Local Time 10:28 25 Oct 2026 Privacy Policy
Forum Index : Electronics : Inverter PCB’s
     Page 15 of 29
ryanm
Posted: 11:35am 16 May 2018
Like I said I'm just soft, and I should treat my poor abused soldering tip better.
oztules
Posted: 12:02pm 16 May 2018
Actually, I am with ryanm on this, when making the boards up, I felt that there was only just enough pad showing to get a bit of heat into the pad to melt the solder...
I settled for heating the legs, and using the fact that there is good through plating, to heat the center of the hole up with the component leg, that then heated the pad ring enough to run the solder... so changed techniques.
I would have preferred a bit more real estate, but that said, it was not a show stopper by any means.
Ok Marks ,machine.
All up and running happily for long periods at 4kw or so, reset, and restart under full loading, no problem... very very quiet at 2kw for some reason, still very quite at 3kw, and not much noisier at 4kw and more.
Have not tried the high current bursts, as only 2 fets in 2 legs at the moment, and they stay pretty cool, it's the tranny that gets hot, it is only single core with 25mmsq wire.
There is some sensitivity which I alluded to years or so ago, regarding the pin6. If you use big switches with long wire... there is a likelyhood that it will trigger oddly under high power, the faulty switch ( thing that introduced inconsistency, if not faulty) was replicated when I replaced it with a like sized switch. I use very small ones in my inverters, maybe why I have not seen this behavior...
So beware, if your unit turns itself on and off... fair chance it is your on off switch circuitry.
Yes, Mark, noticed the brushing, it helped show up the small voids around some of the legs.
Tomorrow will test out the start up characteristics, but the little tranny will limit us.
May send it back Friday or Monday if it continues to perform nicely.
pics.....
Here we can see the new switch.... glued to the caps... but no longer used... started to pulse at 4kw..... notice the jumper lead across the pins instead.
Here is a crappy pic, but shows both the 10amp grill and the 8amp element running together, and did so for 20 mins or more... but at nightime thats not terribly smart.
So I think we are pretty much there. bit more testing to go.
........oztules
Edited by oztules 2018-05-17
Posted: 12:09pm 16 May 2018
I had some real fun today tried the Nano in the control board and nothing, the 12V was shorted. After removing diodes etc on the positive rail the only thing left was the socket for the Nano which was a major PITA to remove. Turned out there was a fine strand of wire between the VIN & GND pins under the socket. I wasted over 2 hours, lucky it was there, could have been somewhere else and even harder to diagnose.
Would have liked to have gotten further with the code but here is what I have so far. It will run the fans and display but that's all at this stage. First off you need to find the address of the Digital temperature sensors with this code.
[code]
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
#include <Wire.h> // Comes with Arduino IDE
// Get the LCD I2C Library here:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
#include <LiquidCrystal_I2C.h>
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
OneWire ds(4); // on pin 9 (a 4.7K resistor is necessary)
void setup(void) {
Serial.begin(9600);
lcd.begin(20,4); // initialize the lcd for 20 chars 4 lines, turn on backlight
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
lcd.print(' ');
Serial.print(addr, HEX);
lcd.print(addr, HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
break;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44); // start conversion, use ds.write(0x44,1) with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data = ds.read();
Serial.print(data, HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
lcd.setCursor(0,0);
[/code]
Upload this to the arduino and open the serial monitor under tools in the Arduino Software. If you hold one of the sensors you will see the temperature increase so you can identify which is which.
This then is entered in the actual code as per below.
DeviceAddress Probe01 = { 0x28, 0xEE, 0x46, 0x1A, 0x2E, 0x16, 0x01, 0x0A };
DeviceAddress Probe02 = { 0x28, 0xEE, 0x15, 0x12, 0x1A, 0x16, 0x02, 0x6F };
Probe01 is for the heatsink and Probe02 is for the transformer.
