Local Time 16:38 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Introducing the Pi-cromite: first steps
     Page 13 of 16
atmega8
Posted: 03:13am 20 Jun 2017
OK, yes i missed it ;-(((
This release also includes support for two uarts COM1 and COM2. Syntax is as per the Micromite and print #, input #, line input #, and input$ should all work as normal
Pins are COM1-RX 10, COM1-TX 8, COM2-RX 11, COM2-TX 7
The parameters supported are baudrate (1-115200), buffer size (defaults to 2048), interrupt routine and number of characters before the interrupt. All transmission is 8N1.
DE, 9BIT, INV, OC, and S2 are not supported, nor is IEEE-485
Note the input is buffered as per the Micromite but the output is blocking.
The RX pin is not pulled up in software so this may be required in H/W if the pins may be left disconnected with the serial port open. Remember the Pis are 3.3V ONLY!!
Posted: 05:48am 20 Jun 2017
  Quote  "OPEN "/ dev / ttyUSB0" FOR RANDOM AS # 5 'open the serial port"
Didn't know that Picromite can do things like this.
How could i know if not documented, or did i miss it somewhere ??
This is different to the serial port commands listed above. Because Linux treats all peripherals as though they are files you can use the file I/O commands to talk to them as above.
gumath has opened the USB port as a file with random access giving both input and output capability
atmega8
Posted: 06:17am 20 Jun 2017
/dev/ttyUSB0
Shows me that he attached a USB to rs232 adapter to the USB port.
Am I wrong?
Posted: 07:45am 20 Jun 2017
  Quote  /dev/ttyUSB0
Am I wrong?
You are correct. The point I was making is that he is opening it as a random access file not as a serial port
vs
OPEN "COM1:9600" AS # 5
gumath
Posted: 07:52am 20 Jun 2017
@ atmega8
"/ Dev / ttyUSB0", when using USB serial converter.
On page 6 described in this tread, by TassyJim.
Thanks Jim !!!
I have already read these 20 pages 3x, and find
Always something new.
Vy 73 de Guenter, OE7GMT
hitsware
Posted: 11:06am 20 Jun 2017
No control of baudrate with " / dev / ttyusbo " ?
Posted: 12:24pm 20 Jun 2017
  hitsware said   No control of baudrate with " / dev / ttyusbo " ?
NO, but there is a system command which should be able to set the baud rate.
It will need a Linux user to provide the preferred command to use. I find Linux has many ways to do tasks and I am at a loss when it comes to the "correct" way.
atmega8
Posted: 12:42pm 20 Jun 2017
Setting serial port parameters under Linux are done with stty commands.
For example:
stty -F /dev/ttyUSB0 115200
sets the baudrate to 115200.
Try man stty for many other settings,
or online man pages :
Stty
Posted: 02:54pm 20 Jun 2017
USB does not have a baud rate.
Only a USB to serial converter uses that to set the UART side of the converter.
A builtin USB device does not have a UART.
atmega8
Posted: 09:17pm 20 Jun 2017
As you can see with ls -l /dev/ttyUSB0:
crw-rw---- 1 root dialout 188, 0 Jun 21 09:06 /dev/ttyUSB0
it is a serial character Device.
Also you CAN set and you NEED to set a baudrate (and other Framings) if the Application (Putty/Minicom/PIcomite..) does not set it!
set with "stty -F /dev/ttyUSB0"
and read with "stty -F /dev/ttyUSB0 speed",
here 4800.
Play with putty, set speed, and read it from another shell with stty -F /dev/ttyUSB0.
This way you can set a baudrate when using Picromite´serial communication.
DS
Edited by atmega8 2017-06-22
atmega8
Posted: 10:08pm 20 Jun 2017
  TassyJim said   More playing, this time with a USB-TTL converter.
  Quote   ' serial test program
OPEN "/dev/ttyUSB0" FOR RANDOM AS #5 ' open the serial port
PRINT #5, "HELLO!!! Is anyone out there?"
DO ' one way to receive serial data which might not be there!
k$ = INPUT$(1,#5)
IF k$="" THEN
nodata=nodata+
1
ELSE
result$=result$+k$
PRINT result$
nodata=
0
ENDIF
PAUSE 20
LOOP UNTIL k$=CHR$(10)OR nodata=50 ' 50*20ms = 1 second timeout
CLOSE #5
There doesn't seem to be a way to change the baud rate yet. My FTDI converter defaulted to 9600 baud.
It seems to need the "FOR RANDOM" bit in there so we think its a file.
A Linux observation - The text is sent with a <LF> only so if you are waiting for the <CR>, you will be disappointed.
