Local Time 05:08 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beta Testers Wanted
     Page 18 of 26
MOBI
Posted: 08:30pm 29 Jan 2014
Hi all, now I can get serious.
I tidied the test jig up a bit. Still need to have the 14049 inverter fitted until my proper USB serial kits turn up. Also shortened the leads on the 10uF Cap.
What are others using?
My unit is powered from a LM317 3.3v regulator Downwind made about umpteen years ago.
The USB serial cable is a CH340. It has ttl voltages but RS232 polarity hence the inverters. The 14049's will work ok at 3.3v.
David M.
Posted: 09:24pm 29 Jan 2014
Now... to find some bugs!!
Amazingly, all the bugs found so far have been in the documentation.
Posted: 10:39pm 29 Jan 2014
  MOBI said  What are others using?
Do you mean cap wise or serial port wise?
If you mean cap, I am using a 47uF 16v tantalum, and if you mean serial port, I am using a native serial port(not a USB adaptor) on a Gigabyte E350N WIN8 motherboard.
Posted: 10:40pm 29 Jan 2014
  Geoffg said   Now... to find some bugs!!
What about entering more then 6 digits for the PIN number?
Posted: 11:03pm 29 Jan 2014
The documentation said that you should not do it. A bug is something rather more than that.
atmega8
Posted: 11:16pm 29 Jan 2014
Geoff,
does it mean there is somthing like a bug errata in the docu?
In the user manual ver 4.5 beta3 i can't find something like this.
Or does it mean that there are no known bugs so far, except the bugs sitting in front of the monitor;-)
THX
vasi
Posted: 11:28pm 29 Jan 2014
  atmega8 said   ...
THX
Actually, atmega8 may qualify as a bug (caterpillar) because it have 28 legs
Elvish name: Mablung Miriel
Beyound Arduino Lang
MOBI
Posted: 01:41am 30 Jan 2014
I meant the specific test set up. Photo?
David M.
Posted: 01:51am 30 Jan 2014
  atmega8 said  does it mean there is somthing like a bug errata in the docu?
No, there is no errata. It is important to realise that this is a beta test, not a production release (where I do supply a change log).
In a beta test I need to make changes quickly and that means that the normal rigorous testing and documentation are often not there. Also, you, as a beta tester, are expected to be self sufficient and not require simple support.
In the past companies like Microsoft and Google have used beta test as a promotional vehicle for finished code. This is different, this is the real stuff with bugs and evolving documentation.
So sorry, when the next beta version is out you will have to scan the manual for changes.
Posted: 02:09am 30 Jan 2014
  MOBI said   Hi all, now I can get serious.
that cable looks a lot like it has a db9 connector on the end, which almost certainly guarantees that you're dealing with rs-232 levels at that point - and explains why you need an inverter. please do correct me if i am wrong.
btw, i've always had good success with silicon labs CP2102 usb to serial bridges, which can be had for around us$2.30 on ebay (including delivery) and which haven't been cloned like the prolific chips. the TTL output levels of the CP2102 are 3v3 compliant, and the onboard regulator is good for 74mA (100mA-26mA running current)
http://www.ebay.com/itm/400565980256
http://www.silabs.com/Support%20Documents/TechnicalDocs/CP21 02-9.pdf
rob :-)
MOBI
Posted: 02:40am 30 Jan 2014
  Quote  that cable looks a lot like it has a db9 connector on the end, which almost certainly guarantees that you're dealing with rs-232 levels at that point - and explains why you need an inverter. please do correct me if i am wrong
Yes, it has a 9 pin connector but the signal levels are 5V and the polarity is inverted like RS232. As the inverter runs happily at 3.3v, I don't have to worry about putting limiting resistors in.
David M.
atmega8
Posted: 09:32am 30 Jan 2014
  vasi said
  atmega8 said   ...
THX
Ok, that's why it didn't work.
I tested everything with an ATMEGA8.
I should us a PIC;-)
atmega8
Posted: 12:19pm 30 Jan 2014
  atmega8 said   Possible Bug?
While transfering a program via xmodem, the terminalprogramm crashed ( Linux);-)
The PIC IS now unresponsible.
A "Factory Reset" by shorting tx an rx wihle power reset didn't work.
I will Programm The pic again, to se if it is broken.
Will take some Time..
FYI:
Left a programmed an working PIC allone under power for some hours.
Programm was not running, just the prompt was shown.
Comming back terminal Programm showed garbage characters.
Shorting tx and rx wihle Power Cycle, no result.
Reflashed The PIC and It worked as before.
No idea what has happened....
Of course i rebooted the PC, checked the com ports and so on.Edited by atmega8 2014-01-31
Posted: 12:33pm 30 Jan 2014
So, after being left, you came back, and typed something - it was garbage. Correct?
Closed and restarted TT and checked settings - still garbage. Correct?
Interesting. I will try an overnight test tonight, and see if the same thing happens to me.
Might be worth you running a blinking LED in your next overnight test, to see if the LED is still blinking the next morning, or has the MMBasic interpreter crashed for some reason relating to time.
atmega8
Posted: 05:25pm 30 Jan 2014
Grogster, correct.
Same thing with a friend of me.
The only equal is, that we bought the same Pic's from the same charge/ distributor.
Type is 32MX150F128B-ISP.
And my via usb-ttl converter connected PC went into sleep/powersave mode...
I have also attached a100nf xr7 between +/-.
The microchip datasheet advised this.
Edited by atmega8 2014-02-01
MOBI
Posted: 05:36pm 30 Jan 2014
  Quote  So, after being left, you came back, and typed something - it was garbage. Correct?
I think that if you are getting garbage when you type, there is still a link operating. Just that something like baud rate etc is corrupted?
I left mine on all last night and it was still quite happy this morning as it is now.
If I give it a hard reset or cycle the power it all continues to works as it should.
I'd be loth to blame the 47uF cap either. I tested mine with a cheap 10uF 35v electro and it worked quite well.
David M.
Posted: 05:59pm 30 Jan 2014
Could it be anything to do with the ISP suffix?
Specified part number was PIC32MX150F128B-50I/SP for the DIL.
MOBI
Posted: 06:28pm 30 Jan 2014
A bug??
None of my chips (6 off) will read analogue on pin3. Analogue works quite happily on all other pins designated.
The data sheet for the series says pin 3 is AN1??? Should work??
David M.
atmega8
Posted: 06:30pm 30 Jan 2014
I will blink a LED and let the PIC in running state.
I' ll be back in xx hours...
Posted: 08:25pm 30 Jan 2014
  Grogster said   Could it be anything to do with the ISP suffix?
That would only matter if you want to run the uMite at 48Mhz.
The ones without the "50" run maximum at 40Mhz.
When starting a uMite it will run at 40Mhz, you have to change the speed with a command to get the 48Mhz.
     Page 18 of 26
