Local Time 13:02 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite MMBasic Version 5.07.07a29 with TFTP
Posted: 07:13am 07 Apr 2023
Me too. Once I found that I could use DHCP and also assign addresses on the router I stopped using them altogether. Mind you, I'm disorganised and I kept losing my list of statics....   :(
Posted: 07:26am 07 Apr 2023
  Quote  Strange, at least CircuitPython seems to support it - different SDK ??
https://forums.raspberrypi.com/viewtopic.php?t=349890
Posted: 08:11am 07 Apr 2023
  bigfix said  Strange, at least CircuitPython seems to support it - different SDK ??
CircuitPython Example
Ah, so what you can do is take Peter's code (with the Pico SDK etc), make the changes yourself and use that.
To make it easier to track future changes, before you change anything you might like to put all the code into a software version management suite (e.g. git but there are others).
Edited 2023-04-07 18:32 by JohnS
