Local Time 02:05 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite - MMedit My wishes for 2019
goc30
Posted: 05:41pm 06 Jan 2019
  TassyJim said
What I want to do is differentiate between the same variable name in different SUB/FUNCTIONs. I will also need to look for DIM statements to do that so something like your request is likely.
First, I have to redo the Syntax file system to try and catch up with the ever growing range of devices and MMBasic versions.
Without a correct syntax file, looking for user variables is unreliable.
Hi Jim
I understand your problem, but for "*", first time, you can just work with "Dim", "Const" and "Local"
Turbo46
Posted: 07:26am 07 Jan 2019
There is one that would be nice in MMEdit from a post by KeepIS. Function folding as an option, where only the first line of a function is shown with a + or - as the first character on the line to expand or contract the function (or sub).
E.G.
+ Function Max(a,b)
Posted: 07:33am 07 Jan 2019
  Turbo46 said   There is one that would be nice in MMEdit from a post by KeepIS. Function folding as an option, where only the first line of a function is shown with a + or - as the first character on the line to expand or contract the function (or sub).
E.G.
+ Function Max(a,b)
Folding is unlikely until I port MMEdit to a more powerful language.
I have pushed things as far as I can go.
I can do it with a better compiler:
No timeframe
Edited by TassyJim 2019-01-08
circuit
Posted: 09:20am 07 Jan 2019
That looks like a VERY worthwhile and valuable addition to MMedit. Much encouragement to translate "No timeframe" into "as soon as I possibly can..."
Really looking forward to the next edition!
paceman
Posted: 10:30am 07 Jan 2019
For the MM+ I'd like to see the BLIT command with the capability to 'erase' a given colour (or preferably colours) on the source area, during or after it has copied it to the destination area. The erased pixels would presumably then be made the background colour. Another help would be a parameter to clear the source area after copying to the destination area.
This would greatly facilitate scrolling graphs because currently when 'static' parts of the source area need to be kept (e.g. grids, scales, etc.) but new data needs to be plotted into the 'cleared' source area, the only option is to clear (overwrite) the source area then re-construct the required static parts.
A complication of this is static and dynamic pixels that have been overlapped, e.g. data points that are plotted on a gridline. I'm not sure how that can be handled but maybe Geoff could think of a solution.
Greg
Posted: 03:03pm 07 Jan 2019
Blit would let you have:
1. the source area with static parts i.e. grids etc but otherwise cleared
2. each time copy it to a temporary source where you plot new data
3. finally you blit that to the destination
and throw the temporary away (well, repeat from step 2)
So no need for that clearing of a source colour.
JohnEdited by JohnS 2019-01-09
erbp
Posted: 11:13pm 07 Jan 2019
For the MMEdit wishlist:
It would be nice if the state of the 'Show Column marker' option (in the 'View' menu) could be saved between sessions. I use this option all the time, but each time I start MMEdit the option is reset and I have to go set it again. No biggie I know, but having it remember the previous setting would be great.
Thanks,
Phil.
paceman
Posted: 05:33am 08 Jan 2019
  JohnS said   Blit would let you have:
That's a workaround for me John - with some changes.
1. As per yours. After the display and static areas are first set up, use BLIT READ #1 to store a clean (un-plotted) area at the right of the plotting area.
2. Plot data right to the end of the plotting area (there is a second scale at extreme right of the screen, past the plotting area). No need for a 'temporary plotting area'.
3. When at end of plotting area, use BLIT in a FOR loop to shift (copy) alternate sections of the plot left, starting with the source area one section to the right of the left end of the plotting area. The first section is discarded automatically by being written over.
4. The previously plotted section at the right end of the plotting area is still there (because it has been copied to the left with the previous FOR/BLIT loop, so now use BLIT WRITE #1 to overwrite it with the stored 'clean' static section.
5. Press on plotting from point 2. We are now scrolling - hopefully!
Greg
Posted: 05:53am 08 Jan 2019
  erbp said   For the MMEdit wishlist:
Something I should have done from the beginning.
I will put on the to-do list.
Done:
It was remembering the column number but not whether to show or hide.
2019-01-08_164514_MMedit.zip
Jim Edited by TassyJim 2019-01-09
erbp
Posted: 07:40am 08 Jan 2019
Done:
Thanks Jim - works a treat!!!
Cheers,
Phil.
goc30
Posted: 08:04am 08 Jan 2019
Hi Jim
good job
I have resolved my problem (search vars declared or not)
in my progs, all vars are declared on top of file.
for exemple: all "dim" and "const" are between line 1 and line 250
It mean that the first line number is :
less than 250 -> var declared but not use (if I have only 1 line number)
More than 250 -> var not declared
thank jim
karjo238
Posted: 08:10am 16 Jan 2019
  Geoffg said
For some reason we have lately been getting a lot of suggestions based on the C language. Are people moving from C to BASIC?
A bit late to the party, but in my case, it's just that I've been messing around with Javascript, Python and C, and some of the conventions used therein I thought might be applicable to BASIC without ruining what BASIC sets out to be.
Joseph.
