Local Time 11:22 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : scale function
Turbo46
Posted: 07:47pm 27 Sep 2022
  stanleyella said  Can a sub be like a function as per passing parameters?
Did you read my post above?
Posted: 07:55pm 27 Sep 2022
  lizby said
  stanleyella said  Would integers be ok for integers?
Would 3 divided by 2 times 2 yielding 2 be good enough for you? What's the fear of floats? If you're doing division, floats are your friend.
Hmmm. I got to think about that. New to me using mmbasic but worked as 16bit and 32bit vals on 8bit ucntrlr.
I will try using integers because some success withprevious code but now testing the
captain boing map function with looks just whatI wanted but may use just math for scaling a value.
cheers, stan
Posted: 08:29pm 27 Sep 2022
Naturally. I read all replies. Your link gave error 404. I from 8 bit do not use subs because the call and return uses the stack but no idea about functions speed.
I got no problem using in line code not subs but if using arrays then repeating same code would use prog mem.. but it is a pico and has plenty so who cares?
Why bother with bits or bytes? use integers and floats for variables
Floats for 1 + 2 just seems new.
Turbo46
Posted: 09:01pm 27 Sep 2022
  stanleyella said  Your link gave error 404
Sorry, you should have said. Try this:
  Turbo46 said  Another good source of information is Geoff's "Getting Started with the Micromite" from here
Sorry but the fact that you asked that question "after reading my post" and reading the manual just suggested to me that you didn't. I tried to demonstrate and explain just that very thing.
Posted: 09:09pm 27 Sep 2022
True that SUBs and FUNCTIONs are slightly slower than inline code, but if they are of any length they'll save you memory, especially if they are used several times. The performance hit from using them isn't much unless they are being called from inside a loop in which case they may slow things down. If you are bothered about speed then use TIMER to measure how long it takes to call a SUB or FUNCTION and return.
It's well worth having a good read about SUBs and FUNCTIONs, as well as about static and local variables. They can make your life a lot easier and enable you to write routines that can be used again in other programs without having to start from scratch.
You generally only DIM an array once. After that it doesn't change how much memory it uses as it's already allocated. The memory used comes out of the variables area, not the program area, so you can have some big arrays.
Posted: 09:32pm 27 Sep 2022
I find the for next final value is strange
vin=3.39 vdeg=270.18181822
I do not see why for vin=0 to 3.3 step 0.01 next got to 3.39 which it does just printing vin
OPTION EXPLICIT
dim vdeg!,vin!
cls
vdeg=Map(vin,0,3.3,0,270)
 text 0,0,str$(vin)
text 50,0,str$(vdeg)
next
do
loop
Function Map(x As Float,rLo As Float,rHi As Float,oLo As Float,oHi As Float) As Float
Map=((Min(Max(x,rLo),rHi))-rLo)*((oHi-oLo)/(rHi-rLo))+oLo
End Function
Turbo46
Posted: 09:49pm 27 Sep 2022
Works for me. I changed the TEXT for PRINT and tested in MMBasic for DOS
OPTION EXPLICIT
dim vdeg!,vin!
cls
print str$(vin), str$(vdeg)
next
do
loop
End Function
These were the last few values:
3.27    267.5454545
3.28    268.3636364
3.29    269.1818182
3.3     270
Posted: 10:18pm 27 Sep 2022
Stan is print to the LCD so the '9' is left over form the previous value 3.29
He needs to use str$(Vin,2,2) or erase the 9 in othe rways.
Similar for 270xxxxx
Edited 2022-09-28 08:18 by TassyJim
Posted: 10:40pm 27 Sep 2022
Wouldn't work on a PICAXE with integer-only math. On what device does it work for you with unsigned 8-bit math? I'm guessing floats have to be available for intermediate values.
Turbo46
Posted: 10:46pm 27 Sep 2022
Of course. Thanks Jim
So Stan, (just in case... )your code would be:
OPTION EXPLICIT
dim vdeg!,vin!
cls
text 0,0,str$(vin,2,2)
text 50,0,str$(vdeg,2,2)
next
do
loop
End Function
And Stan, I recommend that you use:
next vin
It can get confusing when you are nesting for/next loops
Martin H.
