Local Time 15:03 01 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Newie got a few questions
     Page 17 of 25
lew247
Posted: 12:40pm 23 Dec 2016
This "seems to work" However it doesn't clear the serial buffer, it keeps adding all the serial data to the next input and prints everything until I get this error
"String too long"
Also the routing to check if "STX is the first 3 characters recieved and the data contains * doesn't seem to be working, yet it doesn't throw any errors
[code]Open "COM1:19200, 100" As #1
DO
B$ = B$+ Input$(254, #1) 'Suck everything in buffer out AND ADD TO B$
IF Left$(B$, 3) = "STX" Then IF INSTR(B$,"*") THEN Print B$ 'IF com port STX as first 3 characters AND contains "*" Then ......
pause 10
END IF
LOOP[/code]
disco4now
Posted: 02:27pm 23 Dec 2016
Add this as shown below.
B$="" ' Clear the string to started gathering the next message fresh.
  lew247 said   This "seems to work" However it doesn't clear the serial buffer, it keeps adding all the serial data to the next input and prints everything until I get this error
"String too long"
DO
pause 10
END IF
LOOP[/code]
F4 H7FotSF4xGT
lew247
Posted: 12:57am 24 Dec 2016
My code is now
[code]
DO
END IF
pause 10
LOOP[/code]
The STXG string prints perfectly
However the STXT and STXW only prints rarely
I've even changed the STXT and STXW strings to this
[quote]For AA = 1 to 10
Print #2, "STXT " , "," , year,",",month,",",day,",",Left$(Time$, 2),",",Mid$(TIME$, 4,2),",",Right$(TIME$, 2),"*" ' Send correct date/time to Indoor unit to set RTC
next AA
[/quote]
and
[quote]FOR BB = 1 to 10
Print #2, "STXW " , "," , bme280_read_temp()",",pressure",",humidity",",wheading",",wSpeed",",wgust",",hgust",",mmrain",",mmrain2",",hightemp",",h ightemp2",",lowtemp",",lowtemp2",",UVindex",",batt,"*"
next BB[/quote]
I really can't see why they won't print reliably
Posted: 01:58am 24 Dec 2016
Your PRINTs won't end with a *
They'll end with (I expect both of, but at least one of) CR and LF.
So, your next INPUT$ will get CR/LF and that means your LEFT$ will not match STX.
You can either suppress the CR/LF (add a ;) or instead of LEFT$ use INSTR
lew247
Posted: 06:52am 24 Dec 2016
I changed the Left$ to INSTR but it makes no difference, the STXG works perfectly
The STXT and STXW only works sometimes
I just dont get it at all
If anyone wants to see both sets of code they are enclosed
2016-12-24_165253_Code.zip
Posted: 07:30am 24 Dec 2016
You're clearing B$ far too often i.e. in the wrong place!
Imagine being the computer (the mmbasic interpreter). Your program reads a few chars and may have the STX and maybe some more but not the *
Then you pause and clear B$
Next you'll get some more chars, maybe the * as well, but you've already discarded the STX.
JohnEdited by JohnS 2016-12-25
lew247
Posted: 07:34am 24 Dec 2016
I'm trying to do it so B$ clears once I have done all I want with the data and it's empty for when the next set of data comes in
The data is arriving at 19200 Baud
Posted: 07:35am 24 Dec 2016
That's very slow compared to your program.
Don't clear B$ where you do.
lew247
Posted: 08:23am 24 Dec 2016
I changed it to 100ms delay before it cleared B$ but it makes no difference
I did try other values as well all the way from 10ms to 500ms in 10ms steps
STXG works all the time
STXT works "sometimes"
STXW works rarely
Posted: 04:23pm 24 Dec 2016
lew247: use the following code, changing the OPEN statement to match your serial port speed and number of stop bits.
' configure circular line buffer
Dim CB$(10)
head = 1
tail = 1
A$ = ""
B$ = ""
Open "COM1:9600,1024,isr,S2" As #1
' main loop
If head<>tail Then ' collect sentence from buffer
B$ = CB$(tail)
tail = (tail Mod 10)+1
if B$<>"" Print B$
B$ = ""
End ' end of program
Sub isr ' serial port handler
Local I, S$ length 80
S$ = Input$(72,#1) ' grab data into temporary buffer
A$ = Right$(A$,255-Len(S$))+S$ ' add to end of linear buffer
I = Instr(A$,Chr$(13)+Chr$(10)) ' check for eol marker (CR+LF)
If I<>0 Then
CB$(head) = Left$(A$,I-1) ' transfer into circular buffer
head = (head Mod 10)+1
If I<254 Then A$ = Mid$(A$,I+2) Else A$=""
rob :-)
lew247
Posted: 06:03am 25 Dec 2016
Nope it didn't work, I got nothing printed from the com port at all
I then put a very simple program in that prints everthing recieved by the com port to make sure the com port was working and the com ports is seeing what I'm expecting to see
This just doesn't work though.. Sorry
[code]Dim CB$(10)
head = 1
tail = 1
A$ = ""
B$ = ""
Open "COM1:19200,1024,isr,S2" As #1
' main loop
B$ = CB$(tail)
if B$<>"" THEN Print B$
B$ = ""
ENDIF
If I<>0 Then
End Sub[/code]
Posted: 06:52am 25 Dec 2016
can you post the code that is generating the messages (time, etc) at the other end?
