Local Time 04:02 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pointless picomite/ILI9341 demo: autumn in canada
Posted: 10:20am 26 Nov 2021
  PeteCotton said
Yeah - I don't get his/her line of thought.
sometimes, the irrational snobberies in tech (language/CPU/Bits etc...) makes me feel like
Posted: 03:42pm 26 Nov 2021
  scruss said
  JohnS said  What did you try that didn't?
Just tried "mmbasic code" on google.ca.
Top hit: https://circuitgizmos.com/projects/microboard-micromite-projects/mmbasic-code-library/
Click on any of the examples: There has been a critical error on this website
Okay.
Second: https://mmbasic.com/ - it's a description site with links to where you can download the interpreter. Examples? None.
Third hit is Geoff's site.
Pretty much everything below that is spam. Something I wrote on my blog that basically says "MMBasic is available on the Raspberry Pi Pico" (so no real content) appears just below cmm2.fun
I don't want the source code to MMBasic, I want to see and show off what it can do.
That shows how google returns very different results for the same search by different people.
Apparently it thinks it knows what you want but is wrong.
Edited 2021-11-27 01:42 by JohnS
Posted: 03:58pm 26 Nov 2021
  scruss said  It would be nice if there were an archive/demo showcase of MMBasic code somewhere.
I have to admit that I never followed this link before, but in the "Microcontroller and PC projects" section of thebackshed, under "Sticky Topics", after clicking "Micromite MMBasic Library(s)", the second link, "Community driven MMBasic wiki", takes you to fruitoftheshed, "_MMBasic Code Library" section. Clicking "All Pages" gives many entries.
The second post there (just created) also has links.
scruss
Posted: 05:34pm 17 Jan 2023
  scruss said  Source is here: Autumn in Canada: PicoMite version.
It was trivially easy to port to PicoMite VGA. The only part that required some thought was adapting it to the latter machine's limited palette.
' autumn in canada
' scruss, 2023-01 - PicoMite VGA
' a take on my https://openprocessing.org/sketch/995420 for picomite
OPTION base 1
' randomize Timer
' *** initialize polar coords of leaf polygon and colour array
DIM leaf_rad(24), leaf_ang(24), px%(24), py%(24)
FOR i=1 TO 24
 READ leaf_rad(i)
NEXT i
FOR i=1 TO 24
 READ x
 leaf_ang(i)=RAD(x)
NEXT i
DIM integer c%(4)
FOR i=1 TO 4
 READ r%, g%, b%
 c%(i)=RGB(r%,g%,b%)
NEXT i
' *** set up some limits
min_scale%=INT(MIN(MM.HRES, MM.VRES)/8)
max_scale%=INT(MIN(MM.HRES, MM.VRES)/6)
min_angle=-30
max_angle=30
min_x%=min_scale%
min_y%=min_x%
max_x%=MM.HRES - min_x%
max_y%=MM.VRES - min_y%
CLS
TEXT MM.HRES/2, INT(MM.VRES/3), "autumn in canada", "cm"
TEXT MM.HRES/2, INT(MM.VRES/2), "scruss, 2023-01", "cm"
TEXT MM.HRES/2, INT(2*MM.VRES/3), "just watch ...", "cm"
kt%=0
DO
 cx% = min_x% + INT(RND * (max_x% - min_x%))
 cy% = min_y% + INT(RND * (max_y% - min_y%))
 angle = min_angle + RND * (max_angle - min_angle)
 sc% = min_scale% + INT(RND * (max_scale% - min_scale%))
 col% = 1 + INT(RND * 3)
 leaf cx%, cy%, sc%, angle, c%(4), c%(col%)
 kt% = kt% + 1
LOOP UNTIL kt% >= 1024
END
SUB leaf x%, y%, scale%, angle, outline%, fill%
 FOR i=1 TO 24
   px%(i) = INT(x% + scale% * leaf_rad(i) * COS(RAD(angle)+leaf_ang(i)))
   py%(i) = INT(y% - scale% * leaf_rad(i) * SIN(RAD(angle)+leaf_ang(i)))
 NEXT i
 POLYGON 24, px%(), py%(), outline%, fill%
END SUB
' radii
DATA 0.536, 0.744, 0.608, 0.850, 0.719
DATA 0.836, 0.565, 0.589, 0.211, 0.660, 0.515
DATA 0.801, 0.515, 0.660, 0.211, 0.589, 0.565
DATA 0.836, 0.719, 0.850, 0.608, 0.744, 0.536, 1.000
' angles
DATA 270.000, 307.249, 312.110, 353.267, 356.540
DATA 16.530, 18.774, 33.215, 3.497, 60.659, 72.514
DATA 90.000, 107.486, 119.341, 176.503, 146.785, 161.226
DATA 163.470, 183.460, 186.733, 227.890, 232.751, 270.000, 270.000
' leaf colours
DATA 255,0,0, 255,85,0, 255,170,0, 255,255,0
(and now I discover that the SD card on my PicoMite VGA doesn't seem to work, so there was a lot of copying, pasting and editing to get this text here.)
Martin H.
Posted: 07:33pm 17 Jan 2023
'no comment