Posted: 09:01am 28 Sep 2022
example to Scale a Picture
for better readability I left the data uncompressed
'scale a Picture
Dim Col%(15)
Restore colors:For f%=1 To 15:Read Col%(f%):Next f%
MODE 2
Draw_tree
'SCALE it down
For y%=0 To 44
 For x%=0 To 63
   cl%=Pixel(x%,y%)
   Pixel 64+x%/1.25,10+y%/1.25,cl% :'Scale 0.8
   Pixel 116+x%/1.5,16+y%/1.5,cl%  :'Scale 0.67
   Pixel 160+x%/1.8,21+y%/1.8,cl%  :'Scale 0.55
   Pixel 196+x%/2,24+y%/2,cl%      :'Scale 0.5
   Pixel 228+x%/2.5,28+y%/2.5,cl%  :'Scale 0.4
   Pixel 254+x%/3,31+y%/3,cl%      :'Scale 0.33
   Pixel 276+x%/4,35+y%/4,cl%      :'Scale 0.25
   Pixel 292+x%/6,39+y%/6,cl%      :'Scale 0.166
 Next
Next
Print @(0,128)
Sub draw_tree
Local p%,n%,byt$,m$
 '--- Read/Create Sprite
 Restore Tree
  For p%=0 To 40
   Read Byt$:Byt$=expand$(Byt$)
   For n%=1 To Len(Byt$)
    m$=Mid$(Byt$,n%,1)
    cl%=Val("&H"+m$):Pixel n%-1,45-p%,COL%(cl%)
   Next n%
  Next p%
  'Sprite read #1,0,0,64,45
Function expand$(pxl$)
 Local n%,nmb%,tmp$,co$
 For n%=1 To Len(pxl$)
   If Asc(Mid$(pxl$,n%,1))< 71 Then
     tmp$=tmp$+Mid$(pxl$,n%,1)
   Else
     co$=Hex$(Asc(Mid$(pxl$,n%,1))-71)
     Inc n%:nmb%=Val("&H"+Mid$(pxl$,n%,1)):tmp$=tmp$+String$(nmb%+1,co$)
 Next
 expand$=tmp$
End Function
colors:
'--Colorscheme accordung to matherp
Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED)
Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE),RGB(MYRTLE)
Data RGB(COBALT) ,RGB(MIDGREEN),RGB(CERULEAN),RGB(RUST)
Data RGB(FUCHSIA),RGB(BROWN),RGB(LILAC)
Tree:
Data "00000000000000808000AAAAAAAA3AAAA3E3A2A2A0AAA2A08080000000000000"
Data "0000000000000A22A0A2A2A2A2AAACE4EE4EBE2EAAA2AA080000000000000000"
Data "00000000000000000000000000A0A2A3EEEE40E2A2A000000000000000000000"
Data "000000000000000000000000000E0E0EE4CCCC0E0E0000000000000000000000"
Data "00000000000000000000000000000004CCCE0000000000000000000000000000"
Data "00000000000000000000000000000004CC4C0000000000000000000000000000"
Data "00000000000000000000000000000004CCCC0000000000000000000000000000"
Data "0000000000000000000000000000000CCC4E0000000000000000000000000000"
Data "0000000000000000000000000000000CCCCE0000000000000000000000000000"
Data "00000000000800000000000000000CCCE4EE0000000000000000000000000000"
Data "00000000002820002282000000000E4CCCCCC000000000000000000000000000"
Data "000000000ECC0220E8E0200000000CCCCCC4E000000000000288200000000000"
Data "00000E20E0202020E8E020000000E88EEEEE8E000000288E8228200000002000"
Data "023A0222B82A22828282200000000E0CCECCCE0E0000222222AAE8E002202020"
Data "02E822A82282822A828288888888C22882CCC8282828282A3A2B8828E2E88220"
Data "0232222A22228282828E828282228282C88882A2A820A22AB2ABEA20A20E2820"
Data "002AEAAE0EA0AEE0E0E0E0E00EE0000CC000E0AABE0E0EEAEA3AE0BE3E0003E0"
Data "000E2EEAA2A3322E2E8E82A882EE888A888880202A2B83ABAA22A32AA2882000"
Data "000000EEBEAEAEEAEAEAE0EAEAE02AAE00002AA3E0E0BAABABE0ABAA0B820300"
Data "000000E08EE8E2EEAEAEAEEEAEAAEAEAA2EE8BA0EAEAEE0E00E0E0BEAEBE0E00"
Data "00000000EEAAA8EE0E8E88EE8EE8E8EAE8E8E3E8B8EA8E8E8EA8EAEA2AB20000"
Data "0000000E2A23AE0EAEAE8EAEEE8EA0AEEEA3AAE8E8EA8EAE8A38E3ABEA3E0000"
Data "00000000E2EAEAEAEAEA8E3EAAB82AB8EA3E2E8E0E0EEEABABAE3EB2E2000000"
Data "0000000000EAE88E8E8BEEABEE8EE8E8AEAE8E8EE8E8ABAE3AEEAA3E00000000"
