Local Time 06:26 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/VGA/Web V5.08.00: back to betas
     Page 2 of 7
Posted: 11:10am 01 Dec 2023
  matherp said
  Quote  Here's another one that used to work but doesn't now:
I've reduced the number of nested saves to 8 to save memory
Ack, should be more than sufficient. I will adjust my unit-tests.
I've now run all my automated tests and found nothing else Gerry hasn't already reported.
I'll test b1 and do some manual testing over the weekend.
disco4now
Posted: 11:26am 01 Dec 2023
I think there is a bug in MATH M_TRANSPOSE
The transposed matrix is not fully filled with all the elements if they are not square matrix. It is in all systems , CMM2, Picomites H7,F4, probably MMX.
The change below seems to fix it, the rows and columns for matrix2 have already been swapped so should not be reversed again.
MFLOAT **matrix1=alloc2df(numcols1,numrows1);
//MMFLOAT **matrix2=alloc2df(numrows2,numcols2);
MMFLOAT **matrix2=alloc2df(numcols2,numrows2);
test_matrix:
  1.0000,    2.0000,    3.0000
  4.0000,    5.0000,    6.0000
  7.0000,    8.0000,    9.0000
 10.0000,   11.0000,   12.0000
 13.0000,   14.0000,   15.0000
  1.0000,    4.0000,    7.0000,   10.0000,   13.0000
  2.0000,    5.0000,    8.0000,   11.0000,   14.0000
  3.0000,    6.0000,    9.0000,   12.0000,   15.0000
F4 H7FotSF4xGT
disco4now
Posted: 11:52am 01 Dec 2023
  thwill said   Gerry do you have my transpiler running or did you manually #INCLUDE everything, or something else ?
Hi Tom,
I have my MMReplace addon to MMEdit which handles the #INCLUDES at load time. The tests get loaded and run but also copy themselves to the A:/tests directory, so they can be all run with BASE 0 and BASE 1. A couple of directives #LOADLIBRARY and
#IGNORELIBRARY allow the includes to be stored in the library so you are only reloading the actual tests when you are developing. It is your framework with a few tweaks to make it work off the A: drive.
There is just a few tweaks to the header to use your test files so we could trade some test files without much work. I am adding most of the MATH command options to tst_math.bas so I can exercise them. I will also add anything missing in LONGSTRING.
I have found your unit testing a great help when developing the H7 and F4.
I can give you my(your) updated tests if you are interested.
Gerry
F4 H7FotSF4xGT
Posted: 12:15pm 01 Dec 2023
V5.08.08b1
Should fix everything mentioned above and includes Gerry's MATH fix
karlelch
Posted: 04:40pm 01 Dec 2023
Hi Peter,
I am testing my solar panel display program, which uses MQTT. Sofar, it runs with V5.08.08b1. I'll monitor it over the next days.
Best
Thomas
Edit: I also tested my 6-legged, 3DOF robot software (VGA firmware, V5.08.08b1), which makes heavy use of the MATH commands/functions. So far, it works.
Edited 2023-12-02 03:02 by karlelch
Posted: 05:16pm 01 Dec 2023
Thomas - thanks for the feedback - sounds good
Posted: 05:45pm 01 Dec 2023
Straightforward I2C with an MCP23017 I/O expander works on Mick's PicoMiteVGA Mini PCB with:
PicoMiteVGA MMBasic Version 5.08.08b1
OPTION SYSTEM I2C GP14,GP15
OPTION KEYBOARD US
OPTION SDCARD GP13, GP11, GP12, GP10
OPTION AUDIO GP6,GP7', ON PWM CHANNEL 3
Posted: 08:44pm 01 Dec 2023
Hi Peter,
On VGA using 50800beta1
The stack issue with chess is solved.
The layer and color issue is not solved.
What it boils down to (I think) is that when leaving PETSCII robots with control C, the default background color is remembered (was magenta in layer L).
When RUN a new program (i.e. chess, but below 2 line program is sufficient to demonstrate) the CLS clears in magenta color. Not black.
MODE 2
CLS
I would expect that default color to be reset at start of a new program (RUN), and not inherited from previous program.
P.S. maybe related: after a cold boot you can FRAMEBUFFER WRITE L, without even creating the framebuffer with FRAMEBUFFER LAYER.
Edited 2023-12-02 06:58 by Volhout
Posted: 10:38pm 01 Dec 2023
This is nothing to do with the latest changes but I'll look at it when I have a chance
disco4now
Posted: 01:34am 02 Dec 2023
I have added a few more test to MATH and found these.
MATH V_NORMALISE
  Normalising this vector
  results in this one
  INF, INF, INF
must be a divide by zero in there somewhere. Works before the update.
MATH(M_DETERINANT
 test_determinant on this matrix complains about the dimension:
[1645] assert_float_equals(0.0, Math(M_DETERMINANT a!()), 1e-10)
Error : Argument 1 must be a 1D floating point array
MATH(V_MULTIPLY gives incorrect result. causes a restart before the update so
probably something wrong.
