Local Time 13:38 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.04RC1
Posted: 11:31am 19 Jul 2020
RC5 now available - fixes some bugs using integer arrays with MATH commands V_PRINT, M_PRINT, SET, and SCALE
mkopack73
Posted: 03:58pm 19 Jul 2020
Ok not sure if this is a bug or not -
If I have the nunchuk plugged in and do a Wii classic open it works (and Vice versa).
I assume this is ok since it’s the same i2C protocol and data flowing. I assume we need to query the T option to determine which was actually plugged in? I assume you also didn’t do the check internally to keep the 2 from failing if the opposite command was used because of the desire to use these commands for talking to other i2C devices?
Also, I’m confused on the: on error skip N
I put that before the open classic call to try to skip the 2 lines after it (a print and then the close) but it always seems to execute the print. I’m not sure what I’m doing wrong.
Any chance in the future of getting an ON Error goto label. ??? (Thinking rudimentary equivalent to C++/java try/catch handling )
Edited 2020-07-20 02:00 by mkopack73
Posted: 08:06pm 19 Jul 2020
On CMM2, is there a convenient way to read a file into a longstring variable?
Posted: 10:21pm 19 Jul 2020
  lizby said  On CMM2, is there a convenient way to read a file into a longstring variable?
No one step method but easy enough with a few lines of code
INPUT 255 bytes into a normal string and then LONGSTRING APPEND
repeat until EOF reached.
Posted: 10:44pm 19 Jul 2020
Thank, Jim, that's just what I've been doing.
Posted: 10:11am 21 Jul 2020
BUG: Still something fishy going on with * and command-line arguments
Colour Maximite 2
MMBasic Version 5.05.04RC6
Copyright 2011-2020 Geoff Graham
Copyright 2016-2020 Peter Mather
> list "test.bas"
Print Mm.CmdLine$
> *test "test"
"test"
> *test "testa"
"testa"
> *test "testab"
"testab"
> *test "testabc"
Error: Expression syntax
> *test testabc
testabc
> *test testabcde
I can think of no obvious reason for the "Expression syntax" errors that occur when the cmdline length reaches 9 characters.