Data "00000000000EAEEE3EEEEAEAEAEE822222AE2E8EEAEEA3AB0EEEAA3E00000000"
Data "00000000000EAABAAAA0E0BEA0B0E0EABAAAE8EA0E3A0EEE0EA3EEA2E0000000"
Data "00000000000EA3EE0EBAB0EBEAEAEAEAEEABE8E3EEEEABAEAE0EAA0EE0000000"
Data "0000000000002AAE30E0EAEE0EEEEE0EA0EAEA8E0AAEEEAA0E0E000000000000"
Data "000000000000EA3BEE0EEA30AAE0EA2E2EEE2222EEA3AEB8EE0EE00000000000"
Data "00000000000EEAEE0EAEEAAEEEABA3A3AEAEAAE8EEA8C3B8A3AA200000000000"
Data "00000000000EA2EEAEAE0EEAEABAAAABABA3BABEAE0ABBE8EE2EE00000000000"
Data "0000000000003E3E0EEAE88E8E8E0E0EEAAAE0E0B0EAEAAAEAE0000000000000"
Data "00000000000000023A03A8EE0E8EAE8E8E08AA8EAB8A38BB83E0000000000000"
Data "000000000000002A3A2A3A3E2EAEAA3EEBEEEEAEEBA8AABB2000000000000000"
Data "00000000000000E02E2E32A3E8A3BE8AAE8E88E8AAAEBB2E0000000000000000"
Data "00000000000000002E00E3ABEABAABEEAAEEE8EEEBA2ABE00000000000000000"
Data "00000000000000000C000CCC2A3E020AAEAAE8E2A3A232E00000000000000000"
Data "000000000000000000000000CC0000C33EE3E8EA0EE0E0000000000000000000"
Data "0000000000000000000000000000000C2E08AE22E00000000000000000000000"
Data "00000000000000000000000000000000C0E22EE0000000000000000000000000"
Data "000000000000000000000000000000000C00CAAC000000000000000000000000"
Edited 2022-09-28 20:58 by Martin H.
'no comment
Posted: 12:00pm 28 Sep 2022
  Martin H. said  example to Scale a Picture
Very nice. Thank you.
Posted: 02:58pm 28 Sep 2022
Thanks for the replies, sorted the for next prob.
Jim- I should have used a trailing space or formatted the str$(vin).cheers.
Martin- brill demo. I would not have thought of scaling sprites. thanks for sharing.
@Lizby- I have used scale function on 8bit basic that has no floats.
I can find the code if you want.  https://www.youtube.com/watch?v=d51PTF8Boh0
I think captain boing's code is a nice demo with syntax usage and real values demo.
Easy to understand... even for me
PS.- Bill. Next val advice is sound but if you indent your code then nested for next loops are readable.. but true.. use a next val to be safe and more readable. Thanks.
Edited 2022-09-29 01:16 by stanleyella
Posted: 04:14pm 28 Sep 2022
  stanleyella said  I have used scale function on 8bit basic that has no floats.
You have to do tricks to come up with values like 4.35 using only integers, like multiplying your initial value by 100 and then displaying the result divided by 100, then with ".", then with remainder of division by 100.
Posted: 04:37pm 28 Sep 2022
True.. it is called improvisation
edit: I can find 5 year old code for gcb that I am now ashamed of like this a-d meter which was a trig learning experience.
I thought you would wonder how the 8bit sin,cos worked.
It used tables :)
Edited 2022-09-29 03:14 by stanleyella
vegipete
Posted: 05:19pm 28 Sep 2022
Very nice indeed! Ausgezeichnet!
That scaling algorithm is remarkably effective. Thank you!
Martin H.
Posted: 01:20pm 29 Sep 2022
It was more for guiding. :-)
There is still room for improvement.
As the routine paints over some pixels that have already been set.
this can be prevented, by changing your view from source to destination.
If a row in destination is just 40 Pixel, then Query just the 40.
'no comment
Posted: 07:22pm 01 Oct 2022
late to the party coz of personal stuff, but... http://www.fruitoftheshed.com/MMBasic.Map-Function.ashx?HL=map
