Local Time 10:14 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM-Basic Sprite Editor
Posted: 02:23pm 12 Jun 2023
AFAIK there aare no numbers for the color names in the MMBasic rogram, but there are numbers used in the sprite file, to make the format compliant with CMM1.
Posted: 04:05pm 12 Jun 2023
  hhtg1968 said  hello. my picomitevga will be ready in a few days. i tried to start your programm on my cmm2. the colours myrtle, cobalt etc. are no keywords for mmbasic on cmm2. where can i get the numbers for the colour names?
For things like RGB(myrtle) I expect you can
PRINT RGB(myrtle)
Bear in mind not all hardware can do all colours.
Martin H.
Posted: 04:54pm 12 Jun 2023
If the RGB Handling is equal just replace the Data in the Sourcecode:
colors:
'--Colorscheme accordung to matherp
Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED)
Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE),RGB(MYRTLE)
Data RGB(COBALT) ,RGB(MIDGREEN),RGB(CERULEAN),RGB(RUST)
Data RGB(FUCHSIA),RGB(BROWN),RGB(LILAC)
pict:
with this
colors:
Data &H0000FF,&H00FF00,&H00FFFF,&HFF0000
Data &HFF00FF,&HFFFF00,&HFFFFFF,&H004000
Data &H0040FF,&H008000,&H0080FF,&HFF4000
Data &HFF40FF,&HFF8000,&HFF80FF
pict:
as you might see,  myrtle, cobalt etc. are those colors with the Green variants 40,80
Edited 2023-06-13 02:58 by Martin H.
'no comment
Martin H.
Posted: 05:25pm 12 Jun 2023
  Volhout said  Hi Martin,
This is a GREAT tool !!! I used it for 1 week now, and really appreciate it. This really works well. The only negative point I found so far is that <ctrl-C> is needed to Quit (I did not find any other way so far).
Is there any documentation on the "compressed format" ?
So I can implement the compressed sprite reader in MMbasic in my program.
The principle is simple, repeating pixels of the same color are counted.
The color number is increased by 16 followed by the number of repetitions -1 (max 15)
So far you can use a text editor to search and replace repeating parts of the Sprite Data strings with the compressed form.
which is quite laborious.
Example :
find "0000000000000000" replace with "GF"
find "000000000000000"  replace with "GE"
find "00000000000000"   replace with "GD"
find "000" replace with "G2"
and that for all 16 colors.
You can do something like this 2-3 times, but it's boring and a real punishment. So I thought, the pico can do that much faster and with less effort so let him do the work.
you can use the compress and Expand Function from the SprEd Source code..
Function expand$(pxl$)
 Local n%,nmb%,tmp$,co$
 n%=1
  If Asc(Mid$(pxl$,n%,1))< 71 Then
     tmp$=tmp$+Mid$(pxl$,n%,1)
  Else
     ' length encoded - 1st char is pixel colour+71, 2nd is count-1
     co$=Hex$(Asc(Mid$(pxl$,n%,1))-71)
     Inc n%
     nmb%=Val("&H"+Mid$(pxl$,n%,1))
     tmp$=tmp$+String$(nmb%+1,co$)
  Inc n%
 Loop Until n%>Len(pxl$)
 expand$=tmp$
End Function
Function compress$(search$)
Local String from$,zu$
found=0
For f%=0 To 15
  For n%=16 To 3 Step -1
    from$=String$(n%,Hex$(f%,1))
    zu$=Chr$(71+f%)+Chr$(128+Asc(Hex$(n%-1,1)))
   'addition of 128 prevents the results from
    'being incorrectly counted in a further search
      search$=replace$(from$,zu$,search$)
      If found=0 Then Exit
  Next n%
Next f%
compress$=""
For f%=1 To Len(search$)
  n%=Asc(Mid$(search$,f%,1))
  n%=n%-128*(n%>128):'sub the 128 if needed
  compress$=compress$+Chr$(n%)
Next
End Function
Function replace$(sr$,repl$,sear$)
Local n%,tmp$
tmp$=" "+sear$+" "
found=Instr(tmp$,sr$)
If found=0 Then replace$=sear$:Exit Function
tmp$=Left$(tmp$,found-1)+repl$+Right$(tmp$,Len(tmp$)-(found+Len(sr$))+1)
replace$=Mid$(tmp$,2,Len(tmp$)-2)
End Function
To see, how I used it, also take a look at the On the Road again Listing :-)
Sub read_Sprites
Local nr%,p%,n%,byt$,m$
'--- Read/Create Sprites
Restore car
  For p%=1 To 31
    Read Byt$:Byt$=expand$(Byt$)
    For n%=1 To Len(Byt$)/2
      m$=Mid$(Byt$,n%,1)
      Pixel n%-1,p%,COL%(Val("&H"+m$))
      Pixel 56-n%,p%,COL%(Val("&H"+m$))
      m$=Mid$(Byt$,Len(Byt$)-(n%-1),1)
      Pixel n%-1,32+p%,COL%(Val("&H"+m$))
      Pixel 56-n%,32+p%,COL%(Val("&H"+m$))
    Next
  Next
Sprite read #1,0,0,56,32:Sprite read #2,0,32,56,32
'  Sprite load "Car3.spr",3
Restore car3
  For p%=0 To 30
      m$=Mid$(Byt$,n%,1)
    Next
  Next
Sprite read #3,0,0,56,30
Have Fun
Edited 2023-06-13 03:52 by Martin H.
