Local Time 09:38 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : String problem
palcal
Posted: 12:31am 07 Apr 2019
@ TassyJim
If Loc(#1)<>0 Then
D$=Input$(1,#1)
Weather$=Weather$+D$ ' Weather$ contains all the data
Loop Until D$=Chr$(13)
D$="" 'clear end of line flag
Close #1
Print "Weather$ ";Weather$
Print Len(Weather$)
If Asc(Weather$)<32 Then Weather$=Mid$(Weather$,2,13)
OutTemp$=Left$(Weather$,2)+"`" 'split up Weather$ to regain data
OutHum$=Mid$(Weather$,3,2)+"%"
Rain$=Mid$(Weather$,5,3)
RY$=Mid$(Weather$,8,3)
RYear$=Right$(Weather$,3)
Rainfall$=Rain$+" "+RY$+" "+RYear$
Weather$="" 'clear Weather$
This is the code, I don't see what else I can do to clear the buffer.Edited by palcal 2019-04-08
Posted: 01:35am 07 Apr 2019
This should clear any left over characters in the system.
pause 20
junk$=Input$(Loc(#1),#1)
An alternative way to capture the data:
If Loc(#1)<>0 Then
pause 100 ' wait long enough for all text to arrive. Time depends on baud rate
Weather$==Input$(Loc(#1,#1) ' grab everything
RYear$=Mid$(Weather$,11,3)
In both cases, the PAUSE time depends on the number of characters and the baud rate.
The values given are probably way too high (but longer than needed works OK)
palcal
Posted: 02:59am 07 Apr 2019
@ TassyJim.
Thanks I think that has fixed it.Edited by palcal 2019-04-08
Turbo46
Posted: 06:31am 07 Apr 2019
Palcal,
I don't know if this helps but it works for me:
  Quote  '
OPEN "Com1:9600,,RxMsg,5" AS #1
' Receive the master's message
SUB RxMsg
RXD$ =
Cnt =
0
DO
IF LOC(#1)<>0 THEN
RXD$ = RXD$ +
INPUT$(1,#1)
Cnt =
0
ELSE
PAUSE 5 ' Wait longer than 1 character
Cnt = Cnt + 1
ENDIF
LOOP UNTIL Cnt = 2
END SUB
' Send the Response message
SUB TxMsg
PRINT #1, TXD$;
END SUB
It's part of a Modbus slave. The messages are variable in length and can end in any character (ie. a CRC). The end of the message is detected by waiting for a period of more that two character lengths with no character being received.
The message is received in an interrupt routine - it's a bit long but the slave has nothing else to do until the master tells it what to do anyway.
palcal
Posted: 07:05am 07 Apr 2019
Thanks for that Bill but my code is working OK now, I have saved your code and will keep it in mind.
