Forum Index : Microcontroller and PC projects : MMB4L: what are the minimum serial comms capabilities it requires?
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9270 |
Check the output voltage on the data pins while disconnected. Some of these things always use pullups to 5V even if a link has changed VCC to 3.3V. Otherwise, yes, that's the sort of creature. I tend to use bare board/el cheapo ones too. Also a fan of the CH340. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
That module should be fine. If you do look to supplement your supply, I probably have 2 dozen of these, and find them altogether suitable: CH340G PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
