Local Time 16:02 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.00.02 betas
     Page 19 of 23
Posted: 08:58am 27 Feb 2025
I'll have to try that. The YD should be ok.
ville56
Posted: 09:47am 27 Feb 2025
strange behavior after executing OPTION EXPLICIT
> list system i2c
HEX  0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
00:
[LIBRARY] addr = y * 16 + x
Error : ADDR is not declared
> list system i2c
[LIBRARY] Dim integer x,y
Error : x already declared
> list system i2c
Error : x already declared--
Situation can be cleared with NEW. If OPTION EXPLICIT is entered on the commandline it is ok, but if in a program the error will show up after first RUN.
Version is 6.00.02b11 on RP2350A.
Regards, Gerald
73 de OE1HGA, Gerald
Posted: 10:14am 27 Feb 2025
This is correct. Library code must follow the normal rules for variables. If you set OPTION EXPLICIT then any variable used in the library must be explicitly defined. If you have executable code in the library that is not in a subroutine it will be executed whenever a Basic command is executed.
ville56
Posted: 11:48am 27 Feb 2025
Peter, could you please also DIM variable "addr" in the library for "list system i2c" command as this seems to be the cause of the trouble.
Posted: 12:57pm 27 Feb 2025
  ville56 said  Peter, could you please also DIM variable "addr" in the library for "list system i2c" command as this seems to be the cause of the trouble.
Maybe addr should be a local.
Posted: 01:06pm 27 Feb 2025
V6.00.02b14 posted
Fixes bug in LIST SYSTEM I2C using an undeclared variable
Fixes a bug in ADC conversions when CPU speed is > than about 250MHz
Fixes a bug in MM.END not being called properly
As soon as I get some feedback on any unsupported gamepads I will be moving to release candidate status for V6.00.02.
dddns
Posted: 03:02pm 27 Feb 2025
I am very happy and can confirm, that the ADC bug is gone on RP2040/378Mhz and PGA2350/352Mhz!
Another very nice new world is:
> timer=0:blit 0,0,400,0,399,479:?timer
97.577
That is about 5Mb/s ?! Fantastic
Is it possible to make the framebuffer color depth configurable like 8bit?
Thank you!
Edited 2025-02-28 01:04 by dddns
twofingers
Posted: 10:16pm 27 Feb 2025
  matherp said  V6.00.02b14 posted
Can confirm that fix! Thanks.
MM.END now works in the library but also when stored in the main program.
Michael
Posted: 10:46pm 27 Feb 2025
V6.00.02b14 VGA version seems to be running ok on a YD-RP2040 at 252MHz. IIRC it has done previously because of some tweaks to memory timing, but it's nice to know it still works. :)
ville56
Posted: 08:01am 28 Feb 2025
"list system i2c" works, many thanks Peter !!
Gerald
Posted: 09:34am 28 Feb 2025
Hi Peter,
Thanks for the larger heap in the 2040 VGA build (b14). From here we can build further on Kong.
dddns
Posted: 12:02am 01 Mar 2025
PicoMiteRP2040USBV6.00.02b14:
While writing a blit close to the boundaries with parts of the blit being out of
bounds, this out of bounds drawing seems to take memory during the process. I'm not sure but this behavior might be unwanted instead of discarding the data.
Posted: 05:34pm 01 Mar 2025
V6.00.02b15 posted
New functionality from Geoff - with thanks
Now supporting  BYVAL & BYREF.  BYVAL & BYREF are prefixes that can be applied to parameters in the definition of a sub or function.  BYVAL will force the interpreter to use the value of the supplied argument even if a variable is supplied.  BYREF informs the interpreter that a variable is expected and if that is not supplied it will throw an error.
Additional parameter for OPTION LCDPANEL paralleldisplaytype (e.g. SSD1963_7[_16])
OPTION LCDPANEL display, orientation [,backlightpin] [,DCpin] [,NORESET] [,DB0pin]
The new parameter only applies to the RP2350B and allows the starting pin for the 8 or 16 data pins to be specified (defaults to GP0)
e.g. OPTION LCDPANEL SSD1963_4_16, LANDSCAPE,,,GP36,,GP2
This allows SSD and other parallel displays to be used on the new 64-pin DIL development board
Support for three new gamepads including the THEGAMEPAD
bfwolf
Posted: 09:04pm 01 Mar 2025
  matherp said  V6.00.02b15 posted
@Geoff, @Peter: Brilliant !!!
Option explicit
Dim x As integer = 3, y As integer = 4
Print AddInt(x,y), x, y
IncVar(x)
Print x
IncVar(10)
End
Function AddInt(byval a As integer, byval b As integer) As integer
 AddInt = a+b
 a = a+1
 Print a,AddInt
End Function
Sub IncVar(byref z As integer)
 z = z+1
 Print z
ESC:Exit  F1:Save  F2:Run  F3:Find  F4:Mark  F5:Paste  Ln: 1  Col: 1      INS
> run
4       7
7       3       4
4
4
[6] IncVar(10)
Error : Variable required for BYREF
Works, as described!
Greetings, bfwolf
javavi
Posted: 09:12pm 01 Mar 2025
This already pulls at a major version, like Ver 6.01
Posted: 11:13am 02 Mar 2025
Hi Peter,
The essential code is the TEXT command that (in PETSCII) shows the game loop time usage. However in this framebuffer setup (same as petscii), the text statement prints the timer value (1), but not the leading zero's. Any idea ? Is the ink color not used for "00" but it is for the "STR$()". I am trying to write text to layer L.
This is 2040 VGA b14.
 'screen
 mode 2
 FRAMEBUFFER Layer 9
 FRAMEBUFFER write n
 Color 0,RGB(white) : CLS
 FRAMEBUFFER write l
 CLS RGB(magenta)
 timer=1
 Text 10,200,right$("00"+Str$(timer,3,0),3)
 do:loop while inkey$=""
 end
Edited 2025-03-02 21:16 by Volhout
Posted: 12:23pm 02 Mar 2025
What a convoluted way of doing something that is fully supported
TEXT 10,200,str$(timer,3,0,"0")
bfwolf
Posted: 01:23pm 02 Mar 2025
Forgot to explicitly say many thanks in my former post..
@Geoff: Don't you think, this wonderful new feature would be worth included into the Windows version? As this is really a great improvement of the language regarding readability and bug avoiding..
I took a short look into the sources at
https://github.com/UKTailwind/PicoMiteAllVersions
and saw it's probably mainly done in MMBasic.c/h which I suppose are the "core" files..
@thwill: Same with MMB4L..
Thx again, bfwolf
dddns
Posted: 03:14pm 02 Mar 2025
phrasing in manual got me confused too.
> timer=1:print right$("00" + Str$(timer,0,0),3)
001
> timer=10:print right$("00" + Str$(timer,0,0),3)
010
> timer=999:print right$("00" + Str$(timer,0,0),3)
999
> timer=1000:print right$("00" + Str$(timer,0,0),3)
000
bfwolf
Posted: 09:22am 03 Mar 2025
I'm also "a little bit confused"..
From the latest manual:
> list
Option explicit
Dim i As integer, t As float
Timer = 0
t = Timer
Print Timer, t, Format$(t, "%08.3f")
For i=0 To 1000000
Next i
t = Timer
End
> run
0.049   0.022  0000.022
6577.698        6577.677       6577.677
@Geoff, @Peter:
Could it be, that "Timer" gives milliseconds with microseconds (3 digits after the dot) resolution?
> option list
PicoMite MMBasic RP2350A Edition V6.00.02b15
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED  150000 'KHz
     Page 19 of 23
