Local Time 23:59 24 Oct 2026 Privacy Policy
     Page 17 of 31
JanVolk
Posted: 10:33am 03 Jun 2026
Peter,
Updated the PicoMite MMBasic RP2040 V6.03.00RC15 test firmware and copying the long file from A to B with FM first marked with * and then F5 works perfectly now. Thanks.
Jan.
Posted: 10:45am 03 Jun 2026
Has anyone been able to get USB touch working that connects to the Pico via HDMI (for the video) but with a screen that also accepts video via the same USB C that touch is on??
Peter - with your thorough knowledge, is the above a non starter for screens that use the USB for video and touch? I.e. does the usb need to be dedicated to touch data only?
Edited 2026-06-03 20:46 by WhiteWizzard
JanVolk
Posted: 12:08pm 03 Jun 2026
Has anyone seen this before?
I have no video signal. Perhaps the OPTION VGA PINS aren't working correctly?
I also no longer see the option resolution 640x480 @ 252000 KHz.
It did work with an older version. Or is there something wrong with my hardware?
PicoMiteVGA MMBasic USB RP2040 Edition V6.03.00RC15
Copyright 2011-2026 Geoff Graham
Copyright 2016-2026 Peter Mather
> US USB Keyboard Connected on channel 1
> USB Mouse Connected on channel 2
> option list
OPTION SYSTEM I2C GP16,GP17
OPTION FLASH SIZE 16777216
OPTION COLOR CODE ON
OPTION KEYBOARD US
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION SDCARD GP21, GP18, GP19, GP20
OPTION VGA PINS GP11,GP22
OPTION AUDIO I2S GP13,GP15', ON PWM CHANNEL 6
OPTION RTC AUTO ENABLE
OPTION F1 help
OPTION F5 list commands
OPTION F6 list functions
OPTION F7 list pins
OPTION F8 option list
OPTION F9 fm
OPTION PLATFORM PicoMiteVGAUSB RP2040-PiZero
See this version for video signal.
> option list
PicoMiteVGA MMBasic USB RP2040 Edition V6.03.00RC9
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 252000KHz
OPTION F1 help
OPTION F7 list pins
OPTION F9 fm
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP4      6      OFF
GP5      7      OFF
GP6      9      OFF
GP7      10     OFF
GP8      11     Boot Reserved : CONSOLE TX
GP9      12     Boot Reserved : CONSOLE RX
GP10     14     OFF
GP11     15     Boot Reserved : VGA HSYNC
GP12     16     Boot Reserved : VGA VSYNC
GP13     17     Boot Reserved : I2S BCLK
GP14     19     Boot Reserved : I2S LRCK
GP15     20     Boot Reserved : I2S DATA
GP16     21     Boot Reserved : SYSTEM I2C SDA
GP17     22     Boot Reserved : SYSTEM I2C SCL
GP18     24     Boot Reserved : SPI SYSTEM CLK
GP19     25     Boot Reserved : SPI SYSTEM MOSI
GP20     26     Boot Reserved : SPI SYSTEM MISO
GP21     27     Boot Reserved : SD CS
GP22     29     Boot Reserved : VGA BLUE
GP23     41     Boot Reserved : VGA GREEN L
GP24     42     Boot Reserved : VGA GREEN H
GP25     43     Boot Reserved : VGA RED
GP26     31     OFF
GP27     32     OFF
GP28     34     OFF
GP29     44     OFF
Jan.
Posted: 01:09pm 03 Jun 2026
This working perfectly for me
OPTION SYSTEM I2C GP14,GP15
OPTION KEYBOARD US
OPTION PICO OFF
OPTION SDCARD GP13, GP10, GP11, GP12
OPTION VGA PINS GP23,GP18
OPTION AUDIO GP16,GP17', ON PWM CHANNEL 0
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP4      6      OFF
GP5      7      OFF
GP6      9      OFF
GP7      10     OFF
GP10     14     Boot Reserved : SPI SYSTEM CLK
GP11     15     Boot Reserved : SPI SYSTEM MOSI
GP12     16     Boot Reserved : SPI SYSTEM MISO
GP13     17     Boot Reserved : SD CS
GP14     19     Boot Reserved : SYSTEM I2C SDA
GP15     20     Boot Reserved : SYSTEM I2C SCL
GP16     21     Boot Reserved : AUDIO L
GP17     22     Boot Reserved : AUDIO R
GP18     24     Boot Reserved : VGA BLUE
GP19     25     Boot Reserved : VGA GREEN L
GP20     26     Boot Reserved : VGA GREEN H
GP21     27     Boot Reserved : VGA RED
GP22     29     OFF
GP23     41     Boot Reserved : VGA HSYNC
GP24     42     Boot Reserved : VGA VSYNC
GP25     43     HEARTBEAT
GP26     31     OFF
GP27     32     OFF
GP28     34     OFF
GP29     44     OFF
JanVolk
Posted: 01:56pm 03 Jun 2026
Peter,
Thanks for investigating and the response.
I am going to investigate further why it works correctly with PicoMiteVGA MMBasic USB RP2040 Edition V6.03.00RC9 but not with V6.03.00RC15, and how it is with the intermediate versions.
If I find anything, I will let you know.
Jan.
homa
Posted: 04:24pm 03 Jun 2026
Hi Peter,
is there any update on the multi-touch issue with the MageDok display?
Is there anything I can do to help?
Matthias
Posted: 04:30pm 03 Jun 2026
  Quote  s there any update on the multi-touch issue with the MageDok display?
If you can find it please re-post the diagnostic from that screen and post a link to any details.
