Local Time 20:22 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite F4: SSD1963 adapter
     Page 2 of 3
Chopperp
Posted: 01:22pm 05 Aug 2019
Hi stepper / Trevor
Welcome to the forum. Trust you are doing better than the English cricket team ATM
Not sure if any of the UK members have any for sale but I should be able to post you one when they arrive.
I haven't worked out payment methods yet. Will advise.
Brian
ChopperP
stepper
Posted: 02:34pm 05 Aug 2019
Hi Brian,
Many thanks. I have been following the forum for several years but have just not needed to post. I am re-building the control gear for my CNC gear cutter and hope to move over to the the F4 from an Extreme(which works very well) and am using an ER 9" screen. I enjoy new challenges as there was no need to movefrom the Ex252.
Trevor
Edited 2019-08-06 00:35 by stepper
Chopperp
Posted: 09:44pm 05 Aug 2019
Hi Trevor
You're welcome
I did notice your joining date after I posted.
Sounds like an interesting project. Do you have link to the screen you are using?
I'm just pottering around at present. Nothing major. Still learning the ropes with these things.
Brian
ChopperP
Decoy
Posted: 04:44am 06 Aug 2019
I am sorry for being a nOOb here, but what is the project regarding these 'vet6 black boards'? I have several of them lying around - are there any chance of them being able to run MMBasic?
Thanks!
Posted: 05:28am 06 Aug 2019
  Decoy said  I am sorry for being a nOOb here, but what is the project regarding these 'vet6 black boards'? I have several of them lying around - are there any chance of them being able to run MMBasic?
Thanks!
You need to read this thread:
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=11324#133816
I think everything needed is there.
I haven't play with these yet (but have some on order).
I do have some of the other STM boards that are great for running MMBasic.
Edited 2019-08-06 15:30 by TassyJim
Chopperp
Posted: 07:09am 06 Aug 2019
FYI
Adaptor boards are on the way.
Thank you for your order from JLCPCB. It’s our pleasure serving you. We are pleased to inform you that the items listed below have been shipped via DHL International Express.
STM32F407_Y1 10
Payment probably by PayPal, EFT or bartering
Brian
ChopperP
Decoy
Posted: 03:19pm 06 Aug 2019
Thanks!
As far as I can see (at work now), it seems that integration of an LCD-screen
is being looked into; what if I wanted to use regular VGA etc. like on the UBW32
or similar?
Which STM boards have you used? Something like the Blue Pill?
Thanks!
Posted: 04:34pm 06 Aug 2019
  Decoy said  As far as I can see (at work now), it seems that integration of an LCD-screen is being looked into; what if I wanted to use regular VGA etc. like on the UBW32
or similar?
Thanks!
The Armmite F4 MMBasic port uses the STM32F407VET6 module found here
The LCD which that board supports natively is also available on that site.
The Blue Pill doesn't have enough flash to run MMBasic.
This STM32F4 doesn't support VGA. The stm board linked to has a header for a 3.2-inch TFT LCD panel. The adaptor which is the subject of this thread allows larger SSD1963-type panels to be used--4.3", 5", and 7". Still larger 8" and 9" EastRising SSD1963 panels will work if you additionally use Grogster's adaptor: here
Edited 2019-08-07 02:37 by lizby
Decoy
Posted: 05:13pm 06 Aug 2019
Thanks for your answer, I appreciate it. Sad to hear that the VET6 does not
support VGA - any other boards that CAN run MMBasic?
I am not keen on those smaller LCD displays, sorry for holding up the thread :)
Posted: 11:46pm 06 Aug 2019
  Decoy said  I am not keen on those smaller LCD displays
Are you specifically tied to VGA? The Pi-cromite MMBasic port supports hdmi output, which means you can have a display as large as your TV (assuming you have a relatively recent one), or with an hdmi projector, as large as the wall you can project on.
