Forum Index : Microcontroller and PC projects : Interrupt on analog voltage change on Analog Input pin?
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9277 |
In theory, unless the input drops below 0.65v you won't get a high-low interrupt to work. However, I did. Not by design though. :) I rigged up a temporary Micromite and tried it. If you want to be *certain* of it working then you should choose resistor values that pull ain below 0.65v. The resistor network I used wasn't a ladder. I simply switched individual resistors from ain to ground. It made it very easy to test. I just ran the interrupt routine which contained a print pin() statement so I could see the voltage. If there was no interrupt nothing happened, if there was then it gave me the voltage for that resistor. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Changing one resistor would make it more reliable with temperature changes, supply voltage changes or a replacement chip. Better safe than sorry. Bill Keep safe. Live long and prosper. |
| Swartz Newbie Joined: 15/12/2020 Location: United StatesPosts: 18 |
Thanks guys -- I have continued to experiment and have referred to the specs on the device. Having done so - have determined better values for reaching the required thresholds. Thanks! Swartz |
Final idea derived from spreadsheet (I hope I did it right! :) ). 3.3v | 2k2 | ain-+-100-+-100-+-100-+-100-+-100-+ | | | | | | / / / / / / | | | | | | 0v--+-----+-----+-----+-----+-----+ 0 0.143 0.275 0.396 0.5 0.61 Volts 0 44 85 122 157 189 Count This allows up to 6 buttons with detection via interrupt while remaining within spec for Vlow at the input. Maximum current from 3.3v is 1.5mA. I hope it's of use to someone. Edited 2021-03-04 19:47 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
My spreadsheet agrees with yours. Enclosed if it's of any use (Libre Office ods). I would prefer a 10K pullup resistor and I would add a 100nF capacitor from AIN to ground to aid debounce. Voltage Divider Calculator.zip Bill Keep safe. Live long and prosper. |
if you placed a capacitor across each of the 100 ohm resistors, then you could extend the number of switches while still reliably generating the interrupt. with all switches open, the capacitors would be discharged and hence present a brief short when a switch was closed. this (using capacitors across resistors) may work more reliably with each resistor tied back to the Ain pin and using ascending values (rather than a chain of all the same value). fun note: we just had a little earthquake here in christchurch, nz! cheers, rob :-) edit: not so little - was 6.15 magnitude in rotorua, 670km away from here ![]() Edited 2021-03-04 23:40 by robert.rozee |
Still amazed! At the risk of repeating myself or gushing... This board rocks! Cheers! Swartz |
ulp!, Rob.... You don't want too many of those. Bob: IMHO 10k might be a bit on the high side. Aren't you supposed to keep the input resistance below 10k for analogue inputs? I might be wrong. I did actually have 100nF from ain to gnd, but I didn't show it on this diagram. I think it reduces bounce on button release (as it takes time to charge up to >2.5v - it's not necessary on button close as the interrupt occurs once on the falling edge and is then disabled within the interrupt routine. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Yes. The micromite input impedance is >1Meg ohm, 10K could give up to 1% error. Forget I spoke. Rob, I hope all is OK, you don't need another big one. Bill Keep safe. Live long and prosper. |
Magnitude 8 off the NE coast of the north island. We were all set to holiday in NZ a few years ago until a big(ish) quake in Christchurch persuaded us to go to 'old' Zealand instead. I still hope to get across the ditch one day but you will have to stop shaking before the wife will go with me. Jim VK7JH MMedit |
@mixtel90 Just out of curiosity , could something like this be done with voltage drops with diodes in series and switches between them ? As said - just curious. |
I don't think it would be reliable. If you were simply testing the analogue input then yes, but you need a logic 0 (less than 0.65v) on the input to get a reliable interrupt, hence the low voltages from the resistor network. As I managed an interrupt at 1v you could try using 1 or two schottky diodes to give 0.4v or 0.8v - possibly with a 0.65v from an ordinary diode and 0.3v from a germanium one. :) Experimenting is fun but the result might only work with that chip at that temperature on a Thursday. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
If you want more switches reliable on one pin. I suggest following: All switches S1...Sn connect to ground In series with each switch add a resistor parallel to a capacitor. All capacitors are 10nF Resistors are 100k, 81k, 56k, 39k, 22k, 10k, 6.8k, 4.7k, 3.3k, 2.2k, 1.5k Have a common pullup (10k) This will make that each switch has a clearly different voltage, using the whole range of the ADC. And each key will generate a clear interrupt level (0V). +3.3V------10k---------+---------+--------+---//----+--------ADC | | | | 100k//10n 81k//10n 68k//10n 1.5k//10n | | | | SW1 SW2 SW3 SW10 | | | | GND GND GND GND The trick is to wait a little after the interrupt, until the voltage settles. With 100k and 10n that time will be 5ms, others are shorter. Volhout Edited 2021-03-09 07:24 by Volhout PicomiteVGA PETSCII ROBOTS |
Nice idea, Volhout. Is 10k pull up low enough to satisfy the maximum input resistance in the spec though? I suspect it might be - just about - but I think I might prefer something a little lower just to be certain. Mick Zilog Inside! nascom.info for Nascom & Gemini |
If you take into account the input impedance of the micromite pin is approx >1 meg ohm when calculating the analogue input value. 1 meg ohm in parallel with 100k = 90.9k etc. But I agree that lower values may be better, probably using a 100nF capacitor. This is pretty much what Rob suggested. Bill Keep safe. Live long and prosper. |
