Local Time 07:00 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Beta Testers Wanted
     Page 11 of 26
Posted: 09:52pm 22 Jan 2014
For people who can not program the pic and don't want to buy a programmer i have a few PIC32MX150F128B-V/SP (max 40Mhz) in DIP package and many PIC32MX150F128B-50I/SO (max 50Mhz) in SOIC package available for 6 USD each programmed with the beta firmware.
Shipping is about 2USD and takes about 10 days with normal mail.
If you want some send me a PM.
Frank N. Furter
Posted: 11:20pm 22 Jan 2014
@ Alan68:
Your picture looks very interesting to me. Which display did you use? Can you offer your code in the forum?
I want to tinker a little GPS receiver with my µMite...
Thanks a lot!
Frank
OZ1LQB
Posted: 04:28am 23 Jan 2014
Hi All..
I to have the micromite up and running
For the "c" I use 47uf 16volt from ebay
For the usb to ttl i use one of the cheap from ebay with both 5 and 3.3 volt
I think that this i a better solution for me than the MaxiMite
Sorry for my rusty english but it is more than 44 years since i lived in sydney
Claus
Posted: 12:16pm 23 Jan 2014
Perhaps I did not need to rush out and get a PICKit3!!!
With both CG and TZA now offering pre-programmed chips....
PICKit3 not needed.
Oh well - gave me a chance to play with one of those things, and I am sure it will come in useful for other things in the future.
Good price TZA - The Element14 price for the blank IC is US$8.50....
donmck
Posted: 05:48pm 23 Jan 2014
  JohnS said   Grogster - The Prolific USB ones I have are 3.3V or 5V, you can select. But actually you don't need to as just Tx Rx & Gnd is what I find works (think about it).
I dare say these will also work:
http://www.dontronics-shop.com/olimex-usb-serial-cable.html
Don...
https://www.dontronics.com
Bryan1
Posted: 06:35pm 23 Jan 2014
Hi Don,
Those USB to serial ones look great, now I did buy a fidi based one off you years ago and had a good look thru the disc that came with it but couldn't find any info on the voltage levels so would you have any idea ?
Regards Bryan
Posted: 07:34pm 23 Jan 2014
Great price on those Don - will have to get a couple at least.
Do you happen to know if they are 5v-TTL tolerant or strictly 3v3?
It's just if they are 5v tolerant, then the one cable could do either or.......
Posted: 08:16pm 23 Jan 2014
  Bryan1 said   I did buy a fidi based one off you years ago and had a good look thru the disc that came with it but couldn't find any info on the voltage levels so would you have any idea ?
Regards Bryan
I have an FTDI converter which uses the FT232BM chip.
This chip can be configured for either 3.3V or 5V.
It all depends on the designers choice and the best way to check is with the trusty multimeter. Sitting idle, the Tx pin should be at 3.3 or 5V.
Some boards will have the option of selecting the voltage but mine doesn't.
Having 3.3V and 5V terminals does NOT indicate that you can select the data lines voltage or even tell you what the data lines are set to.
I think there will be a solution that works for either voltage soon.
We don't want too many people frying their pride and joy too soon.
atmega8
Posted: 08:46pm 23 Jan 2014
Hi,
Received some pic32150 128b from Reichelt.de in Germany.
Flashed it via pickit3 and mplabx.
Tested with some I2C chips and played around.
47 uf 6 v tantal and used FTDI 3,3v USB converter.
So far no problems, everything works like i excpected it from Geoff;-)
Let's go further, faster........
Dietmar from DEEdited by atmega8 2014-01-25
Posted: 09:45pm 23 Jan 2014
For anyone trying to use the Micromite with a 5V USB to serial bridge TassyJim has found that you need to use a low value resistor in series with the Tx line from the converter (not the 4.7K that I suggested).
The reason is that I turned on the internal pullup resistor in pin 12 (the Micromite's receive data) to prevent the input from floating. Because of this the series resistor needs to be a low value to pull the input down to below the low logic threshold.
A good value for the series resistor is 1K and this has been tested by Jim and works. You could go as low as 470 ohms if needed and it will not cause any damage.
