Local Time 14:39 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.07.00b11: json support with full ESP-01 example code
     Page 2 of 3
elk1984
Posted: 05:03pm 31 Jan 2021
  Nimue said
  RetroJoe said  At this rate, we're going to need a Maximite Expansion Interface...
I remember networking ZX Spectrums the the interface 1 (https://en.wikipedia.org/wiki/ZX_Interface_1 back when I was a wee girl (~15yo)
Nim
There's definitely some rumblings on this board in that direction
CMM2 Expansion Board
Posted: 06:22pm 31 Jan 2021
  Quote  I've also found my ESP-01 module to not be terribly stable,
It is worth checking the firmware version. The new ones I bought were on old V1.2.x firmware, latest is V1.7.4 and after upgrade the seem to work much better.
Use AT+GMR to check the version
I'll post full details on another thread
Posted: 08:49pm 31 Jan 2021
  matherp said  It is worth checking the firmware version. The new ones I bought were on old V1.2.x firmware, latest is V1.7.4 and after upgrade the seem to work much better.
Looks like I am running an approximation of the latest:
AT version:1.7.4.0(May 11 2020 19:13:04)
SDK version:3.0.4(9532ceb)
compile time:May 27 2020 10:12:17
Bin version(Wroom 02):1.7.4
I don't suppose you know if the ESP8266 is storing any state when it loses power, and how to clear that state ?
It seems like once something goes bad, i.e.
Fatal exception (28):
epc1=0x40001800, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00007ff0, depc=0x00000000
it stays bad even over a power-cycle and I'm not sure what eventually is causing it to clear.
Posted: 09:33pm 31 Jan 2021
AT+RESTORE is the command to do a factory reset.
I would try re-flashing your module anyway in case it have a bad byte or two stored.
Posted: 10:10am 01 Feb 2021
  TassyJim said  AT+RESTORE is the command to do a factory reset.
Thanks for both Jim. I've ordered the necessary doodad and will experiment with "AT+RESTORE" the next time I encounter the issue.
toml_12953
Posted: 05:34am 07 Aug 2021
  matherp said  V5.07.00b11 now available for download
I've added a new edit font OPTION EDIT FONT VERY LARGE for use with high resolution modes and changed the horrible font 3 to a different one that is the same size
This release also supports a json parsing function.
I don't think my ESP-01 is working. The program in this thread doesn't run. It errors out at this line:
if NOT OKwait(4000) then errorexit("AT+CWMODE_CUR=1")
If I run the following, should I get OK back? I get nothing.
open "COM2:115200,512" as #1
print #1,"AT"+chr$(13)+chr$(10)
print input$(2,1)
Edited 2021-08-07 15:48 by toml_12953
Posted: 06:59am 07 Aug 2021
print input$(2,1)
You need a delay before reading the response.
If you are adding the CRLF, add a ; to suppress the system newline.
print #1,"AT"+chr$(13)+chr$(10);
pause 500
print input$(loc(#1),#1)
Then try different baud rates.
If you don't know what firmware your module is running, it is easier to reflash with something that you have the command reference for.
Edited 2021-08-07 17:21 by TassyJim
toml_12953
Posted: 03:08pm 07 Aug 2021
print input$(2,1)
pause 500
Thanks for the response! It turned out to be a bad solder joint. I reflowed the solder and it works OK now. I won't be able to update the firmware version from 1.3.0 since it's soldered in but at least it works. I did download an AT reference and a full manual for it also so at least I know how it works.
mclout999
Posted: 07:45pm 07 Aug 2021
The firmware I see in the download is B4.  Is that correct?
toml_12953
Posted: 10:12am 08 Aug 2021
  matherp said
Attached is some code that uses the openweathermap.org api which is called using an ESP-01 with the default "AT" firmware. You need to substitute your own wifi login details and your own openweathermap api username and key in lines 3, 4, and 14 to get it to work. This is code I previously published to work on the Micromite eXtreme  that works without a single change on the CMM2 - Isn't compatibility wonderful
You can see from the local report why I have so much time for coding
I copied and pasted the code into my program. I have a free Openweather account and changed the three lines to access my WiFi network and Openweather account. When I run the program, I get this:
Weather for
Temperature is  -273
Pressure is    ain.temp
ain.temp
I've checked my user ID and API KEY a number of times and they're typed correctly.
