Local Time 14:16 28 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWEB V5.07.07a24+ - Now with TFTP
     Page 2 of 5
Posted: 09:33am 14 Mar 2023
I spoke too soon:
Connected
*** PANIC ***
Out of Heap memo
After 15 reports.
JIm
Pluto
Posted: 09:35am 14 Mar 2023
Thanks Jim. I will try your proposal after my ongoing test is done.
What about the buff%()? Should it be emptied between the updates? I suppose not.
Pluto
Posted: 09:52am 14 Mar 2023
Tested with updating only one location every second minute. Crashed after 15 updates. Checked openweathermap and it allows 60 calls per minute; so that should not be a problem.
Posted: 10:03am 14 Mar 2023
We need to narrow down the cause. If you write a simple json parser in Basic rather than using the json$ function does that fix it?
json$() uses the system heap. It is third party code and is supposed to clean up after itself but who knows
Pluto
Tested with DIM buff%(1024) and updates each 15s to save time. PANIC after 15 updates.
twofingers
Posted: 10:45am 14 Mar 2023
FYI:
I also had a ***Panic*** error message when using JSON (V5.07.07a16). But only with certain JSON data from Openweathermap (which I don't want to pass on unedited because of ID). I'm pretty sure it's a JSON issue. I will test it again on the CMM2.
Michael
Posted: 10:53am 14 Mar 2023
  Quote  I will test it again on the CMM2.
The CMM2 is very different. It uses MMBasic heap rather than system heap and cleans up regardless after each call so the two aren't comparable. The PicoMite can't do the same thing.
Pluto
Yes it seems to be a JSON issue. I removed all JSON statements and just retrieved the the data. Updating did not stop (no PANIC). Printed the buff%(); looks like this:
RUN
ntp address 195.148.70.12
got ntp response: 14/03/2023 12:51:22
****************Update nbr:     1
tcp address 188.166.16.132
Connected
488
2478231517896319611
4189032028242606906
3184384918481155378
3474028082218757154
2462480755104232238
2482157843938108791
4189021006120835898
7593470440261300280
8462101260445295214
8315162384941609828
etc
Posted: 10:55am 14 Mar 2023
I added this (and the memory command)
Print "Heap: ";Hex$(MM.Info(stack)),MM.Info(HEAP)
Heap: 200413E8  78080
Heap and memory didn't change. Still crashed after 15 calls.
Posted: 11:04am 14 Mar 2023
I think I may have found something. Are you parsing something that comes back as an empty string?
This can happen if it is an array (rather an array element) or some other things in json I don't understand (raw, object , null)
If you are then there is a possible memory leak which will eventually cause the issue. If so I can then probably fix it.
Posted: 11:34am 14 Mar 2023
Try it without this
TEXT 0,120,"Regn: "+Json$(buff%(),"rain.1h")+" mm/h"
You can see the returned data with
  Quote  longstring print buff%()
and you will see that rain.1h doesn't exist. I should be protecting against this error but I think this is the problem
Pluto
Posted: 11:36am 14 Mar 2023
In fact I removed it just before your message!
Posted: 11:40am 14 Mar 2023
V5.07.07a25
PicoMiteWebV5.07.07a25.zip
Fixes memory leak in json$ function if the naughty user requests a field that doesn't exist
Pluto
Posted: 11:44am 14 Mar 2023
Naughty user send big THANKS to Peter, Jim & TwoFingers!
22 updates now and no PANIC.
Will now go over to a25.
twofingers
Posted: 02:57pm 14 Mar 2023
Btw.
I think there are still (crash) problems with A25. Not associated with JSON. I test ...
Some OT for Openweathermap:
' Windrose converts a degree cardinal direction into a compass direction.
Degree=360-11
Print Degree, windrose16$(Degree)
End
Function windrose16$(Degree)
Local WD$(16)=("NNO","NO","ONO","O","OSO","SO","SSO","S","SSW","SW","WSW","W",
"WNW","NW","NNW","N","NNO")
windrose16$=WD$(Int(((Degree+360*(Degree<11.25))-11.25)/22.5))
End Function
Posted: 03:05pm 14 Mar 2023
Didn't crash for me
Michal
Posted: 03:53pm 14 Mar 2023
In:
"Windows MMBasic Version 5.07.03b15
 349
Error in line 8: Expected closing bracket"
Michal
twofingers
Posted: 03:59pm 14 Mar 2023
@Peter
Please try this:
MFile$="ABC"
path$=".\nsa8\"+MFile$
End
For me it causes a crash.
Michael
Edit:
Works:
a$="test"+"TEST"
End
Crashes:
a$="\"+"test"  'crash
End
Edited 2023-03-15 02:32 by twofingers
atmega8
Posted: 05:00pm 14 Mar 2023
  twofingers said  @Peter
Please try this:
MFile$="ABC"
End
Michael
Edit:
Works:
a$="test"+"TEST"
End
Crashes:
End
Commit:
MFile$="ABC"
CRASH
RESET
> print mm.ver
5.070723
Posted: 05:33pm 14 Mar 2023
Now that \ starts an escape you need to change the strings.
(Ideally it wouldn't crash, though.)
     Page 2 of 5
