Local Time 19:44 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: ILI9341 TFT with parallel interface
Posted: 09:40am 14 Sep 2023
Indeed, let's not get ahead...
Let's first prototype and see how much gain there is in speed... because that is why this is interesting, right ?
Edited 2023-09-14 19:40 by Volhout
Posted: 10:00am 14 Sep 2023
For reference since easy to do on the MMX (200MHz)
Time for CLS
ILI9341 SPI 49mSec
ILI9341 16-bit parallel 6mSec
ILI9341 8-bit (calculated from the scaled time of 8-bit 480*272 SSD1963)  14mSec
NB: the SPI on the MMX is more efficient than the RP2040 but parallel port operations are slower (2 cycles per write)
On Pico @ 252MHz
ILI9341 SPI 69mSec (66mSec at 133MHz)
ILI9341 8-bit (calculated from the scaled time of 8-bit 480*272 SSD1963) 8mSec (14 at 133MHz)
Edited 2023-09-14 20:01 by matherp
Posted: 01:00pm 14 Sep 2023
That sounds promising Peter, it certainly looks like it would be fast enough that blitting to the display would no longer be the bottleneck for arcade games.
