Local Time 07:43 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I've found an interesting module for I2C
scruss
Posted: 09:15pm 04 Aug 2025
  Mixtel90 said  ... Confusingly, there are two "standards" (Qwiic and Stemma QT) that use I2C on the same 1mm pitch JST connector but with different coloured wires.
At least Qwiic and Stemma QT use the same pinout. Wemos/LOLIN have been producing boards with a JST 1 mm I²C connector for years (possibly at least as long as SparkFun's Qwiic) and it has SDA/CLK swapped w.r.t. Qwiic/Stemma QT.
And only two standards? There's also Grove, (full-size) Stemma, Octopus (2.54 mm pitch) and a few others, all vying to be the easy-connect standard.
Posted: 09:03am 05 Aug 2025
The nice thing about standards is that there are so many of them to choose from. :)
Posted: 09:08am 05 Aug 2025
And if you wait a little more come along.
Posted: 09:12am 05 Aug 2025
It's always better to create your own, I've found. At least no-one can tell you that it's non-standard. :)
