Godoh Guru Joined: 26/09/2020 Location: AustraliaPosts: 715
Posted: 06:09am 10 Mar 2023
I have also used VueScan. Many years ago, I had a printer scanner that Widows did not support, so loaded VueScan and it worked a treat. I gave up on widows many years ago and just use Linux. It seems to be able to find printers, print with them with no problems at all. I have an ancient Canon IP 4200, the only problem I find is that it does not like printing Pdf files from emails, If I save them to the hard drive they print fine. I don't have a scanner anymore, I just photograph files if I need to and print them to pdf. Pete
