Local Time 08:05 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: PCF8575 I2C I/O Expander
Posted: 09:36am 06 Sep 2024
The PCF8574 and similar 8575 are designed for common applications where LED's are between output pin and 3V3 (5V), and pulups are used to detect key switches that connect to ground. When this is your configuration, they work just fine, with the simplest I2C interface possible.
If you want more complex IO, then there are the TCA6408 type chips, and probably the microchip that Stan promotes.
PhenixRising
Posted: 09:37am 06 Sep 2024
  barewires said  Today I received a Bus Pirate 5. I have used the V3 in the past and mostly for I2C monitoring and probing.
https://buspirate.com/bus-pirate-5-rev-10-now-available/
Still trying to figure-out what it does
Posted: 09:46am 06 Sep 2024
  Quote  Today I received a Bus Pirate 5 ... Still trying to figure-out what it does
The clue is obviously in the name:
  Volhout said  The PCF8574 and similar 8575 are designed for common applications where LED's are between output pin and 3V3 (5V), and pull-ups are used to detect key switches that connect to ground. When this is your configuration, they work just fine, with the simplest I2C interface possible.
I guess I will get a couple and have a play.
I'm still curious about something though, @lizby was suggesting that he was connecting IC pin -> switch -> 3.3V ... what is it that tells us whether that is "safe" for the IC or not, is that not sinking a lot of current through the IC? - remember pretty much everything I know about electronics has been learnt through osmosis on TBS, there is little real understanding - "Dammit Jim I'm a programmer not an electronics-engineer".
Edited 2024-09-06 19:47 by thwill
Posted: 11:09am 06 Sep 2024
Hi Tom,
In case of the PGA2350 I agree. It is much more expensive than a Pico2.
But in general it is cheaper to use the next size up microcontroller (if you need more IO pins) than adding additional IO expanders. And typically these additional microcontroller pins are more versatile.
The main advantage of "distributed IO" is that you avoid the PCB routing complications (running many traces from fine pitch chips like BGA's).
Edited 2024-09-06 21:31 by Volhout
Posted: 12:13pm 06 Sep 2024
This on "wiring-pcf8575-as-input" has good information, including:
"This part is not ideal for being used for many buttons because of this. Each button you press will have ~100mA of current flowing to ground."
They recommend the TCA9555, but the modules on aliexpress are fairly expensive, and have 24 pins. With that in mind, I'd be more inclined to use an RP2040-Zero:
Edited 2024-09-06 22:14 by lizby
PhenixRising
Posted: 12:24pm 06 Sep 2024
Also the added on-board intelligence and more watchdogs.
When my main controller is waiting for a "Start" signal, the slave takes care of determining the validity:
-A normally-closed contact must open
-A normally-open contact must close
-That state must persist for tens of milliseconds.
The main controller receives a true/false.
Posted: 12:31pm 06 Sep 2024
  Tom said  what is it that tells us whether that is "safe" for the IC or not, is that not sinking a lot of current through the IC?
As it is able to drive LEDs directly (no series resistor) the outputs appear to have current limiting.
  Datasheet said  Current source to VCC for actively driving a high at the output
Posted: 12:45pm 06 Sep 2024
  lizby said  has good information, including:
Hi lizby,
I am sure that 100mA only applies when you change the pin output state while the button is pressed. The idea however is that for input pins you ALWAYS send a logic high to the  associated output pin register for any pin that is targetted input, even if you toggle other pins that are intended as output pins.
In that case the 100mA do not apply.
Edited 2024-09-06 23:11 by Volhout