rob :-)
lew247
Posted: 07:15am 25 Dec 2016
SetPin 16, DOUT 'HC-12 Power
Pin(16) = 1 'HC-12 Power OFF
Open "COM1:19200" As #2 Open port for HC-12 TX/RX
'When searching for GPS lock****
Print #2, "STXG" , "," , "*"
Once GPS LOCK is found and it's converted the time to local time
Pause 100
Pin(16) = 0 'HC-12 Power OFF
'Once the weather is ready to transmit to the indoor unit
If secs Mod 15 = 0 Then 'every 15 seconds
Pin(16) = 0 ' Turn HC-12 Power ON
BATTERY ' Measure battery voltage
SendDataUpdate 'SEND DATA via Com Port
Pause 500
Pin(16) = 1 ' Turn HC-12 Power OFF
End If
Sub SendDataUpdate
LOCAL BB as integer
FOR BB = 1 to 10
Print #2, "STXW " , "," , bme280_read_temp()",",bme280_read_pressure()",",bme280_read_humidity()",",wheading",",wSpeed",",wgust",",hgust",",mmrain ",",mmrain2",",hightemp",",hightemp2",",lowtemp",",lowtemp2",",UVindex",",batt,"*"
pause 20
next BB
I have it sending the data to the com port 10 times at the moment in the hope of "one of the streams" being received properly and it will only transmit once every 5 mins or so instead of every 15 secondsEdited by lew247 2016-12-26
Posted: 06:47pm 25 Dec 2016
ok. try this program on the inside unit - it will print out everything that comes in, but also show the values of control characters:
Open "COM1:19200" As #1
S$ = Input$(72,#1)
For I=1 To Len(S$)
C$=Mid$(S$,I,1)
If L$=Chr$(13) And C$<>Chr$(10) Then Print
If Asc(C$)<32 Then
Print "<";Str$(Asc(C$));">";
Else
Print C$;
If L$=Chr$(13) And C$=Chr$(10) Then Print
L$=C$
Next i
also, i notice you seem to be powering the HC-12 down when not in use. when powering it up, you should allow a short delay for the onboard processor to boot:
Pin(16) = 1 'HC-12 Power ON
pause(50)
please post the output that you see.
rob :-)
lew247
Posted: 12:32am 26 Dec 2016
  robert.rozee said   ok. try this program on the inside unit - it will print out everything that comes in, but also show the values of control characters:
You are a genius!
Once I could see the control characters I found the problem, there were a few problems with the code I was transmitting in the formatting of it
The main problem is RECEIVING the Humidity reading from the BME280
I just don't get why, it's printing on the console perfectly, but as you can see from the output below it's not reliably sending on the com port for some reason
[quote]STXW <9>,<9> 20.76<9>,<9> 1017.88<9>,<9> 52.46<9>,<9> 87.9179<9>,<9> 0<9>,<9> 0.416667<9>,<9> 0.416667<9>,<9> 0<9>,<9> 0<9>,<9> 20.76<9>,<9> 0<9>,<9> 20.76<9>,<9> 0<9>,<9> 0.03<9>,<9> 3.54194<9>,<9>*<13><10>
STXW <9>,<9> 20.76<9>,<9> 1017.99<9>,<9>STXW <9>,<9> 20.76<9>,<9> 1017.94<9>,<9>STXW <9>,<9> 20.75<9>,<9> 1017.93<9>,<9>[/quote]
STXW is the start of the Transmit string and * SHOULD be the end
But as you can see after the first successful transmission, the string stops sending after the temp and pressure readings are sent.. the humidity does not send
Yet as you can see below from the console output it does send to the console
[quote]
11:22:49
Battery Voltage 3.54 V
Direction: 87.39 Degrees
WindSpeed: 0 MPH
Gust 0.42 MPH
Highest Gust 0.42 MPH
Rain Today 0.00 mm
Rain Yesterday 0.00 mm
Temperature 20.69 C
Highest Temp 20.73 C
Lowest Temp 20.69 C
Hi Temp Yesterday 0.00 C
LOW Temp Yesterday 0.00 C
Pressure 1017.91 mB
HUMIDITY 52.76%
UV Index: 0.02
11:23:19
Direction: 87.2141 Degrees
WindSpeed: 0 MPH
Gust 0.42 MPH
Rain Today 0.00 mm
Temperature 20.69 C
Lowest Temp 20.69 C
Pressure 1017.92 mB
HUMIDITY 52.75%
UV Index: 0.02
[/quote]
Here's the code I@m using to send to both the console and com port... I can't see why the com port stops working after the 1st transmit
BTW - the HC-12 is turned on 100Ms before the transmit code is sent to it so it is sending correctly and the recieve one is always on
[code]Sub SendDataUpdate
Print "*********************************"
Print Time$
Print " Battery Voltage ";Str$(batt,3,2);" V"
Print " Direction: ";Str$(wheading);" Degrees"
Print " WindSpeed: ";Str$(wSpeed); " MPH"
Print " Gust ";Str$(wgust,3,2); " MPH"
