Local Time 14:46 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Minor issue with MMEdit
Posted: 09:35am 09 Jan 2022
  Turbo46 said  This was the SYSTEM command I used:
  Quote          SYSTEM "C:\Users\mckiw\Documents\Micros\DOS Basic\mmbasic.exe asssa.bas"
QUIT
It stopped at the space after 'dos' with an error (don't remember it exactly [...]
try the below, note the extra SINGLE quote marks:
  Quote          SYSTEM "'C:\Users\mckiw\Documents\Micros\DOS Basic\mmbasic.exe' asssa.bas"
QUIT
this (single quotes around just 'DOS Basic') should also work:
  Quote          SYSTEM "C:\Users\mckiw\Documents\Micros\'DOS Basic'\mmbasic.exe asssa.bas"
QUIT
rob   :-)
Turbo46
Posted: 10:46am 09 Jan 2022
Thanks Rob, that may well work, although I don't know how. But I've moved on and removed the space in the path, put a copy of MMBasic.exe in the same folder as the BASIC files. My system command now is:
  Quote          SYSTEM "mmbasic.exe asssa.bas"
QUIT
Having done that, I think it was working without the long path to asssa.bas anyway. Probably because it was in the same folder from which the system command was issued.
Turbo46
Posted: 03:12am 10 Feb 2022
Hi Jim,
In MMEdit 4, I was researching the #INCLUDE function and, while looking in the HELP file under 'Using MMEdit', I found a small typo. In the line near the bottom starting with:
  Quote  On devices with file systems, the file is uploaded as 'temp.bas'. If you hold ...
I think you may have mis-spelled 'Shift'.
Posted: 06:23am 10 Feb 2022
I am surprised that the spell checker didn't find that!
Turbo46
Posted: 04:58am 21 Feb 2022
Jim,
Not really an MMEdit problem but I was searching for 'Clipclean', but couldn't remember its name and couldn't find it on my PC. Finally found it on the 'Forum upgrade' post, and then armed with the name, I found it on my PC.
I for one have found it useful and I was thinking it would be easier to find if it was on your website.
Posted: 05:46am 21 Feb 2022
  Turbo46 said  Jim,
Will do.
Glad you find it useful
Turbo46
Posted: 05:54am 21 Feb 2022
Thank Jim,
I do, because sometimes I type a post in the word processor before copying into TBS.
I hope you fixed that typo too. When first read it I had just come in from cleaning up after my dog and the mental image was not good.