Posted: 09:57pm 23 Jan 2014
Nice info, Geoff - thanks for that.
elproducts
Posted: 02:38am 24 Jan 2014
  Alan68 said   Hi,
I've had my PIC32MX150 working for a few day's if you look at the photo, you can see I'm using a 47uF 16V electrolytic.
I'm powering the whole circuit from a USB to serial TTL interface that has a 3.3V and 5v output, the USB interface is plugged into a powered USB hub that keeps the whole lot running 24 hours a day.
Is that a KS0108 graphic LCD?
I'd like to see the MMBASIC code too if you're willing to share it.
www.elproducts.com
Posted: 03:42am 24 Jan 2014
  vasi said   Well, apologies to Serge, the last version of pic32prog works excellent!
Was this with a PicKit3 or PicKit2?
Also did Jman (or anyone else) get the PIC32MX250F128B programmed with PicKit2 using Pic32Prog??
I have latest version 1.90M and all seems to program fine and the Config words are what they should be (confirmed by Geoff) but alas nothing happens when power connected.
Have used logic analysers to confirm pins 11 & 12 to see if any life but no signals outputted at all.
I will be trying a PicKit3 later today and will update on progress but in the meantime any positive successes would be appreciated to know exactly what the setup was.
Alan68
Posted: 04:57am 24 Jan 2014
Hi,
Below is the program running on the MircoMite
The display is a 12864 GLCD from Ebay, in text mode.
The program is one of Geoff's that's been changed a little.
The GPS receiver is a SKYLAB and works at 9600
I'm designing a project to examine all the data from A GPS receiver and the data is after say comer 15, I use a subroutine to count the comers as when there is no data available you get a row of comers as the NMEA sentences are never a constant length.
Dim j(20)
SetPin 2,dout 'D0
SetPin 3,dout 'D1
SetPin 4,dout 'D2
SetPin 5,dout 'D3
SetPin 6,dout 'D4
SetPin 7,dout 'D5
SetPin 14,dout 'D6
SetPin 15,dout 'D7
SetPin 16,dout 'E
SetPin 17,dout 'R/W
SetPin 18,dout 'RS
Open "com1:9600,1000" As #1
Pin(17) = 0
Pin(18) = 0
Pause 10
Q = &B00110010 : GoSub LCD : Pause 10
Q = &B00001100 : GoSub LCD : Pause 10
Q = &B00000110 : GoSub LCD : Pause 10
Q = &B00000001 : GoSub LCD : Pause 10
Q = &B00000010 : GoSub LCD : Pause 10
Pin(18) = 1 : Pause 10
Line Input #1 ,n$
If Mid$(n$,1,6) = "$GPRMC" Then
Pin(18) = 0
q = 2 : GoSub LCD ' move to (0,0)
Pin(18) = 1
GoSub COMER
r$ = " " + Mid$(n$,j(0),2) + ":" + Mid$(n$,j(0)+2,2) + ":" + Mid$(n$,j(0)+4,2)
GoSub word
COMER:
L=0
For k= 1 To Len(n$)
If Mid$(n$,k,1) = "," Then
j(L) = k+1 : L=L+1
Next k
Return
WORD:
For W = 1 To Len(r$)
Q = Asc(Mid$(R$,w,1)) : GoSub LCD
Next W
Return
LCD:
Pin(15) = Q And 128
Pin(14) = Q And 64
Pin(7) = Q And 32
Pin(6) = Q And 16
Pin(5) = Q And 8
Pin(4) = Q And 4
Pin(3) = Q And 2
Pin(2) = Q And 1
Pin(16) = 1
Pause 1
Pin(16) = 0
Return
vasi
Posted: 04:58am 24 Jan 2014
Hi,
  WhiteWizzard said
Was this with a PicKit3 or PicKit2?[/quote]
Pickit2
[quote]
Also did Jman (or anyone else) get the PIC32MX250F128B programmed with PicKit2 using Pic32Prog??[/quote]
Mine was PIC32MX220F032D.
[quote]
I have latest version 1.90M and all seems to program fine and the Config words are what they should be (confirmed by Geoff) but alas nothing happens when power connected.[/quote]
This was also the behavior of my program for the same microcontroller when I used the Microchip C compiler. It continues to be. Until now, any program made with anything else than mikroe compilers doesn't work. I will keep trying. Make a blink test with one of the Mikroelektronika compilers (they are writing something also in boot zone - the same program written in Microchip C is written differently by the pic32prog - I will make the tests again and I will open a topic).