Print " Highest Gust ";Str$(hgust,3,2); " MPH"
Print " Rain Today ";Str$(mmrain,3,2);" mm"
Print " Rain Yesterday ";Str$(mmrain2,3,2);" mm"
Print " Temperature "; Str$(bme280_read_temp(),3,2)" C "
Print " Highest Temp ";Str$(hightemp,3,2) " C"
Print " Lowest Temp ";Str$(lowtemp,3,2) " C"
Print " Hi Temp Yesterday ";Str$(hightemp2,3,2) " C"
Print " LOW Temp Yesterday ";Str$(lowtemp2,3,2) " C"
Print " Pressure "; Str$(bme280_read_pressure(),3,2)" mB "
Print " HUMIDITY "; Str$(bme280_read_humidity(),3,2)"%"
Print " UV Index: ";Str$(UVindex,3,2)
Print "*******************************"
Print #2, "STXW ",",",bme280_read_temp(),",",bme280_read_pressure(),",",bme280_read_humidity(),",",wheading,",",wSpeed,",",wgust,",",hgu st,",",mmrain,",",mmrain2,",",hightemp,",",hightemp2,",",lowtemp,",",lowtemp2,",",UVindex,",",batt,",","*"
End Sub[/code]
I did also try changing the humidity to Str$(bme280_read_pressure(),3,2) but it makes no difference
EDIT: If I delete bme280_read_humidity() totally then the STXW works perfectly
Edited by lew247 2016-12-27
Posted: 01:07am 26 Dec 2016
i suspect you may be hitting a buffer overflow with that extremely long line. there is also an issue with using commas to separate items. this code:
Print 123, ",", 456, "hello"
produces this output:
123<9>,<9> 456<9>hello<13><10>
the <9> are tab characters, that are meaningful only to teraterm.
try something like this instead:
Print #2, "STXW ," bme280_read_temp() "," bme280_read_pressure() ",";
Print #2, bme280_read_humidity() "," wheading "," wSpeed ",";
Print #2, wgust "," hgu st "," mmrain "," mmrain2 "," hightemp ",";
Print #2, hightemp2 "," lowtemp "," lowtemp2 "," UVindex "," batt ",*"
i've removed all the commas between items being printed. then only commas left are the ones after the #2. print is quite happy to have a list of items that are just separated with spaces - the spaces are not printed.
all bar the first line end in a ; so that theputput appears as a single output line.
rob :-)Edited by robert.rozee 2016-12-27
lew247
Posted: 01:19am 26 Dec 2016
Thanks, I didn't realise that using ; allowed the output to be appended without putting in a cr/lf
Unfortunately it made no difference, IF I remove the Humidity then it works perfectly, but when I put Humidity back in it fails
What I don't get is the humidity prints to the console perfectly, it just won't send over the com port
Posted: 01:37am 26 Dec 2016
i still feel you may be overflowing a buffer. how about if you split the data between several id tags:
Print #2, "STXW1," bme280_read_temp() "," bme280_read_pressure() ",*"
pause 50
Print #2, "STXW2," bme280_read_humidity() "," wheading "," wSpeed ",*"
pause 50
Print #2, "STXW3," wgust "," hgu st "," mmrain "," mmrain2 "," hightemp ",*"
pause 50
Print #2, "STXW4," hightemp2 "," lowtemp "," lowtemp2 "," UVindex "," batt ",*"
pause 50
remember, the HC-12 also has a limited internal buffer (possibly only 60 bytes), so blasting it with a long string of text may cause characters to be lost.
on the outdoors micromite, try adding in 2 stop bits to the open command. in theory having 2 stop bits should slightly slow the rate of transmittion of serial data from the micromites, but not affect the received rate.
rob :-)
lew247
Posted: 02:18am 26 Dec 2016
I'm totally confused now
I tried as an experiment swapping the Humidity place in the TX string
So now it sends Temp, Humidity and then pressure
It now receives the Humidty but It's still failing after the 2nd item is sent (this time it's not recieving the pressure reading
Print #2, "STXW" "," bme280_read_temp() "," bme280_read_humidity() "," bme280_read_pressure()
This "should" work and I don't understand why its stopping after the 2nd item is transmitted I've swapped humidity and pressure round and whichever is the 2nd item sends ok but not the 3rd
It has to be something stupidly simple but I'm not seeing it
Posted: 02:34am 26 Dec 2016
try using the following on the outside unit:
Open "COM1:19200,S2" As #2
rob :-)
     Page 17 of 25
