you post some working code in the original thread.
Maybe you need PAGE COPY?
The PAGE COPY command is very highly optimised to run as fast as possible. It also has an optional parameter which
is documented in the user manual.
I: means do the copy immediately. It is the default and most efficient but risks causing screen artefacts;
B: means wait until the next frame blanking and then do the copy. It is the least efficient but is absolutely
determinate in its effect and no screen artefacts will ever be seen; and
D: means carry on processing the next command and do the copy in the background when the next frame
blanking occurs. This is efficient but must be used with care as subsequent drawing commands may or may
not be included in the copy depending on the timing of the next screen blanking.
Edited 2026-03-06 08:24 by disco4now
F4 H7FotSF4xGT
PhenixRising
Posted: 10:51pm 05 Mar 2026
Hi Gerry, PAGE COPY was always my plan but I'm currently on G1 and don't have that option for mode 11. The flicker won't be a problem for me, the report was just an FYI.
Man, I'm loving the SPRITE stuff. I always associated sprites with games and so I skipped over but heck no. These work for pop-up menus, buttons, etc. Fantastic stuff
mclout999
Posted: 10:36am 04 Apr 2026
I was wondering. What was happening with the CMM2 version?
disco4now
Posted: 01:09am 02 Oct 2026
CMM2 V6.00.00 Beta14 Update
The CMM2_Beta.zip download package on Geoff's website is now updated with Beta14.
CMM 6.00.00 CMM2_Beta.zip
Fixes Flash Not Erased error when binary copy of Font, CSub or CFunction pushes
program to next 128K flash segement. Introduced at conversion to 16bit command tokens.
Fixes Font7 % character being displayed mirrored.
LOAD BMP now uses BmpDecoder.c from picomites in lieu of previous MS version.
  Dithering is not supported.
  The new decoder supports these BMP files:
  1-bit (monochrome) - 2 colors with palette
  4-bit - 16 colors with palette
  8-bit - 256 colors with palette
  16-bit - typically 5-5-5 RGB or 5-6-5 RGB
  24-bit - 8-8-8 RGB (true color, most common)
  BI_RGB (0) - uncompressed (most common)
  BI_RLE8 (1) - 8-bit run-length encoding
  BI_RLE4 (2) - 4-bit run-length encoding
MM.VER now returns a value to show release candidates as for latest Picomite.
 i.e. V6.00.00.xx where xx is 00-49 for Beta releases.
                       xx is 50-99 for RC releases.
MATH CRC12 function corrected to return 12bit result. (was incorrectly 16)
MATH(CROSSING function Bug fix from Picomite.
Previous notes from Beta13
CMM2 V6.00.00 Beta13 Update
HELP command alternative used at the command line if file a:/help.txt exists otherwise the CMM2 inbuilt help is used. The Editor still uses the inbuilt help.
help.txt has same structure as Picomites.
Fixed bug in MSGBOX function introduced on conversion to 16bit command tokens.
Fix issue where an explicit END command was required at the end of a program when OPTION AUTORUN ON was used.
Fixes two bugs in structures as per Picomite 6.02.01RC8
Fix bug in MEMORY INPUT when length is greater than 8, MEMORY INPUT fails with an End of File error.   see here
Fix to prevent HEX$( , BIN$( and OCT$( being replaced when part of a function name.
Function POS returned. Was temporarily changed to MM.POS in Beta11.
F4 H7FotSF4xGT