This 2D array
  3.0000,    3.0000,    3.0000
This Vector
This result
  0.0000,    0.0000,    0.0000
Expected
  18.000     18.000     18.000
FAIL (1/2)
   2: Assert equals failed, expected 18 but actually 1.709015797e-304
MATH Q_CREATE complains about varaiable
sub test_quaterions()
 'Quaternion arithmetic
  local outRQ!(BASE%+4)
  MATH Q_CREATE 1, 2, 2, 2, outRQ!()
 'MATH V_PRINT outRQ!()
  assert_float_equals(0.4672, outRQ!(BASE%), 1e-6)
end sub
 test_quaterions:
[1382] Math Q_CREATE 1, 2, 2, 2, outRQ!()
Error : Variable name
LONGSTRING PRINT array%()  is OK
LONGSTRING PRINT #1,array%() gives error.
[1475] LongString Print #1, array%()
LONGSTRING COPY fails. Have not verified if it was previously OK
Sub test_copy()
 Local src%(100), dest%(100)
 LongString Append src%(), "Hello World"
 LongString Copy dest%(), src%()
 assert_string_equals("Hello World", LGetStr$(dest%(), 1, LLen(dest%())))
test_copy:                                         FAIL (1/1)
   1: Assert equals failed, expected "Hello World" but actually "<0><0><0><0><0><0><0><0><0><0><0>
Edited 2023-12-02 12:18 by disco4now
F4 H7FotSF4xGT
Posted: 10:09am 02 Dec 2023
V5.08.08b2
Gerry: thanks for all the great testing
b2 should fix all of the above and Harm's issue (not tested). In addition I have added functionality for Frank.
PLAY HALT - stops playback for MP3 files via the VS1053 and notes the current location in the file
PLAY CONTINUE track$ - restarts playback of an mp3 track from the position halted. "track$" will be the name of the file with all file attributes removed
e.g.
PLAY MP3 "B:/mp3/mymp3.mp3"
sometime later
PLAY HALT
later again
PLAY CONTINUE "mymp3"
disco4now
Posted: 11:03am 02 Dec 2023
  matherp said  b2 should fix all of the above
Confirmed that all are fixed.
Gerry
F4 H7FotSF4xGT
Posted: 11:13am 02 Dec 2023
  disco4now said  ... A couple of directives #LOADLIBRARY and #IGNORELIBRARY allow the includes to be stored in the library so you are only reloading the actual tests when you are developing ...
Hi Gerry,
That hadn't occurred to me, I may take a look, though since it's unit-test specific I might just live with the existing inefficiency of completely pre-processing each file as I send it.
  disco4now said  It is your framework with a few tweaks to make it work off the A: drive.
I thought it did work off the A:/ drive, that's at least how I am using it.
  disco4now said  I will also add anything missing in LONGSTRING.
I would struggle without unit-testing now, it's the only way to efficiently keep on top of regressions.
Yes, please I would appreciate adding anything you've got to my test suite, it might even encourage me to put some work into MMB4L.
disco4now
Posted: 11:42am 02 Dec 2023
One more.
MATH(M_DETERMINANT is now OK with OPTION BASE 0
but with same tests some have incorrect results when OPTION BASE 1
SUB test_determinant
local a!(BASE%+2,BASE%+2)
a!(BASE%,BASE%)=1
a!(BASE%,BASE%+1)=2
a!(BASE%,BASE%+2)=3
a!(BASE%+1,BASE%)=4
a!(BASE%+1,BASE%+1)=5
a!(BASE%+1,BASE%+2)=6
a!(BASE%+2,BASE%)=7
a!(BASE%+2,BASE%+1)=8
a!(BASE%+2,BASE%+2)=9
'print
'MATH M_PRINT a!()
a!(BASE%,BASE%+2)=2
assert_float_equals(3.0, Math(M_DETERMINANT a!()), 1e-10)
a!(BASE%,BASE%+2)=4
assert_float_equals(-3.0, Math(M_DETERMINANT a!()), 1e-10)
end sub
These failures when OPTION BASE 1 is set.
test_determinant:                                  FAIL (2/3)
   2: Assert equals failed, expected 3 but actually 0
   3: Assert equals failed, expected -3 but actually 0
F4 H7FotSF4xGT
Posted: 12:04pm 02 Dec 2023
Found and fixed - keep em coming
I hate and despise OPTION BASE
Edited 2023-12-02 22:05 by matherp
Posted: 03:02pm 02 Dec 2023
Probably unrelated bug:
1. EDIT "foo.txt"
2. Type "Bananas" with no newline
3. Press F1 (Save)
4. EDIT "foo.txt"
5. File just contains "Banana" with no trailing "s"
javavi
Posted: 03:13pm 02 Dec 2023
Version V5.08.08b1 was compiled from source codes and worked with changes for my hardware (Murmulator).
Source Code
Version V5.08.08b2 is built but doesn't work at all! :(
Posted: 03:31pm 02 Dec 2023
  Quote  Probably unrelated bug
Also found and fixed - thanks
javavi
Posted: 02:32pm 03 Dec 2023
Starting from beta version V5.08.08b2, the program for PicoMiteVGA compiled from source code does not work!
https://github.com/UKTailwin/PicoMite
In this case, the assembly of the same codes, the PicoMite version, starts normally.
In my opinion, the reason is due to file changes:
Audio.c
Audio.h
MMBasic.h
MM_Misc.c
Edited 2023-12-04 00:33 by javavi
Posted: 02:38pm 03 Dec 2023
  Quote  the program for PicoMiteVGA compiled from source code does not work!
I don't provide any support for building from github. It works for me and the files are up-to-date
     Page 2 of 7