Edited 2026-06-04 02:31 by matherp
homa
Posted: 04:59pm 03 Jun 2026
  homa said
  matherp said  Another version to test on the first panel
PicoMite.zip
lastVersion.zip
Was the data insufficient? Shall I run this version again?
So far, the information is only available on the webshop: https://store.magedok.com/products/9-inch-raspberry-pi-touch-monitor-with-hdmi-input-t090a
and there, the Touch Controller: ILITEK 2132 ?!
https://www.cdtech-display.com/wp-content/uploads/2025/09/ILI2132_DTS_V003_20200616.pdf
I'll carry on looking later.
Posted: 05:20pm 03 Jun 2026
Does that report include definitely trying two fingers at the same time? If not please run again with the version that had the diagnostics and specifically try touching in two places at once. This is needed to see if the required report is actually happening. That controller boots up in "mouse" mode. i.e. single touch and simple reports but I need to know if the multi-touch reports are also happening.
JanVolk
Posted: 05:40pm 03 Jun 2026
Peter,
I reloaded PicoMiteVGA MMBasic USB RP2040 Edition V6.03.00RC15 and performed OPTION RESET.
Also > Drive "A:/FORMAT" and then copied options line by line from Notepad++ to Tera Term in a specific order.
After that, I transferred the backup folder using FM. I made some adjustments to the options list.
PiZero module with a 64x29mm perforated board underneath containing RTC+EEPROM, VGA connector and resistors, and an I2S module with 3mm spacer sockets.
All pins are accessible and the unused HDMI pins have been used for VGA. The whole assembly is 35mm high and compact. A speaker set from Action (12 Euros) makes it complete. The bottom was finished with a similar perforated board.
On the PiZero, I adjusted the debug pins for Rx=GP9 and Tx=GP8.
Everything is working properly so far.
Thanks for the support.
This is my options list:
> option list
OPTION KEYBOARD US
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 315000KHz
OPTION MODBUFF ENABLE
OPTION F1 help
OPTION F7 list pins
OPTION F9 fm
Jan.
Posted: 05:52pm 03 Jun 2026
Homa
Another question. Have you run the display on a windows machine. Can you confirm if multi-touch works on any other host?
Posted: 06:53pm 03 Jun 2026
Hi Peter,
I've cheekily taken the opportunity to attach a 'HID report descriptor' file for an OLED screen. This is with the hope that you can help get the USB multi-touch to work on it.
Touch HID report descriptor.zip
As you'd requested in earlier posts for some other screens, I'm hoping there's enough info in there, but if needed, I can run any other tests required.
Thanks for any help you can provide.....
EDIT: I can confirm it works 100% when connected to a Win 11 laptop (via HDMI for image, and via a single USB for touch & power
Edited 2026-06-04 04:56 by WhiteWizzard
grumpyoldgeek
Posted: 07:28pm 03 Jun 2026
What is the maximum size of FLASH and PSRAM supported by the current release?
homa
Posted: 08:35pm 03 Jun 2026
  matherp said  Homa
Yes, win11 oout of the box, multitouch and gesture control also works with two-finger zooming!
The old Records also mentioned 3-finger touch.
I was out and about. Tomorrow I’ll finish up several test runs with descriptions and upload them here for you.
Posted: 09:48pm 03 Jun 2026
homa and WhiteWizard please test the attached HDMIUSB version and report exactly what you see
PicoMite.zip
ville56
Posted: 05:30am 04 Jun 2026
@Peter,
minor issue: the BACKLIGHT command in the HDMI version is still not an "no-op" command as announced but throws an error (Error : unknown command)
73 de OE1HGA, Gerald
Posted: 06:21am 04 Jun 2026
Hi Peter
Thanks for test file - output below:
PicoMiteHDMI MMBasic USB RP2350B Edition V6.03.00RC16
> Multi-touch Connected on channel 4 (10 contacts, 16383x9599)
> gui test touch
> 'nothing happens on screen in gui test touch
> 'will now unplug usb touch, and reconnect......
> Multi-touch Disconnected
> 'will now reconnect USB
Error : USB device limit reached
> 'NOTE: display showing expected image throughout above (apart from Test Touch)
homa
Posted: 08:23am 04 Jun 2026
Peter,
At first I was put off by WhiteWizzard’s report, but I gave it a go anyway.
The result is that initially there’s no debug output either, and the “gui test touch” command clears the screen but doesn’t respond to it.
However, I noticed that after a reset and a quick, immediate "gui test touch", there is a brief window during which the screen responds to the test. After that, though, it stops responding. Only a RESET causes the behaviour to reappear, so it is reproducible.
Attached is an image showing single-touch and two-finger-touch.
Matthias
Update: I can even reconnect the Microsoft mouse/keyboard dongle without a Hex Debug message appearing. However, the behaviour remains the same. The pump demo works via touch for a brief moment, then there is no response again. After that, it only works with the mouse.
Edited 2026-06-04 18:30 by homa
Posted: 08:30am 04 Jun 2026
Matthias
I'm unclear what you are reporting. Is multi-touch now working but stops after a period? Does single touch also now stop when it didn't before?
This version should have the debug
PicoMite.zip
Edited 2026-06-04 18:35 by matherp
homa
Posted: 08:34am 04 Jun 2026
Peter,
1. RESET
2. Output:
PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC16
> Multi-touch Connected on channel 4 (10 contacts, 16384x16384)
> GR USB Keyboard Connected on channel 1
3. gui test touch <--- immediate entry
4. You have about 5 seconds to test the touch, whether single or multi-touch! After that, only the touch function stops working. The Pico can still be fully operated via the terminal.
5. goto 1
Matthias
Footnote added 2026-06-04 18:35 by homa
With the RC15, the touch operates in single-mode throughout!
     Page 17 of 31