[code]
/* YourDuino.com Example: Multiple DS18B20 Temperature Sensors
Displayed on 4x20 character LCD display
DS18B20 Pinout (Left to Right, pins down, flat side toward you)
- Left = Ground
- Center = Signal (Pin 9): (with 3.3K to 4.7K resistor to +5 or 3.3 )
- Right = +5 or +3.3 V
terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <OneWire.h>// Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
#include <DallasTemperature.h>//Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
#include <Wire.h>// Wire (I2C) Library
#include <PID_v1.h> //PID LIB for fan speed
#include <LiquidCrystal.h>// LCD Library
#include <avr/wdt.h>//Watchdog Lib
#define ONE_WIRE_BUS 4 // Data wire is plugged into port 4 on the Arduino
#define pwmH 6
#define pwmTR 5
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass address of our oneWire instance to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//-----------------------------CHANGE THESE AS REQUIRED---------------------------------------------------------------------------------
// Start the LCD display library
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address change this 0x3F or 0x27 if nothing on the LCD
double HSsetpoint = 35; //Heatsink Target Temperature
double TRsetpoint = 45; //Toroid Target Temperature
int MinVolts = 47; //Battery Volts to shut down
int TimeAtMinVolts = 120; //How many seconds below MinVolts till shout down is triggered
int RestartTime = 10; // How many minutes to restart if battery volts recover above MinVolts
DeviceAddress Probe01 = { 0x28, 0xEE, 0x46, 0x1A, 0x2E, 0x16, 0x01, 0x0A }; // Address for Sensor connected to Heatsink USE DS1820_SERIAL_READ TO GET THE ADDRESS OF YOUR SENSORS
DeviceAddress Probe02 = { 0x28, 0xEE, 0x15, 0x12, 0x1A, 0x16, 0x02, 0x6F }; // Address for Sensor connected to Toroid USE DS1820_SERIAL_READ TO GET THE ADDRESS OF YOUR SENSORS
//------------------------------STOP HERE IF YOU ARE NOT SURE---------------------------------------------------------------------------
int HSmax;
int TRmax;
int FANtempH;
int FANtempT;
double tempTR;
int tempTR1;
double tempHS;
int tempHS1;
double fanspeedH;
double fanspeedT;
double fanpwmH;
double fanpwmT;
int fanpercentH;
int fanpercentT;
const int numReadings = 10;
double Setpoint, Input, Output;
int readings; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int voltsinputPin = A7;
boolean singlecase = false; // true for all in one case, false for divided case with seperate fans for heatsink and toriod.
float R1 = 105000.0; // resistance of R1 (100K)
float R2 = 8000.0; // resistance of R2 (8K2) For setting up voltage divider to get correct voltage reading Use in conjunction with trim pot on pcb
double vin = 0.0;
double vout = 0.0;
int beeper = 11;// the number of the beeper pin
int beeperstate = LOW;
//int ShutDown = 3;// the number of the shutdown pin
//int ShutDown = HIGH;
unsigned long previousMillis = 0;
const long interval = 750; // interval at which to beep (milliseconds)
double Kp = 45, Ki = 20, Kd = 3; //variables for setting PID for fan speed control
PID HSPID(&tempHS, &fanpwmH, &HSsetpoint, Kp, Ki, Kd, REVERSE);
PID TRPID(&tempTR, &fanpwmT, &TRsetpoint, Kp, Ki, Kd, REVERSE);
void setup() /****** SETUP: RUNS ONCE ******/
Serial.begin(9600);
wdt_enable(WDTO_1S); // Setup watchdog to reset after 1 second if no activity
//------- Initialize the Temperature measurement library--------------
sensors.begin();
// set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
sensors.setResolution(Probe01, 10);
sensors.setResolution(Probe02, 10);
//---------------- Initialize the lcd ------------------
lcd.begin(20, 4); // initialize the lcd for 20 chars 4 lines, turn on backlight
lcd.setCursor(0, 0);
HSPID.SetMode(AUTOMATIC);
TRPID.SetMode(AUTOMATIC);
pinMode(beeper, OUTPUT);
// pinMode(ShutDown, OUTPUT);
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings = 0;
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
wdt_reset(); // Reset watchdog timer
// lcd.clear(); // Reset the display
lcd.home();
lcd.backlight(); //Backlight ON if under program control
lcd.setCursor(0, 3);
lcd.print("V :");
lcd.print(vin);
sensors.requestTemperatures(); // Send the command to get temperatures
lcd.setCursor(0, 0); //Start at character 0 on line 0
lcd.print("H:");
tempHS = sensors.getTempC(Probe01);
if (tempHS == -127.00) // Measurement failed or no device found
lcd.print("Error");
tempHS = tempHS1;
else
lcd.print(tempHS, 0);
tempHS1 = tempHS;
HSmax = max (HSmax, tempHS);
lcd.print(" M:");
lcd.print(HSmax);
HSPID.Compute();
tempTR = sensors.getTempC(Probe02);
if (tempTR == -127.00) // Measurement failed or no device found
lcd.print("Error");
tempTR = tempTR1;
else
lcd.print(" T:");
lcd.print(tempTR, 0);
tempTR1 = tempTR;
TRmax = max (TRmax, tempTR);
lcd.print(" M:");
lcd.print(TRmax);
TRPID.Compute();
analogWrite (pwmTR, fanpwmT);
analogWrite (pwmH, fanpwmH);
lcd.setCursor(0, 1);
lcd.print("HSF% ");
lcd.setCursor(5, 1);
lcd.print(fanpwmH / 2.55, 0);
lcd.setCursor(9, 1);
lcd.print(" TRFAN% ");
lcd.setCursor(17, 1);
lcd.print(fanpwmT / 2.55, 0);
// subtract the last reading:
total = total - readings;
// read from the sensor:
readings = analogRead(voltsinputPin);
// add the reading to the total:
total = total + readings;
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
vout = (average) / 20.0;
vin = (vout) / (R2 / (R1 + R2)); // Voltage divider calculation
if (vin >= MinVolts) {
lcd.setCursor(9, 3);
lcd.print("VOLTS GOOD");
// ShutDown = LOW;
beeperstate = LOW;
else
lcd.print("LOW VOLTS ");
// ShutDown = HIGH;
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (beeperstate == LOW) {
beeperstate = HIGH;
} else {
beeperstate = LOW;
// set the LED with the ledState of the variable:
digitalWrite(beeper, beeperstate);
//--(end main loop )---
[/code]
oztules
Posted: 11:32pm 16 May 2018
Well it looks like the mystery has been solved in this case.
