Local Time 10:18 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Nothing to do with uC: measuring parasitic draw from car battery
Posted: 09:19am 16 Aug 2024
  JohnS said  In case the car has sensitive ultrasonic sensors you may have trouble doing anything in the cabin.
LOL, it has 4 (5?) wheels and it goes "Brmmm!" (pretty much all I've ever asked, beyond a little reliability, from a car). This is a 10 year old car which is about as "low rent" as they come, I doubt it has much in the way of "sensitive ultrasonic sensors".
Anyway, I'm gratified to know more about it now such that if I had no other option I might be able to poke about with some hope of success. However given it wouldn't take me < 3 hours that I don't have, plus probably at least one trip to Halfords, plus the risk of damaging car or multimeter I think I'll be taking it to the mechanic; if I could stand on the roof of our house I could throw stones and hit at least two .
Thanks again folks,
Posted: 09:56am 16 Aug 2024
Disconnecting the car battery does not give you information how to fix. It is 2 things
1/ a weak old battery. Measure the volts during engine start. When it goes down to 9 volt, replace it
2/ something eating power. Through the fuse box you get an idea where to look.
twofingers
Posted: 10:42am 16 Aug 2024
  thwill said  ...The car battery went very very very flat whilst sat for a couple of weeks ( < 0.5V ), I did charge it back up but it then drained again in 4 days ...
  Quote  ... but it's also possible nobody has ever changed its battery which would be 10 years old ...
Hi Tom, my guess: you should save up for a new battery!
edit:
To be clear: the battery is destroyed, buy a new one!
Measuring with a 0.1 ohm resistor is a good idea (as long as you don't try to start the engine   )
Good luck!
Michael
Edited 2024-08-16 21:03 by twofingers
Rickard5
Posted: 11:02am 16 Aug 2024
This may sound stupid but does England Still have that Annoying Positive Earth thing on modern cars?
Posted: 11:03am 16 Aug 2024
If buying a battery I recommend www.tayna.co.uk
DaveJacko
Posted: 09:08pm 16 Aug 2024
Rick
I'd totally forgotten about the positive-earth thing !
wasn't it changed to avoid electrolytic corrosion ?
By the way your American switches are all upside down !
Joking,
Actually, that way, swipe down to switch off, makes more sense.
easier to turn machine off as you fall, stunned, to the ground.
Try swapping 2 and 3 over
Posted: 12:32am 17 Aug 2024
GDay Tom, All,
Just pop out a fuse and put your multimeter across the terminals in AMP mode. Record the reading and go to the next etc etc etc.
If you see a reading that seems high then you should also know the area to be looking.
These cases are usually 3rd party car alarms or entertainment equipment powered off a permanent 12V rather than a switched AUX 12V that should be off when the car is off (and locked).
You could use an old blown fuse and solder wires to it to connect your meter.
Mick (The big one)
Posted: 05:34am 17 Aug 2024
  bigmik said  Just pop out a fuse and put your multimeter across the terminals in AMP mode. Record the reading and go to the next etc etc etc.
Sadly that tends to wake modules so you get current flow that's not the fault but looks like it could be.
PeteCotton
Posted: 07:40pm 22 Aug 2024
Had a parasitic draw on my old Ford Expedition. It took ages to track it down, but it turned out that the rear windscreen wiper would occasionally seize in the non-parked position, and the motor would just keep driving trying to push it to the parked spot.
Even after I fixed it I had to replace the battery - as it was damaged.
Rickard5
Posted: 04:51am 23 Aug 2024
  DaveJacko said  Rick
Joking,
NO Dave I Swear positive Earth was Created to sell me Radios and Magnetos
Most of our switches are up=on , down-off Now I will agree we do fail to follow British electrical code our switches only have off and on, No Smoke or Fire ;)
OA47
Posted: 06:04am 23 Aug 2024
Many years ago I had a work vehicle (1985 Ford Falcon Station wagon) that was not used on the weekends and occasionally I would have a flat battery at the start of the week. When I parked it at the end of the week I regularly grabbed the multimeter and measured the current drain from the battery and eventually I found a 500mA draw when parked. I started lifting fuses and relays to track it down and located the fault to a sticky relay that operated a heater element in the carburetor for cold starting.
It took weeks to catch it but I was glad when I did.
0A47
Posted: 06:48am 23 Aug 2024
@Rick
No, positive earth has gone the way of the dinosaurs in the UK now. If you do come across it it will be on some lovingly restored collectors car.
Can we help it if you lot are incompetent enough to install your switches upside down?