Vasi
P.S. I guess the program is there, but nothing to start it. Not a correct jump? This is from the linker script? Maybe Pickit3 knows that and is correcting "the problem"?Edited by vasi 2014-01-25
Elvish name: Mablung Miriel
Beyound Arduino Lang
elproducts
Posted: 05:47am 24 Jan 2014
  Alan68 said   Hi,
Excellent. Thanks.
I didn't realize Geoff had created a Maximite graphic display example.
Does your graphics display have a CS1 and CS2 pin?
I don't see those connections in the code.
The link below is an example schematic I did with Great Cow Basic and a PIC16F886. I'm gonna try to drive this with MicroMite/ Maximite but I'm wondering if the displays are compatible. Mine is a 128x64 based on a KS0108 chip set and I got it on EBAY as well.
http://www.greatcowbasic.com/uploads/9/2/9/8/9298268/glcdsch ematic.pdf
www.elproducts.com
Posted: 08:53am 24 Jan 2014
The MicroMite runs great.
One of the advantages of saving the program in flash is that it is now easy to program a chip including a basic program. Very neat!
I still have problems with the full screen editor, same as on the other Maximites.
I just not seem to get it to work right in Tera Term (4.74).
Is there some secret setting that i miss?
Every time i press an arrow or function key it responds if i want to "exit and discard all changes (Y/N):" often this is followed by a [ and another character depending on which key it triggers.
It seems the esc character is recognized without the following characters. Also often those [A [B etc end up somewhere in the code.
Baudrate is 38400, short wires and clean signal. Checked it with a scope.
The culprit is the handling of vt100 codes.
If i am in edit mode and did not modify the code then it just drops to the ready prompt and again always a [ and a character.
I have tried "transmit delay" with values from 1 to 100. Does not make a difference.
Type really really slow, like one keystroke every two seconds results in the same, but often not on the first use of arrows but the second or third.
Maybe the double use of the ESC code causes the problem. As all VT100 codes begin with an ESC, using ESC to Exit the editor might get wrongly interpreted. With me it seems that every special key (arrows and function keys) results in detecting a ESC and the editor tries to exit. Maybe changing the exit key to F10 might solve this problem.
It really drives me nuts and is completely unworkable. I thought i try it again on the MicroMite but it is still the same problems for me.
Luckily there is MMEdit.
Small video in zip file. Just one keystroke (right arrow)
2014-01-24_193242_micromite.zip
Edited by TZAdvantage 2014-01-25
elproducts
Posted: 09:15am 24 Jan 2014
I haven't had any issues with the editor on my PC but the Mac its still an issue.
To be honest, I actually would have liked the line numbers to still be an option for a very simple interface on MicroMite but I understand the memory limitations.
I'm assume that not many people use the line numbers but if I wanted to make a simple I/O control quickly then being able to write a quick program with any dumb terminal is nice. It also makes it easier for a kid to start programming with it as well.
I also think it gives it that retro look and feel of an old fashion BASIC computer shrunk down to a single IC.
www.elproducts.com
donmck
Posted: 10:03am 24 Jan 2014
  Bryan1 said   Hi Don,
Regards Bryan
The Voltage is selected inside the plastic casing Bryan, so you can't easily change it.
Most units, including FTDI have the voltage written on the case, however the latest Chinese cables use a colour coded system to identify them. see:
http://www.dontronics-shop.com/ftdi-usb-to-serial-ttl-level- 33v-converter-cable.html
Will give you pictures and the explanation on how to tell, if they aren't marked on the case.
Of course the prolific ones I have on special at:
are a lot cheaper than the FTDI ones I have.
Cheers Don...
Edited by donmck 2014-01-25
donmck
Posted: 10:10am 24 Jan 2014
  Grogster said   Great price on those Don - will have to get a couple at least.
Strictly 3V3, however as Geoff has outlined, you can simply make the 5V ones tolerant.
Cheers Don...
     Page 11 of 26