Chopperp
Posted: 07:40am 07 Aug 2019
The Micromite eXtreme 100 & 144 pin versions both support VGA displays.
ChopperP
stepper
Posted: 01:45pm 07 Aug 2019
Hi Brian,
Sorry about delay replying, have been at a garden railway meeting all yesterday! Thanks for your updates.
I used the display in the link below, all that was needed was to change over the existing jumpers J3 and J4 - un-solder as supplied and connect the other.
The screen then worked perfectly with any program I loaded. The whole thing was surprisingly painless. You will need the adaptor pcb as mentioned in the thread in the paragraph below.I have used it on the E100 and the Extreme 144. I did make a small ali extension plate to make it "backpack" and a couple of nylon stand-offs to relieve the strain on the adaptor and 40 way socket. I can send details if or when you need them
If you look at page 2 of the forum topics pages you will find a thread EastRising 7,8,9" e100 adaptor by Grogster from 1st August, it details setting up the micromite and which options to choose when on the Buy Display site.
http://www.buydisplay.com/default/9-inch-tft-lcd-module-touch-display-w-ssd1963-controller-board-for-arduino
Please do shout if you need any more help/info/pictures.
Trevor
Edited 2019-08-07 23:46 by stepper
Chopperp
Posted: 02:33pm 08 Aug 2019
The adaptor boards arrived this morning.
Just checked my emails again & there was a photo of them at my front door. Still there. (We rarely use our front door)
They look really good:
For:-
paceman (2 off)
disco4now (2 off)
stepper (1 off)
bigmik (1 off)
(& anyone else I've missed...1 or 2 spare).
Could you please PM me your addresses & confirm number required & payment method so I can send them to you. (Not particularly worried about immediate payment)
Boards will be AU$2.00 ea plus postage.
I also have 6 x 40 pin female headers @ $2.50 ea on hand if anyone needs any with their boards. I do have more (& cheaper ones) on order but they will be a while coming.
@Grogster. Just noticed your reply.....
  Grogster said
  Chopperp said  Hey Grogster
Are you going to get any of Matherp's F4 adaptor boards made up for sale?
Be interested in some.
I was going to, but I am late to this thread, so you can do them!
Done....
Thanks.
Brian
ChopperP
Chopperp
Posted: 03:02am 09 Aug 2019
FYI
Boards etc should be in today's mail for:
paceman (2 off + Header)
disco4now (2 off)
stepper (1 off)
Sent a PM to bigmik
Brian
ChopperP
paceman
Posted: 12:26pm 09 Aug 2019
Hi Brian,
Thanks for your PM reply. I tried to reply back via PM but couldn't find a "SEND" button. How did you do it?
Reply was:
Great, thanks Brian I'll let you know.
Yea it's blowing a gale here and bl..y cold, well 8 deg anyway. Worst part is no sun, Melbourne has heaps of 'clag' days as we call them and they're depressing, no wonder the Russians drink! I had two weeks up in Noosa back in mid July and it seems a lifetime ago now.
Greg
Chopperp
Posted: 02:03pm 09 Aug 2019
Got the message ok.. It's the Save button. Bit confusing.
Boards posted.
Still a couple spare if anyone else wants one.
Brian
ChopperP
paceman
Posted: 11:45am 15 Aug 2019
Hi Brian,
boards arrived today so thanks again for the organising. They look nice and neat so I'll have to get into the F4 soon -  that'll be interesting!
Can you PM me an e-mail or whatever so I can Paypal to you.
Greg
Chopperp
Posted: 12:18pm 15 Aug 2019
@paceman
Good to hear.
Will do although PP wants most of our money.. Both ends it seems.
Brian
ChopperP
paceman
Posted: 01:23pm 15 Aug 2019
Yes, I was afraid of that. I've sent you a PM.
Greg
Chopperp
Posted: 08:27am 17 Aug 2019
@Greg (paceman)
I sent you a PM in case you missed it
Brian
ChopperP
     Page 2 of 3
