Local Time 08:10 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PZ Control - my quest for the perfect game controller
Posted: 11:04am 20 Dec 2023
  Mixtel90 said  Unfortunately I don't think I can emulate the WII Classic, but I'm open to putting the bits in any order. :)
I wasnt't asking for emulation, just the bits for the digital controls in the order I gave, which should be the same order as Peter's Wii Classic support on CMM2/PicoMite (and not coincidentally my "ctrl.inc" library). It is the closest to a "standard" that we have.
Edited 2023-12-20 21:04 by thwill
Posted: 01:19pm 20 Dec 2023
The bits will be returned as two bytes, I think. I2C under MMBasic seems to be strictly byte-orientated. Apart from that, no prob.  :)
Posted: 02:26pm 20 Dec 2023
Two bytes will be fine if they are like Tom posted, just join them together as 16 bits.
Possibly Windows will be awkward but should be able to map onto something the same or very close to Tom's list - I hope!
Posted: 09:12pm 21 Dec 2023
Revised:
J(U,D,L,R) = joystick virtual D0pad directions or LH buttons
JB = Joystick switch or Soft_Reset (always high on the Classic)
LT,RT = "shoulder" buttons
P, Z two buttons below Select & Start (replace ZL and ZR)
Command &h04
Returns two bytes:
Byte 1
JR, JD, LT, Select, Hone, Start, RT, JB
Byte 2
P, B, Y, A, X, Z, JL, JU
Incidentally, Nintendo stopped making the Classic and Classic Pro controllers about ten years ago. They simply dropped them with no official announcement.
Edited 2023-12-22 07:25 by Mixtel90
vegipete
Posted: 01:46am 22 Dec 2023
I would try massage those bit patterns somewhat more. The order is mostly right, but the positions are off by one.
From the Wii Classic docs:
  Quote  '     A bit will be set to 1 if the button is pressed.
' The button bitmap is as follows:
' BIT 0: Button R
' BIT 1: Button start
' BIT 2: Button home
' BIT 3: Button select
' BIT 4: Button L
' BIT 5: Button down cursor
' BIT 6: Button right cursor
' BIT 7: Button up cursor
' BIT 8: Button left cursor
' BIT 9: Button ZR
' BIT 10: Button x
' BIT 11: Button a
' BIT 12: Button y
' BIT 13: Button b
' BIT 14: Button ZL
Bit 15 is missing and could presumably be your extra signal.
What order does I2C sent the bits?
Posted: 08:23am 22 Dec 2023
On the Classic controller the spare location is actually bit 0 - it's MMBasic that's wrong. :) I realized that this morning. Bit 0 always returns a 1.
Revised again:
Command &h04
Returns two bytes:
Byte 1 (bits 7-0)
JU, JR, JD, LT, Select, Hone, Start, RT
Byte 2 (bits 15-8)
JB, P, B, Y, A, X, Z, JL
No idea about the I2C bit order. You shove a character (or an array in my case) in at one end and it pops out at the other. That's all I'm interested in. :)
