Local Time 02:48 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 release candidates
     Page 13 of 19
Posted: 09:44pm 13 Nov 2025
While tinkering with Frank's Christmas Bells project I thought a useful addition to MMBasic might be a Port version of the ADC command. That is, reading a Port instead of an analogue input.
For Frank's project speed wasn't an issue but for faster data the Do: Loop routine I used would be too slow.
Is this feasible and if so is it worthwhile?
Posted: 07:29am 14 Nov 2025
  phil99 said  a useful addition to MMBasic might be a Port version of the ADC command. That is, reading a Port instead of an analogue input.
In what way(s) would it differ from the existing Port command & function?
Posted: 07:46am 14 Nov 2025
Hi phill,
It may be already there, did you take a look at:
ADC OPEN freq,n
ADC START sh*tload_of_arrays
Posted: 07:47am 14 Nov 2025
  Quote  In what way(s) would it differ from the existing Port command & function?
Sampling rate. My test with a For / Next loop fluctuated around 60 -70 µS/sample.
ADC can sample down to about 2 µS/sample with reliable timing.
Edit.
ADC Open, n can read 4 channels' but if you want to read a 8 bit bus...
It also uses a lot more memory with at least 8 bits per channel versus 1.
Edited 2025-11-14 17:54 by phil99
Posted: 08:01am 14 Nov 2025
  matherp said
  Quote  Any hope for an RP2340A version for ILI9488 480x320?
Already there, it is only the WebMites where I haven't enabled it
@Peter,
This is an awesome addition!
Without having a PicoMite nearby to try it right now, can you confirm it will work with SPI screens too!
If so, then is the turtle’s area/screen-size determined by mm.hres and mm.vres OR is it limited to something else ie 320x240 ?
Thanks….
Posted: 08:30am 14 Nov 2025
@phill,
Sorry, I mis-read your message. You where asking about reading a PORT in a faster automatic sequence. Not the reverse.
I can only offer PIO. The logic analyzer uses it, but that may be far to complex to be used as a basis for the bells. But the terminal version might be an option, since it contains only the basics. It is published in the PicoMite user manual, appendix F, sample program #3.
Edited 2025-11-14 18:36 by Volhout
Posted: 09:28am 14 Nov 2025
Bear in mind that the Pico only has one ADC on the chip. The inputs to it are multiplexed. It's impossible to read all the ADC inputs simultaneously as each read takes a finite time.
Posted: 10:32am 14 Nov 2025
  Quote  PicoMite user manual, appendix F, sample program #3.
Thanks for that.
That certainly could be adapted to read a parallel bus.
Posted: 01:18pm 14 Nov 2025
  WhiteWizzard said  Without having a PicoMite nearby to try it right now, can you confirm it will work with SPI screens too!
It worked for me with a 480x320 ILI9488 SPI LCD. All tests ran. I think only two showed results which might be considered anomalous, where plot points outside the screen resolution plotted at the maximum x or y.
Amnesie
Posted: 01:33pm 14 Nov 2025
Hi Peter,
new bug / problem with your latest updated RC12:
you fixed IR (now works!) but:
play mp3 "name_of_file"
does crash the whole picoMiteHDMI (tested version)... my option list is the same
as the picture in my above post with the IR bug. I can remember a few iteration ago there was also this play mp3 problem, but you fixed it, now the problem is back.
Greetings
Daniel
Posted: 09:26am 15 Nov 2025
Version 6.00.03
Print MM.Info(exists "a:/profiles.txt")
is giving me a syntax error. The file exists as MM.Info(filesize ...) works.
Not tested on a beta or rc as I want a (more or less) stable version for my hotplate temperature controller. :)
Edited 2025-11-15 19:28 by Mixtel90
Posted: 10:13am 15 Nov 2025
  Quote  Print MM.Info(exists "a:/profiles.txt")
That's what happens if you invent syntax   manual page 85
Posted: 11:33am 15 Nov 2025
Oddly enough supported by MMB4L which makes me suspect it was supported by the CMM2 but not the PicoMite.
Still kicking,
Posted: 11:50am 15 Nov 2025
  Mixtel90 said  Version 6.00.03
Should it be
Print MM.Info(exists file "a:/profiles.txt")
Posted: 11:57am 15 Nov 2025
Oh c**p!
Posted: 01:28pm 15 Nov 2025
I confess I had to read the manual entry.
We used to say RTFM...
Edited 2025-11-15 23:29 by JohnS
ville56
Posted: 01:41pm 15 Nov 2025
There seems to be a bug in the turtle graphics ....
If I run the test program form Peter (earlier in this thread) at test # 10 (cursor tests) subtest "different cursor colors" fails with invisible cursor if the test is repeated. The first run after a reset or cpu restart is ok. There is also an artefact left over after the first cursor is painted. My setup is as follows:
PicoMiteHDMI MMBasic USB RP2350B Edition V6.01.00RC12
OPTION SERIAL CONSOLE COM1,GP0,GP1
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 252000KHz
OPTION DISPLAY 30, 53
OPTION HDMI PINS  1, 3, 7, 5
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION AUDIO GP26,GP27', ON PWM CHANNEL 5
OPTION MODBUFF ENABLE  192
OPTION PLATFORM OLIMEX USB
The effect seems to be independent of the mode setting.
Gerald
73 de OE1HGA, Gerald
Posted: 01:59pm 15 Nov 2025
  Quote  There seems to be a bug in the turtle graphics ....
Explain the exact running sequence to create the issue. Can't reproduce
Edited 2025-11-16 00:01 by matherp
ville56
Posted: 02:26pm 15 Nov 2025
running your test-suite
' TURTLE GRAPHICS TEST SUITE FOR MMBASIC
>run
1.  Basic Movement Tests
2.  Pen Control Tests
3.  Position Tests
4.  Shape Tests (Circles)
5.  Shape Tests (Rectangles)
6.  Arc Tests
7.  Fill Pattern Tests
8.  Polygon Fill Tests
9.  Stack (PUSH/POP) Tests
10. Cursor Tests
11. Complex Drawing Tests
12. Stress Tests
13. Run All Tests
0.  Exit
Select test: 10
Cursor Tests
Test 1: Toggle cursor visibility
Cursor should be visible
 (Press any key for next test)
Cursor should be hidden
Test 2: Cursor following movement
Test 3: Different cursor sizes
Test 4: Different cursor colors
Test 4 is the failing one on the HDMI monitor. Didn't test on SPI display yet.
Gerald
Posted: 02:31pm 15 Nov 2025
What do you do after each run? ctrl-c or press 0 or what?
     Page 13 of 19