The network login procedure seems to be going through OK or the program would never reach the output lines.
What might I be doing wrong?
Edited 2021-08-08 20:20 by toml_12953
Posted: 11:50am 08 Aug 2021
  toml_12953 said  What might I be doing wrong?
To find out, you might need to see exactly what is being returned. The easiest way is to unplug your ESP8266 (oops) . . . Plug a spare ESP8266 into a USB ESP8266 module and plug into your PC, connect with puTTY or TeleTerm or your own fav and then manually enter what the CMM2 sends.
Then you can get what the reply is, cut and paste it into a text file on the CMM2, and fiddle with the decoding code until you can see what's what (if it isn't evident when you look at it).
Alternatively, you can cobble a splitter on CMM2 Rx and wire to a USB/ttl-serial module (with 0V also) and spy on the incoming text there.
Edited 2021-08-08 21:52 by lizby
Posted: 12:18pm 08 Aug 2021
I'm not getting a response to CIPSTART today from api.openweathermap.org so can't help. Perhaps they have an issue or have changed something - anyone got anything working with openweathermap?
Posted: 01:44pm 08 Aug 2021
Using a PicoMite, which doesn't have JSON$, after "getinput(10000)", "longstring print m%()" gives this for Liverpool, Nova Scotia:
{"coord":{"lon":-64.7155,"lat":44.0335},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04d"}],"base":"stations","main":{"temp":292.87,"feels_like":293.3,"temp_min":290.01,"temp_max":296.06,"pressure":1017,"humidity":92},"visibility":10000,"wind":{"speed":1.03,"deg":220},"clouds":{"all":100},"dt":1628429640,"sys":{"type":1,"id":549,"country":"CA","sunrise":1628414098,"sunset":1628465642},"timezone":-10800,"id":6057856,"name":"Liverpool","cod":200}
[26] Print "Weather for "+json$(m%(),"name")
Posted: 01:51pm 08 Aug 2021
With an F4 with the same longstring print command, I get this (correct JSON breakout of values):
{"coord":{"lon":-64.7155,"lat":44.0335},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04d"}],"base":"stations","main":{"temp":293.31,"feels_like":293.73,"temp_min":290.01,"temp_max":296.92,"pressure":1017,"humidity":90},"visibility":10000,"wind":{"speed":1.03,"deg":220},"clouds":{"all":100},"dt":1628430685,"sys":{"type":1,"id":549,"country":"CA","sunrise":1628414098,"sunset":1628465642},"timezone":-10800,"id":6057856,"name":"Liverpool","cod":200}
Weather for Liverpool
Temperature is   20.31
Pressure is     1017
overcast clouds
Posted: 02:59pm 08 Aug 2021
This version works on the PicoMite. A very limited, non-generic version of JSON$ is included, and 3 of the 4 calls to JSON$ are modified to fit the limitations of the JSON$ subroutine.
' weather.bas
option explicit
option default none
Dim MYID$="MyID"
Dim APIKEY$="MyKey"
Dim report$="weather"
dim b$= "GET /data/2.5/"+report$+"?id="+MYID$+"&APPID="+APIKEY$
Dim m%(8000)
b$=b$+" HTTP/1.0"+Chr$(13)+Chr$(10)+Chr$(13)+Chr$(10)
if instr(mm.device$,"Pico") then
 SetPin 21,uart0tx:SetPin 22,uart0rx
 open "com0:115200,8192" as #1
elseif instr(mm.device$,"F4") then
 open "com3:115200,8192" as #1
else
 print "COM PORT OPEN COMMAND NEEDED"
 end
endif
LongString clear m%()
print #1,"AT+CWMODE_CUR=1"+chr$(13)+chr$(10);
print #1,"AT+CWJAP_CUR="+chr$(34)+"MyAP"+chr$(34)+","+chr$(34)+"MyPW"+chr$(34)+chr$(13)+chr$(10);
if NOT OKwait(10000) then errorexit("AT+CWJAP_CUR=")
print #1,"AT+CIPSTART="+chr$(34)+"TCP"+chr$(34)+","+chr$(34)+"api.openweathermap.org"+chr$(34)+",80"+chr$(13)+chr$(10);
