Local Time 06:43 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Bob’s 4 X inline F&P’s
feix62k
Posted: 09:27am 12 Aug 2008
hi im new to your site just picked up a couple of f@p moters and downloaded some stuff from the backshed question how do you mount the blades on standard f and p shafts?
dont the days seem lank and long when nothing gos right and everthing gos wrong
Posted: 12:15pm 12 Aug 2008
Hi feix62k
A few years ago I was selling some lasercut steel splines for the F&P shaft, but they were costing more to make than I was selling them for. Recently I've been playing around with some plates cut on a waterjet, a nicer finish than the laser cut parts. Will let everyone know in a few weeks if I will be selling them.
Trev does sell a aluminum spline, very strong.
http://www.thebackshed.com/FoundryAndFibreglass
Other options are to weld a plate to the shaft ( but this means filing down the ridge half way down so the shaft can slide out of the two bearings from one end ), taperlocks, or use a Toyota ( Toyota Corolla 1967 to 1974 KE3 ) drive shaft spline with a couple of grub screws. Use the forum search for "toyota".
Gill
Posted: 12:30pm 12 Aug 2008
G'day feix62k,
I made a prop hub using the spline from the F&P agitator.
It worked well, in fact it's still working now.
I guess a lot depends on your skills and resources.
here's a link to the old thread. Link
I hope you find something to suit.
Cheers Gill _Cairns, FNQ
