Local Time 06:26 27 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Watering Controller - Updated Firmware (V1.3)
Posted: 04:52am 19 Jan 2024
  Quote  Sub MM.STARTUP is only executed if the program is running (ie, OPTION AUTORUN worked).
whatever is in Sub MM.STARTUP seems to get executed whenever the Pico restarts, regardless of AUTORUN. If OPTION AUTORUN is set MM.STARTUP runs first.
On my WebMite AUTORUN isn't set, just MM.STARTUP as above and the program runs every time.
Edit. This works reliably for me. After a power outage the WebMite first waits for the modem to boot then waits for the internet to reconnect before starting the main program.
> option list
WebMite MMBasic Version 5.08.00RC4
OPTION COLOURCODE ON
OPTION DISPLAY 55, 132
OPTION WIFI WiFi-6BAC, ***************, PICOE6614104031
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
OPTION SDCARD GP17
> LIST
Sub MM.STARTUP
 Pause 200
 On error skip 4     'test for WiFi link
 If (MM.Info(ip address) = "0.0.0.0") Or (MM.Info(ip address) = "") Then
   Pause 8000
   CPU restart
 Local float TZ = 10, DS = 1    'Time Zone, Daylight Saving
 Do While Right$(Date$,4) = "2000" 'test for internett connection
  On error skip 2
  WEB NTP TZ+DS, "162.159.200.123"
  Pause 2000
 Run 'start main program
Edited 2024-01-20 22:18 by phil99