'no comment
Posted: 09:42pm 12 Jun 2023
Hi Martin,
I saw you paint the pixel data on screen, and then read the sprite from screen.
Why not uncompress the colors in a linear array, and use
SPRITE LOADARRAY n,w,h,array%
Saves a lot of coordinate calculations
Martin H.
Posted: 02:51am 13 Jun 2023
sounds good. I missed the option so I've never tried it.
How is the memory consumption?
'no comment
Posted: 04:05am 13 Jun 2023
Probably bad. You need DIM an array for each size sprite. But you need this only during  creation (local).
hhtg1968
Posted: 09:01am 13 Jun 2023
to martin h:
many thanks for the colour numbers...
Martin H.
Posted: 05:40am 14 Jun 2023
  hhtg1968 said  to martin h:
You're welcome
These were the color values that the PicoMiteVGA returned.
Now I have noticed that in the Windows version, the position of red and blue seem to be reversed. Since I don't know how the colors are used on the CMM, here the codes that MMBasic4Windows gave me back.(just to be on the safe side, if the other colors don't fit).
Data &HFFFF0000,&HFF00FF00,&HFFFFFF00,&HFF0000FF
Data &HFFFF00FF,&HFF00FFFF,&HFFFFFFFF,&HFF004000
Data &HFFFF4000,&HFF008000,&HFFFF8000,&HFF0040FF
Data &HFFFF40FF,&HFF0080FF,&HFFFF80FF
Edited 2023-06-14 15:41 by Martin H.
'no comment
hhtg1968
Posted: 06:17am 14 Jun 2023
hello. no i have a running picomitevga and can test this program...
1. i only see 8 colours. the row has 16 parts, so i see the same colours twice...
2. is this software free? i would program further for my purpouses, but only if martinH is saying "yes"...
Posted: 06:59am 14 Jun 2023
  hhtg1968 said  hello. no i have a running picomitevga and can test this program...
A hardware problem? A bit shorted / not connected?
Maybe post a small picture showing all the ones you see and someone may say what's wrong.
toml_12953
Posted: 07:08am 14 Jun 2023
  Martin H. said  To make the work a little easier I wrote a small sprite editor.
Have Fun
�Mart!n
Thanks! This is very useful. If I may make a few suggestions:
1. Don't let the program crash if the load filename is non-existent.
2. Allow the user to exit the load and save prompts without entering a filename and without destroying work in progress.
This can be as easy as this:
Case Chr$(145):fname$=Dialog$("Load File, Name?"):if fname$<>"" then fread(fname$)
Case Chr$(146):fname$=Dialog$("Save File, Name?"):if fname$<>"" then fwrite(fname$)
3. Allow mouse presses for the buttons on the right.
Edited 2023-06-14 17:20 by toml_12953
hhtg1968
Posted: 08:01am 14 Jun 2023
the problem with the colours is solved... i placed the connection for 1/3 green wrong... at another topic here i got the solution...
Martin H.
Posted: 09:04am 14 Jun 2023
I say "Yes"
'no comment
hhtg1968
Posted: 10:21am 14 Jun 2023
thanks.
electricat
Posted: 03:51pm 25 Aug 2024
@Martin H,
Did you progressed somehow Sprite Editor further?
I am thinking to write small game and now looking arround for some toools :)
My MMBasic 'sand box'
Martin H.
Posted: 05:52pm 25 Aug 2024
@electricat
I haven't developed much further here. It was a project that I created for myself and then shared with others. That's why I didn't invest much time in comfort.
But it is definitely appreciated if someone takes on the program and publishes improvements to it.
Since I hat to convert the graphics for Petscii Robots, also because it was so much, I've switched to creating the graphics on a PC with a drawing program (Paint dot Net) and then converting them into sprites on Pico or with MMBasic for Windows.
Martin
Edited 2024-08-26 03:56 by Martin H.
'no comment