With the large heat sinks radiating into space, and no close decoupling on the +5v, we seem to be getting too much noise into the switch circuit.
So I put two decoupling caps across the gnd and +5v pins of the switch socket, and shorted the 1k to ground.
This then seemed to calm things right down, even using the large switches, that would have attracted the most noise.
My board has direct line to pin 6 from above the board, and that seems to have saved me the ignominy of unforced shutdown at high power.
So it looks like this thing is going back home soon.
Was happily doing it's 4.5kw this morning . running around 90 amps.... and only 2 fets in 2 bridges..... these HY4008 are amazing things.... cheap Chinese chips be damned, these things are gold.
......oztules
renewableMark
Posted: 11:50pm 16 May 2018
Bloody legend Oz,
could you possibly put that on my build thread for anyone that may follow that and want to know the answer of the fix?
Re the Mad board, I can't get a hold of 22pf mono caps anytime soon, would ceramic caps be ok?
Cheers Caveman Mark
Off grid eastern Melb
oztules
Posted: 12:36am 17 May 2018
Yes...22pmono should work fine too, I have used up to 50pf before with no change in result.
Now for a few pics of wave form....
This is with 2 turns through the torroid ... so there are wave forms everywhere, and no filtering from the caps on the output, this is the raw data in the core....
So beware, there will be waveforms from the 50hzsquare, the spwm, the sum and the difference of all sorts of stuff... but the main fundamental is the sine wave, here it is at 2.5kw.. not too shabby considering no filter of anysort, just raw magnetics.
Note the other waves in there, some you may recognize too.
And this is in the 4.5kw range. Considering all the poor connections. I am surprised it is this good. Very surprised in fact.
I think thats pretty good . Filters will change things for the better, but the raw data is in the core....You get to see all the waveforms in there, just fiddle the CRO, and you get the whole gammit of stuff.... pretty interesting really.
..........oztules
Posted: 12:38pm 17 May 2018
I made up this switch for testing before the long lead issue was discovered. Main reason was I figured it was better than having it hanging off the end of the wires and the potential to short something. It is the wrong type off switch though with the centre off position, I have the right ones coming.
gpalterpower
Posted: 01:50am 18 May 2018
Hi Madness,
I haven't received your PM as yet regarding paypal payment. Not sure if its working. Could you contact me thru my email please. geepea101@gmail.com
Thanks Marcus
Posted: 05:40am 18 May 2018
Don't know what happened there I have sent PMs, just emailed you.
renewableMark
Posted: 05:47am 18 May 2018
You may need to empty out your inbox a bit. They don't hold an indefinite amount.
Mad I just needed one more part to finish my boards but couldn't get the right size for the spade terminals. is that some odd size? Where did you source yours from?
Edit never mind I just bent the pins a bit and they fitted.
Hey what's the difference between uf4007 and 1n4007?Edited by renewableMark 2018-05-19
Cheers Caveman Mark
Posted: 07:29am 18 May 2018
Don't know what happened with spade terminals but yes you need to bend them a little and they go in.
Should be 1n4007 where is that from?
plover
Posted: 08:07am 18 May 2018
A little bit different post here. I am fascinated by all this inverter what not buisness. Normally my coils are only about 1.5 inch square. I understand switchmode theory but practice, well these monsters needs working upon.
I am up to about page 12 in this topic here and hopping round as I can find time.
There was one thing I noticed, something about drawing up a schematic, I think it was in here?. It just so happens after having decided not again getting into doing pcb work etc, after having used protel some years ago up to version 99SE , then a bit out of the blue I got an invitation to come out of retirement and do a job, that project really interests me, some bleading edge stuff no gurantee where you land.