if NOT OKwait(10000) then errorexit("AT+CIPSTART=")
print #1,"AT+CIPMODE=1"+chr$(13)+chr$(10);
if NOT OKwait(4000) then errorexit("AT+CIPMODE=1")
print #1,"AT+CIPSEND"+chr$(13)+chr$(10);
if NOT OKwait(4000) then errorexit("AT+CIPSEND")
print #1,b$;
getinput(10000)
'longstring print m%()
 Print "Temperature is ",val(json$(m%(),"temp"))-273
 Print "Pressure is ",json$(m%(),"pressure")
 Print json$(m%(),"description")
else
 Print "Temperature is ",val(json$(m%(),"main.temp"))-273
 Print "Pressure is ",json$(m%(),"main.pressure")
 Print json$(m%(),"weather[0].description")
endif
print #1,"+++";
pause 1000
print #1,"AT+CIPMODE=0"+chr$(13)+chr$(10);
if NOT OKwait(4000) then errorexit("AT+CIPMODE=0")
print #1,"AT+CIPCLOSE"+chr$(13)+chr$(10);
if NOT OKwait(4000) then errorexit("AT+CIPCLOSE")
end
function OKwait(timeout as integer) as integer
OKwait=1
timer=0
do
loop until input$(1,1)="O" or timer>=timeout
do
loop until input$(1,1)="K" or timer>=timeout
if timer>=timeout then OKwait=0
end function
sub errorexit(calling as string)
print "AT call timeout from - ",calling
end
end sub
sub getinput(waitpause as integer)
local a$
local j%,i%=-1
timer=0
do
a$=input$(1,1)
If a$<>"" Then
LongString append m%(),a$
' print a$;
if a$="{" then
if i%=-1 then
i%=1
else
i%=i%+1
endif
endif
if a$="}" then i%=i%-1
endif
loop while timer<=waitpause and i%<>0
LongString trim m%(),LInStr(m%(),"{")-1
print ""
end sub
Function json$(ls%(),key$)
 local integer i,j,k,l,m
 local string a,b
 m=1
 json$=""
   i=LInStr(ls%(),key$,m)
'    Print key$,i
   If i Then
     a=LGetStr$(ls%(),i-1,1)
     b=LGetStr$(ls%(),i+Len(key$),1)
'      Print "|";a;"|","|";b;"|";
     If a=Chr$(34) And b=Chr$(34) Then ' found the key
       j=LInStr(ls%(),",",i+Len(key$)+2)
       If j>0 Then
         k=i+Len(key$)+2
         a=LGetStr$(ls%(),k,j-k)
'          Print a
         If Mid$(a,1,1)=Chr$(34) Then ' remove "s
           a=Mid$(a,2,Len(a)-2)
         If Instr(a,"}") Then: a=Mid$(a,1,Len(a)-1): EndIf
         json$=a
         Exit Do
     m=i+Len(key$)
   Else
     Exit Do ' key not found
End Function
Temperature is   21.39
Pressure is     1017
overcast clouds
Posted: 03:01pm 08 Aug 2021
Thanks for testing - good the code is working - don't know why I can't access the internet from my esp - must be a router issue
UPDATE - did a AT+RESTORE on the ESP and now working with the posted code
Edited 2021-08-09 01:29 by matherp
mclout999
Posted: 07:12pm 08 Aug 2021
  matherp said  Thanks for testing - good the code is working - don't know why I can't access the internet from my esp - must be a router issue
I had the Same here.  I did the AT+RESTORE and it worked right away.  I got crap output but I did nothing but add my AP and PW and my username and code.  What else do I need to do to get it localized and reporting right?
toml_12953
Posted: 07:51pm 08 Aug 2021
Adding your details to your account on the website should do it.
mclout999
Posted: 03:58am 09 Aug 2021
  Quote  Adding your details to your account on the website should do it.
Thanks I will log in and see if I can find where to put the info.
EDIT: In "Invoice info", I assume? I filled that in but I still get no info so far.  Maybe it needs to propagate or something.  I will try later.
Edited 2021-08-09 14:30 by mclout999
Posted: 07:03am 09 Aug 2021
  Quote   What else do I need to do to get it localized and reporting right?
Set MYID$ to the code for where you want. Codes are downloaded from the weather site in a json file
     Page 2 of 3