So far I have tested with a loopback plug on the serial adapter but there is no reason a micromite couldn't be sitting there.
This version on MMBasic doesn't save your code between sessions so remember to do a SAVE before exiting!
So use stty -F /dev/ttyUSBx 38400 ...or what you need on the bash
gumath
Posted: 10:40pm 20 Jun 2017
@ atmega8
Thanks for the tip !!!
I will be testing extensively tonight.
Thanks again,
Posted: 12:01am 21 Jun 2017
Please find attached version 5.4.a05
2017-06-21_094453_mmbasic.zip
Please delete the OPTIONS file before use: "rm .options"
I need help from Pi 3 owners to test a specific change in this release.
There is a known issue with pigpio that the timing of waveforms created with the DMA wave output functions are incorrect on some, but not all, Pi 3s. Other Pis do not seem to be affected.
This functionality is used for serial comms output and the new "BITSTREAM" command. Note other time based MMBasic functions are correct - this issue is specific to the pigpio wave functionality.
The timings are wrong on my Pi 3 and in release 5.4.a04 and below I used a frig factor of 1.128 to correct the timings. However, gumath has reported that this didn't work on his Pi 3.
To rectify this I have introduced a new option WAVETIME which defaults to 1.0
Syntax is: OPTION WAVETIME number
In my case I use "OPTION WAVETIME 1.128" to get correct serial output. The value is permanently stored in the .options file. If the value isn't 1.0 then the value in use will be reported when you use OPTION LIST
So, if you have a Pi 3 please could you test serial output for me. First try the release as delivered (WAVETIME=1.0). If that doesn't work (i.e. you get garbled output) try 1.128.
If that also doesn't work and you have access to an oscilloscope or logic analyser please try the following:
open "COM1:1000" as #1
do
print #1,"U";
loop
This generates a stream of characters where the bit length should be exactly 1 millisecond and character "U" toggles the bits.
Please measure the actual length of the bit and report back. You can then use the measured bit length to correct serial output WAVETIME = measured_bit_length/required_bit_length.
Please also let me know the exact version of the Pi 3 you are testing on - mine is the Pi 3 Model B V1.2 and MM.DEVICE$ reports A02082
Thanks for any and all help on this one.
Edited by matherp 2017-06-22
RonnS
Posted: 03:49am 21 Jun 2017
Hello Peter,
first many thanks for your work.
I've done first experience with the BITSTREAM Command. I have connect a Pi with an 433 mhz Transmitter and run my Remote Control Code .
It worked only a part of the code immediately, this part sent a 24 bit stream to a Led controller, over the 433 mhz transmitter, so I can say it works in principle .
- the other part should send a 32 bit stream - i have to work on it
My other impression was that the Pi then swings by itself and does not stop again
I could not measure any results with my logic analizer - I had to terminate mmbasic to stop everything.Tested with V5.4.04 and i have the same Raspi version as you
regards RonEdited by RonnS 2017-06-22
Posted: 05:06am 21 Jun 2017
Ron
Have you upgraded pigpio to V64? see 2nd post on page 19
If you still have problems please post sample code that causes the problem
RonnS
Posted: 05:32am 21 Jun 2017
  matherp said   Ron
hi Peter ,
pigpiod -v. gives me a 64 back...( now ;) )
I will keep trying it again :) and will report then
it could be that the problem caused in the changed "end of transmission"
thank youEdited by RonnS 2017-06-22
atmega8
Posted: 11:11am 21 Jun 2017
Peter,
while testing the new version, i could see, that just starting mmbasic, it consumes more than 90% CPU, no programm runnig !!!!
Also deleted .options.
26629 root 20 0 22492 7416 2604 R 92,8 1,7 2:16.05 mmbasic
3 root 20 0 0 0 0 S 3,8 0,0 0:13.94 ksoftirqd/0
23885 pi 20 0 5580 2520 2136 R 1,7 0,6 0:02.77 top
PS.: Why is my stored Programm deleted when i exit
mmbasic and start it again??
THX
Posted: 11:29am 21 Jun 2017
  Quote  PS.: Why is my stored Programm deleted when i exit
Programs are stored in RAM so are deleted when you exit same as mmbasic for DOS or maximite
  Quote  t consumes more than 90% CPU, no programm runnig !!!!
All versions of mmbasic sits in a tight loop while waiting for input. On the Pi it runs as priority 0 so Linux will timeslice it if required
atmega8
Posted: 12:10pm 21 Jun 2017
So, when I use the internal editor and store the Programm it is lost when I exit mmbasic?
Ok.
atmega8
Posted: 12:13pm 21 Jun 2017
Settings in .options are not stored in ASCII format, correct?
     Page 13 of 16