Well I am now getting into the 'documentation works' and are working overtime getting up to speed on using Autotrax Dex, I am at the stage where I can do schematics fairly easily now but still want some more practice.
I offer to attempt to make the schematic and will also attempt layout to see how it will stress my system. However pcb I do not expect to be a success just testing my software.
If my offer has interest, I would be interested to know what documentation is available and in what form.
p.
Edited by plover 2018-05-19
renewableMark
Posted: 08:34am 18 May 2018
  Madness said   Here is the Big Inverter PCB with 24 HY4008 MOSFETs, this is the same as I have been running for around 12 months now. I have put 16 - 24 components as you can vuild it with just 16 FETs if you want as Oztules has done they still will run just about anything with a 240 plug on it. I even have a list of components. Some people talk about screwing heatsinks to the PCB, I have not done this or seen any reason to do it, the MOSFETs are plenty robust enough to carry the weight of the very large heatsinks I use. The cround connection is by soldering cable to the copper where I have left a strip of copper unmasked across the full width of the PCB. I have done this by solder on 12 lenghts of wire with approximately 3mm diametre core then crimping them all to one lug at the other end.
The PCBs are 2oz copper 200 X 300MM, if you don't want to use the Totem Pole drivers there is provision to add jumpers and use the original design.
5 100uf 63v electrollytic cap
6 104 50v 2.54mm Caps
1 104 50v 5.08mm Caps
1 10uf 50v 5.08 Cap
4 10nF 103 3KV capacitors (Snubbers)
6 100V 10000UF Electrolytic (Can) Capacitor 35mmX60mm
1 4.7uF 250V Metallized Polyester Film CBB Capacitor 475J,
2 CAPACITOR, SAFETY, 10NF, 250V, 20%
1 18V Zener
2 UF4007 Diode
1 Tip35c
4 Tip41c
4 Tip42c
16 - 24 HY4008w MOSFET
16 - 24 IN4148 Diodes
1 120 Ohm 5W Resistor
5 10K 0.5w resitor
4 47 Ohm 3W Resistors (Snubbers)
4 5k Ohm 0.5W
4 20 Ohm 0.5W
16 - 24 10 Ohm 0.5W
16 - 24 20K Ohm 0.5W
4 MOV's Metal Oxide Varistors (for helping protect against lightning)
2018-04-25_185453_8_KW_Power_TIP4142_-_PCB_all.pdf 2018-04-25_185514_8_KW_Power_TIP4142_-_PCB_TOP.pdf
2018-04-25_185611_8_KW_Power_TIP4142_-_PCB_BOT.pdf
From here
they look the same specs, I used 1n4007 so I'll just move along to next bit.Edited by renewableMark 2018-05-19
Cheers Caveman Mark
Posted: 09:15am 18 May 2018
Sorry it is a typo, 4007 is a Diode uf is for capacitors.
Posted: 09:25am 18 May 2018
  plover said   A little bit different post here. I am fascinated by all this inverter what not buisness. Normally my coils are only about 1.5 inch square. I understand switchmode theory but practice, well these monsters needs working upon.
p.
Some of us have not bothered with Circuit diagrams while others are out of their comfort zone if they don't have a circuit diagram. The software I used to do the PCB's can also do Circuits but I have not bothered as it takes 10 times longer. Your welcome to have a crack at it. Best I can offer is to work off the PCBs.
oztules
Posted: 10:47am 18 May 2018
actually uf4007 is a fast 1a diode.
..........oztules
renewableMark
Posted: 11:16am 18 May 2018
  oztules said   actually uf4007 is a fast 1a diode.
..........oztules
Yeah I looked at the specs more closely, element 14 list it as ultra fast, hence the uf.
Is there any benefit in using them in this circuit?Edited by renewableMark 2018-05-19
Cheers Caveman Mark
Posted: 11:29am 18 May 2018
Just checked, the original circuit is UF4007 but I have been using 1N4007.
FR107 the same as on the control board is doing the same job so they should be fine there.Edited by Madness 2018-05-19
Boppa
Posted: 01:17pm 18 May 2018
I find that a circuit diagram is almost essential when things dont go according to plan and you have to fault find a board
With a circuit diagram, you can see how a circuit works and where likely faults will be and can figure out what effects a certain fault will cause, without it, you are left trying to guess what has failed and why. They arent so essential when constructing, but are imho essential for fault finding
plover
Posted: 01:42pm 18 May 2018
Crumbs, that size board and no circuit schematic that is rather impressive. I could reconstruct from the layout but I do not have that extra time for quite a while.
Is there any generic schematics that come close that could form the backbone? Anyway I will be flat out exercising schematics for quite a while so if any constructors are scribling part circuit I will put it in nice looking format
p.
     Page 15 of 29
