Local Time 16:18 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB4W - blit, programming or hardware error - help
electricat
Posted: 02:35pm 06 Feb 2025
  bfwolf said  On my laptop (HP Probook 6550b, Win10Pro, 22H2) MMB4W shows just a black screen - no "signon message" or anything else..
Any ideas?
bfwolf
Nothing new or original about my ideas, but I would tray to
1) run as Administrator,
2)tray compatibility modes
3) change video drivers
4) if system has integrated and discrete video card I would try both of them (run with graphics processor..."
Not so many chances , but I would check/ask question this for searching reason of problem https://github.com/OneLoneCoder/olcPixelGameEngine/issues
My MMBasic 'sand box'
Posted: 04:53pm 06 Feb 2025
Almost certainly that you haven't got the required audio DLLs. Check the various threads for how to start without audio.
bfwolf
Posted: 08:56am 07 Feb 2025
Thanks for your tips!
  electricat said  Nothing new or original about my ideas, but I would tray to
"run as Administrator" and "tray compatibility modes" I already tried, but didn't help I didn't want to change the video driver because I think Windows 10 automatically installed the optimal one - and the laptop only has the integrated "Intel graphics unit" so there aren't many options.
Unfortunately, nothing enlightening could be found in the olcPixelGameEngine issues.
  matherp said  Almost certainly that you haven't got the required audio DLLs. Check the various threads for how to start without audio.
That was a really good tip! It's quite possible that I didn't install anything "special"!
Now I just have to find out how to start MMB4W without "audio" or maybe even which DLLs are missing and install them...
Thx, bfwolf!
bfwolf
Posted: 08:51pm 07 Feb 2025
To give you an update: Success!
I found no hint, how to disable audio, in the forum topics..
But I had a look into the MMB4W sources - in main.cpp I found some parts that let me assume that giving '0' as 1st arg should do it - and this worked!
BTW: Does a reasonably up-to-date manual for MMB4W exist somewhere? (PDF? Link?)
bfwolf
Posted: 09:00pm 07 Feb 2025
The latest I can find
Turbo46
Posted: 11:45pm 07 Feb 2025
See
  Quote  OK so we know it is the audio dll which is the problem - winmm.dll
Now please try the attached but launch mmbasic from a dos box using the command
MMBASIC 0
Perhaps this should be included in the manual (Panky?)
Posted: 12:12am 08 Feb 2025
winmm.dll
winmm.zip
Its in C:\windows\System32 on my computer.
electricat
Posted: 09:29am 08 Feb 2025
  bfwolf said  To give you an update: Success!
bfwolf
It was explained im MMB4W manual   But looking into sources sometimes really helps   .
From a command line prompt in Windows , you can start MMBasic running a BASIC program in a number of
ways as follows:-
MMBASIC
'opens MMBasic
MMBASIC "program.bas"
' opens MMBasic and immediately runs program.bas
MMBASIC "program" ' opens MMBasic and immediately runs program.bas
MMBASIC "program.bas",text
' opens MMBasic and immediately runs program.bas,
passes text to the program as MM.CMDLINE$
MMBASIC "program",text
' opens MMBasic and immediately runs program.bas, passes
MMBASIC 0
'opens MMBasic with audio disabled
MMBASIC 0 "program.bas" ' opens MMBasic and immediately runs program.bas with
audio disabled
MMBASIC 0 "program"
audio disabled
MMBASIC 0 "program.bas",text
passes text to the program as MM.CMDLINE$ with audio disabled
MMBASIC 0 "program",text ' opens MMBasic and immediately runs program.bas, passes
text to the program as MM.CMDLINE$ with audio disabled.
One can also create win shortcut and edit cmd properties.
Edited 2025-02-08 19:30 by electricat
bfwolf
Posted: 08:56pm 08 Feb 2025
Many thansk for all your help!
  phil99 said  The latest I can find
Thx!!! That helped!
  phil99 said  winmm.dll
winmm.zip
A few minutes ago I searched the Windows directory for "winmm.dll" - I "felt" that I had about 20 "winmm.dll" instances in various subdirectories - with different dates. There is also a "winmm.dll" in C:\Windows\System32 and I tried to copy a slightly larger one with a slightly newer date - but Windows "doesn't like it" (i.e. refuses).
ways as follows:-
Yes - after I downloaded the PDF of the "most recent" MMB4W manual, I found the relevant section. So until I have solved the "actual problem" with the "winmm.dll", I can live with the first argument '0' for mmb4w.exe - then I just have no audio.. Who cares?
In olcPGEX_Sound.h in the MMB4W source there is the instruction
#pragma comment(lib, "winmm.lib")
and that already points to the "winmm.dll"..
Or is in fact another DLL to blame?
bfwolf
