Local Time 19:18 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite and RFID reader
Posted: 12:10pm 11 Nov 2021
Don't they run off 20kHz or so?
Posted: 12:14pm 11 Nov 2021
My cat seems to be in an almost perpetual sleep mode - lucky sod.
Edited 2021-11-11 23:58 by thwill
Posted: 01:55pm 11 Nov 2021
  i was actually somewhat serious - referring to the RFID chips fitted inside most models of cat (and dog) manufactured here in the last 10 years or so. i'd like to be able to make an automatic cat door that only lets in authorized felines, but have never managed to find out details of the RFID chips used in NZ.
rob   :-)
Posted: 02:24pm 11 Nov 2021
  robert.rozee said  i'd like to be able to make an automatic cat door that only lets in authorized felines
Wouldn't +that+ confuse the unauthorized ones. Gotta be careful when you start messing with the minds of cats.
Posted: 02:29pm 11 Nov 2021
You know you can just buy these things, Petporte is one such vendor. Or can you not get ones compatible with those wiley NZ cats.
Posted: 03:23pm 11 Nov 2021
The NZ cats go in and out upside down, Tom. It confuses the RFID system because the magnetic waves fall to the bottom.
Posted: 12:10pm 12 Nov 2021
  Gizmo said
My RFID-RC522 module ...
does this help? (arduino instruction but has a good pinout diag)
RC522 kit.zip
Still looks like a lot of faff compared to Grogs' recommendation. Also the tags are different - the predominant flavour seems to be 125KHz where as this reader uses 13.56MHz tags - beware when buying extra cards/tags
Edited 2021-11-12 22:18 by CaptainBoing
paceman
Posted: 12:24pm 12 Nov 2021
Rob, I did this with a MiniMicromite and different RFID reader module back in 2012. Search with RFID and 'paceman' and you'll find some posts.
The frequency used is either 125 or 134 KHz but the reader coil you use needs to be closer than about 25mm. There are several protocols used with the implants, here in Oz it's typically RDX-B but also HDX - different countries can have different protocols. Your vet can show you a new implant in it's package and that'll have the protocol stamped on it. They can also scan your cat to get it's implant number, then you can check if your module's reading right.
It was a fun project but I gave up on it after a few months because of several 'cat' issues. First, friendly cats followed by un-friendly cats are often moving rather quickly resulting in 'congestion' at the door, thus no reading happens. Secondly the range of the reader coil is less than 25mm so you need something to 'line-up' the cat. I used a short length of perspex tube. Thirdly, cats find curfews insulting so if you get the door to stay closed preventing the cat exiting after hours, they'll probably chew the servo mechanism for the door cam to bits - as ours did!
My veterinarian daughter thought I'd done well persevering for the few months it was semi-operational but I then gave up. The cat went back to her normal ways and lived to a ripe old 17 years.
Greg
paceman
Posted: 11:22pm 12 Nov 2021
Gizmo, I just had a quick read of the Captain's link re your RC522 module. Looks like they're using NFC communication at 13.56 MHz. That might be a new 'standard' but I guess it'll depend how old your pets (or vets) are. I remember when I was playing with it the vet's reader wands came from various suppliers and different models could read different protocols. Maybe they've added an NFC coil to the readers these days as well.
Greg
Posted: 11:44pm 12 Nov 2021
The issues of short range and multitude of implant standards might be avoided (depending on the temperament of the cat) with a collar and key-fob for a standard door RFID reader.
PilotPirx
Posted: 11:39am 07 Sep 2026
Hello experts,
I’d like to start a new project with the PicoMite and need to read NFC cards using the MFRC522 RFID RC522 reader (writing to them would also be useful later on).
So, to avoid starting from scratch, here’s my question:
Has anyone ever written a driver for MMBasic for the RFID RC522 reader?
That would be a huge help and save me a lot of time.
